Refinishing Ventus b Fuselage
Old October 16th 18, 03:08 PM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
Default Refinishing Ventus b Fuselage
On Monday, October 15, 2018 at 6:49:09 PM UTC-7, Mike C wrote:
On Monday, October 15, 2018 at 5:54:39 PM UTC-6, Richard Pfiffner wrote:
On Saturday, October 13, 2018 at 4:01:37 PM UTC-7, Brad wrote:
On Friday, October 12, 2018 at 6:16:35 PM UTC-7, Richard Pfiffner wrote:
Pictures and process for refinishing a ventus b fuselage. Work in progress pictures and process as work is completed.
http://www.craggyaero.com/ventus.htm
Richard
www.craggyaero.com
looking really good. the Tetra will need a fuselage face lift in the next few years. not a total gel/paint removal like you've done, but still a huge amount of labor.
Brad
Rolled on two coats of Duratec Vinyl ester surfacing primer, sanding tomorrow.
Pictures:
Richard
www.craggyaero.com
Hi Richard,
Thank you for documenting this.
Watching with interest, I may do the same this winter.
How smooth/even was the primer after rolling, much different than spraying? I rolled marine PU on a trailer and it flowed very nicely.
What will you be using as a color/top coat?
Thanks,
Mike Carris
It will probably take several coats of surfacer, it does not matter if it is rough. Rolling on eliminates many pin holes. I will let you know after therapy sanding today.
refinishing Ventus 2cm- wing profile [email protected] Soaring 20 November 6th 11 12:15 AM
refinishing Stig Pedersen Soaring 1 November 27th 05 04:50 PM
refinishing Stig Pedersen Soaring 1 November 26th 05 09:16 PM
Second speaker in Ventus 2b/c fuselage [email protected] Soaring 3 September 14th 05 05:41 PM
REFINISHING Ventus B Soaring 32 December 3rd 03 10:14 PM
