HPH Twin Shark
Old October 7th 18, 03:09 AM posted to rec.aviation.soaring
waremark
Default HPH Twin Shark
So why isn't an Arcus M in the frame?
Old October 7th 18, 08:04 PM posted to rec.aviation.soaring
Chris Gill
Arcus is much nicer to fly than the 32. However, the Arcus has a
tendancy to 'bob' its nose down upon applying throttle, it has a
skid/nose wheel, but its much nicer to have the tail on the ground.
32 engine is a bit more complex to operate (and different engine to the
arcus/twin shark).
I've not flown the shark (one coming to my place next year, so I'll find
out then!)
I operate a DG1001M and it is much better as a self launching glider
than the Arcus/32. It doesn't handle/go as well as the arcus though.
Chris
Old October 8th 18, 11:46 AM posted to rec.aviation.soaring
waremark
Re Chris Gill saying the Arcus bobs forward onto the nose wheel when applying throttle at the start of the ground run. Yes it can and it is an issue, but it doesn't happen on a smooth surface, and generally not if suitable tail ballast is carried. And even if it does bob forward onto the nose wheel that is not a big problem. So while it is an issue I would consider it quite minor. Another minor issue is that the Arcus has a smaller fuselage fuel tank at only 14 litres (3.5 US gals) so I use the wing bags more often than I would with a larger fuse tank - which is a fiddle.
de Havilland Canada DHC-6 Twin Otter pics 2 [7/8] - Viking Air DHC6 Series 400 Twin Otter 2097069.jpg (1/1) Miloch Aviation Photos 0 September 30th 17 03:12 PM
de Havilland Canada DHC-6 Twin Otter pics 2 [5/8] - Viking Air DHC6 Twin Otter interiormodweb03.jpg (1/1) Miloch Aviation Photos 0 September 30th 17 03:12 PM
de Havilland Canada DHC-6 Twin Otter pics 2 [4/8] - Twin-Otter-DHC-6-100-C-GTKB-Kenn-Borek-Air-Unaalik-Aviation-Kimmirut-NU.jpg (1/1) Miloch Aviation Photos 0 September 30th 17 03:12 PM
de Havilland Canada DHC-6 Twin Otter pics 1 [03/11] - DeHavilland-Canada-DHC-6-100-Twin-Otter-Chile-Air-Force-Fuerza-Aerea-De-Chile-Twin-Engine-Airplane-Aircraft-940.jpg (1/1) Miloch Aviation Photos 0 September 30th 17 03:10 PM
ID Twin w/ twin vert stabs--RPV? Unk_Twin.jpg (01/01) No Name Aviation Photos 5 October 12th 07 05:55 AM
