kinsell wrote on 11/13/2018 9:18 PM:
scinating videos on YouTube. However, "safer" isn't actually the same as "safe", LFP's are quite capable of burning, despite what the scholarly articles say.* There have been a number of fires, particularly when they're used as starter batteries.* High charge rates and very high discharge rates seem to cause problems, as homebuilders of small power planes have discovered. There was also that LFP battery fire in an EB-28 in Finland this summer. -Dave Dave, if you look around youtube long enough, you will find that a AAA battery can make a fire. Certainly a 12V lead-acid has enough juice to do that if circumstances are right. The overwhelming evidence of many years of usage of LiFePo4 chemistry in glider batteries suggests that they are as safe as the old gel-cells. Give progress a chance, I'm not saying be a Progressive. Herb If you come across a YouTube video of an AAA battery filling a cockpit with toxic smoke, you be sure to post the link, OK? Meanwhile, this is the sort of progress I can live without: https://www.pilotsofamerica.com/comm...-fires.102016/ I did not see any indication the burning battery had a BMS. Some builders put in the "starter" LiFe batteries that do not have a BMS, so perhaps that is the reason the battery burned. I think LiFe batteries from the usual suppliers (Bienno, K2, Stark - for example) with a BMS, used for instrument batteries, and charged with the recommended charger are as safe as a comparable capacity SLA. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 - "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm http://soaringsafety.org/prevention/...anes-2014A.pdf |
On Friday, November 16, 2018 at 7:20:53 PM UTC-8, Eric Greenwell wrote:
kinsell wrote on 11/13/2018 9:18 PM: scinating videos on YouTube. However, "safer" isn't actually the same as "safe", LFP's are quite capable of burning, despite what the scholarly articles say.Â* There have been a number of fires, particularly when they're used as starter batteries.Â* High charge rates and very high discharge rates seem to cause problems, as homebuilders of small power planes have discovered.. There was also that LFP battery fire in an EB-28 in Finland this summer. -Dave Dave, if you look around youtube long enough, you will find that a AAA battery can make a fire. Certainly a 12V lead-acid has enough juice to do that if circumstances are right. The overwhelming evidence of many years of usage of LiFePo4 chemistry in glider batteries suggests that they are as safe as the old gel-cells. Give progress a chance, I'm not saying be a Progressive. Herb If you come across a YouTube video of an AAA battery filling a cockpit with toxic smoke, you be sure to post the link, OK? Meanwhile, this is the sort of progress I can live without: https://www.pilotsofamerica.com/comm...-fires.102016/ I did not see any indication the burning battery had a BMS. Some builders put in the "starter" LiFe batteries that do not have a BMS, so perhaps that is the reason the battery burned. I think LiFe batteries from the usual suppliers (Bienno, K2, Stark - for example) with a BMS, used for instrument batteries, and charged with the recommended charger are as safe as a comparable capacity SLA. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 - "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm http://soaringsafety.org/prevention/...anes-2014A.pdf Several years ago I had a bad batch of batteries from one of the suppliers you mentioned in your post. 4 to 5 aH capacity in a 10 Ah battery. I quit selling them. I now sell LiFePO4 batteries that I personally test before shipping with a West Mountain Radio computer tester. Document is supplied with the battery. http://www.craggyaero.com/lifepo4_battery.htm Richard www.craggyaero.com |
Richard Pfiffner wrote on 11/17/2018 10:22 AM:
On Friday, November 16, 2018 at 7:20:53 PM UTC-8, Eric Greenwell wrote: https://www.pilotsofamerica.com/comm...-fires.102016/ I did not see any indication the burning battery had a BMS. Some builders put in the "starter" LiFe batteries that do not have a BMS, so perhaps that is the reason the battery burned. I think LiFe batteries from the usual suppliers (Bienno, K2, Stark - for example) with a BMS, used for instrument batteries, and charged with the recommended charger are as safe as a comparable capacity SLA. Several years ago I had a bad batch of batteries from one of the suppliers you mentioned in your post. 4 to 5 aH capacity in a 10 Ah battery. I quit selling them. I now sell LiFePO4 batteries that I personally test before shipping with a West Mountain Radio computer tester. Document is supplied with the battery. http://www.craggyaero.com/lifepo4_battery.htm I test every battery before installing it, also using a West Mountain tester. Over the years, I've had three SLA batteries that had half their rated capacity, and returned them. I've only used one LiFe battery, and it had exactly the rated capacity. Couldn't believe it - tested it again, and got the same answer. |
Battery Chargers | Stan Amyett | Soaring | 2 | March 12th 04 05:27 AM |
Solar Battery Chargers | Jay Honeck | Piloting | 32 | February 22nd 04 11:17 PM |
Battery Chargers | Mike Rapoport | Owning | 11 | December 2nd 03 11:55 PM |
Rechargable AA batteries and chargers | TripFarmer | General Aviation | 2 | October 17th 03 06:34 PM |
Rechargable batteries and chargers....... | TripFarmer | Products | 2 | October 17th 03 06:31 PM |
