On Mon, 15 Oct 2018 04:34:27 -0700, Retting wrote:
Looking for information covering tension applied to a towrope during tow and any other maneuvers while on tow. Here's the result of a spreadsheet calculation I did some time back for my Libelle being flown by myself, so the weights are accurate. Of course I still have the spreadsheet. Libelle on tow ============== Glider weight 216 kg Pilot+parachute 73 kg Flying weight 289 kg Glide ratio 36 Drag at best glide 8.03 kg Best glide 53 kts Tow speed 60 kts Drag at tow speed 10.29 kg Climb angle 600 fpm (5.67 degrees) Load due to climb 28.54 kg Total tow load 38.83 kg Explanation =========== I calculated drag at best glide as all-up weight / glide ratio and then scaled it for tow speed as (towspeed^2 / bestglidespeed^2) since drag varies as the square of flying speed. Load due to climb: I calculated the angle as asin(climbrate/towspeed) where both speeds are in kts. The tow load due to climbing is flying weight*(climbrate/towspeed) So the load in the tow rope is drag + climbing load. -- Martin | martin at Gregorie | gregorie dot org |
What would you think the increase (%) would be at start of roll thru aceleration?
A heavy twin at 700 kg? R |
Well start with you can work out the average acceleration...and Newton’s second law...
What are you actually trying to get done here? This will vary from such trivial stuff (like the above) to very complex modeling. |
On Mon, 15 Oct 2018 05:28:59 -0700, Retting wrote:
What would you think the increase (%) would be at start of roll thru aceleration? A heavy twin at 700 kg? That would depend on the total of: a) rolling resistance, i.e. the type of surface, how hard it is, how long the grass, etc. is and tyre pressure. b) the acceleration, which depends on the type of towplane, engine size and the throttle-bending tendencies of the tuggie. c) the slope, if any, of the runway. That, at least, is easy once you know the slope because its the same calculation as the climbing contribution to tow load in the air. I have little idea of the values of parameters a and b except that the acceleration load would be the all-up glider weight multiplied by the acceleration expressed in G, so a 0.1G acceleration would have a tow load of 50kg for an all-up weight of 500kg. However, the initial acceleration is almost certainly less than 0.1G As for rolling resistance, I suggest you fit a decent spring balance to a short length of towline and rings. Then two or three of you can easily measure low speed rolling resistance for a glider or two on a variety of surfaces. It would be interesting to know how much difference there is between rolling resistance on a tarmac surface and a dry, recently mown grass strip. Last but not least, and it would be something to do at the field on a non-flying day. -- Martin | martin at Gregorie | gregorie dot org |
A typical 235Hp Pawnee generates about 400kg of static thurst, that would also be the maximum tension on the rope that the towplane can generate.
On the other hand can the glider generate a towrop tension high enough to break the tope or the weak link if used. |
On Monday, October 15, 2018 at 9:22:43 AM UTC-4, Per Carlin wrote:
A typical 235Hp Pawnee generates about 400kg of static thurst, that would also be the maximum tension on the rope that the towplane can generate. On the other hand can the glider generate a towrop tension high enough to break the tope or the weak link if used. Instead of calculating and modeling these conditions, why not measuring it very accurately? We wanted to know what the force distribution throughout a winch launch is - a far more complex thing than an aero-tow - and built a slick little recorder. It was housed in a 2l soda bottle attached to the apex of drogue chute and recorded the forces and accelerations of multiple launches. The data was compressed and stored on a micro SD card and was read at the end of the day. Uli 'AS' |
Starting new thread.....
![]() Get a life!! |
100 Uganda Shillings to the first to provide the best response to the original thread.
R |
Rope Tension Meter for Auto Tow | [email protected] | Soaring | 18 | June 3rd 20 03:37 PM |
Aerotow towrope instructions | Paul Remde | Soaring | 23 | April 8th 16 10:39 PM |
Winch tension meters - sources? | [email protected] | Soaring | 2 | January 7th 07 01:54 AM |
Tost Retract Towrope on a SuperCub | John Sp | Soaring | 1 | July 24th 05 09:09 PM |
Towrope sources | Paul Remde | Soaring | 1 | January 2nd 05 02:57 AM |
