L-13 Blanik Tow OUt Gear
Old October 31st 18, 11:41 PM posted to rec.aviation.soaring
Boise Pilot
Default L-13 Blanik Tow OUt Gear
My 12 year old is now 38 and not interested...and not many 12 year olds hanging out at the airport. Understand the comment about towing it backwards, will have to have the tail wheel off the ground on some type of tow bar. Blanik America sent me a couple of photos of two variations for L-23's that were manufactured by the then Blanik factory 12 years ago. Not usable as designed, for a l-13 but a start. Just hoped some owner of the 125 Blanik l-13's in the US before the grounding AD had addressed this issue.
Boise Pilot
On Wednesday, October 31, 2018 at 1:31:24 PM UTC-6, wrote:
On Tuesday, October 30, 2018 at 9:56:59 AM UTC-7, Boise Pilot wrote:
Looking for examples of L-13 tow out gear. Has anyone designed and or constructed equipment to facilitate towing a L-13, 13ac, or 23 behind a vehicle? Now that I have mine flying again I am looking for a way to move it around the airport by myself.
Boise Pilot
That is what a 12 year old is for.
A wing runner wheel made by making a fiberglass splash off the tip is simple.
If the rebuild left the wench bridle attachments in place, towing it forward is the best. The L13 tail structure is to fragile to work for a backward tow.
02Soar
Old November 1st 18, 02:51 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Not really tow out gear related, but I recall years ago, Bill Seed discovered that the ailerons had a "stop to stop motion" that would get going at about 5-10 MPH tailwind. You might need to restrain the stick or have an obvious, easy to remove gust lock to prevent damaging the ailerons. This mode was encountered when pulling the plane forward, downwind, to the end of the runway for doing auto tows. Wind speed minus walking speed set it off. Something to be aware of.
As for a tow bar, could you make a cuff with a wheel to set the tail in, then pin it to the airframe where the ground handling tail tube gets poked through? Your wing wheel is going to have a really big cuff!
Good luck!
Steve Leonard
Old November 1st 18, 06:02 PM posted to rec.aviation.soaring
AS
Good luck!
Steve Leonard
My club in Germany operated a L13 until the left wing came off in mid-flight. Originally, the L13 only had a tail-skid and the ground handling dolly we had was just like Steve described: an A-shaped frame with bushings on each end to put an aluminum tube through them and the fuselage and a well for the skid. There was a caster wheel with a pneumatic tire below that well. Because the L13 is a 'tail-sitter' no additional fastenings between the tail skid and the dolly was required.
Later, we had the factory replace the tail skid with a caster tail wheel so the dolly became obsolete.
It would be quite conceivable to install an off-center tow bar on that dolly and make an wing-wheel with an open cuff so one wouldn't have to deal with the 'tip-tanks'.
Uli
'AS'
Blanik landing gear strut needed Charles Longley Soaring 0 February 21st 18 03:57 AM
Blanik L-23 Super Blanik Manual -F.C.F.S. Joel Flamenbaum Soaring 2 April 14th 10 03:29 PM
Blanik L-13 tow out gear TDixon Soaring 4 February 16th 10 12:30 AM
Gear Up, pt 4 - Crashed He 111 with balloon cable cutting gear - July 1940.jpg (1/1) Mitchell Holman Aviation Photos 0 April 13th 07 01:50 PM
Blanik L-13 Tow Out Gear [email protected] Soaring 4 June 8th 05 04:40 AM
