ASW-19 Maximum Weight
  #21
Old October 19th 18, 01:18 AM posted to rec.aviation.soaring
Default ASW-19 Maximum Weight
On Thursday, October 18, 2018 at 8:12:31 PM UTC-4, wrote:
On Thursday, October 18, 2018 at 5:19:34 PM UTC-4, Ouroboros wrote:
Here's a link to a copy of the manual:
https://drive.google.com/file/d/1TUV...w?usp=drivesdk
I only see mention of a maximum all up weight and maximum non lifting parts. The manual does have a table for maximum water ballast carried depending on cockpit load, but again is only limited by max gross and non lifting parts.
The manual(note it is for a 19B) is clear. If you have the weighing info that provides wing weight,in addition to total empty weight, you can determine the max pilot weight for that glider based upon max weight of non lifting components. The manual specifically describes fairly heavy pilot mass in the cockpit.
If it is not a B, there is descriptive info on the Schleicher web site on how to do so. It is not a big deal.
Been There Done That
UH
Info:
https://www.alexander-schleicher.de/..._TM06AB_E..pdf
Raises max mass of pilot to about 254 lb.
UH
Maximum aircraft weight a carrier catapult can launch? J[_2_] Naval Aviation 6 June 1st 11 10:01 AM
Minimum amount of Maximum pilot weight Nyal Williams[_2_] Soaring 1 May 22nd 11 10:34 AM
Fiberglass cloth weight vs 'finished' weight Fred the Red Shirt Home Built 12 April 5th 08 04:24 PM
Glider Weight/Wing Loading and determing speed for best L/D for a given weight 65E Soaring 3 January 26th 06 09:26 PM
Empty/Gross weight Vs. Max. Pilot weight Flyhighdave Soaring 13 January 14th 04 04:20 AM
