Which 18m FES sailplane to buy?
Old November 27th 18, 02:53 PM posted to rec.aviation.soaring
slbair
Default Which 18m FES sailplane to buy?
Matt,
I am currently flying a 17B FES and and have a Mini Lak FESL on order. I would really appreciate a conversation about your trip to the factory and your thoughts on both the Mini and the 17C. Here's my email address: . Thanks,
Steve Bair
  #72
Old November 27th 18, 03:14 PM posted to rec.aviation.soaring
Matt,
Thank you so much for sharing your most positive experience with Lak. I am in a full agreement with the previous poster, in that I would love to hear more about your recent visit to their production facilities. As I told our Lak sales representative up here in Canada, it’s unfortunate Lak doesn’t organize a North American tour with there lineup of toys. I have several questions and concerns over their products, starting with fit and comfort in a Mini with my 6 foot frame, to support for batteries here in North America.
John Hebert
Montreal, Canada
  #73
Old November 27th 18, 07:22 PM posted to rec.aviation.soaring
Matt Herron (Sr)
On Tuesday, November 27, 2018 at 7:14:48 AM UTC-8, wrote:
Matt,
John Hebert
Montreal, Canada
  #74
Old November 27th 18, 07:23 PM posted to rec.aviation.soaring
Matt Herron (Sr)
Matt,
John Hebert
Montreal, Canada
  #75
Old November 27th 18, 07:26 PM posted to rec.aviation.soaring
Matt Herron (Sr)
Hi John:
I'm 5'7", so I can't help you on fit. But I found both the LAK17 and the Mini completely comfortable, and I think there was extra room beyond my personal dimensions. The 17 and the Mini essentially have the same fuselage, so if you've ever sat in a 17, you would probably find the Mini about the same fit.
As for batteries, I assume one could get support through US/Canadian distributor, but my guess is that any serious repairs would have to come from LZ in Slovenia.
As you probably know, LZ recalled all FES batteries for inspection and upgrade following the two battery fires. Here's what I wrote about that issue for Soaring:
In accordance with a Modification Bulletin
issued by the European Aviation Safety Agency
(EASA), the LAK factory has reinforced the
battery pack housing with flame retardant
fiberglass, installed an independent fire
warning system, and added a safety valve smoke
vent to the battery compartment cover.
The FES system has been with us for about
eight years now. During this time some 180
gliders have been fitted with the engine,
either as self-launch or sustainer. /There
have been no reported engine failures in
flight./ However, there have been two fires
involving the lithium polymer battery packs at
the heart of the FES system. One happened
during a landing in the UK and was
extinguished after the pilot exited the glider
safely. The pilot reported that one of the
battery packs had previously been dropped,
which could have damaged one or more of the
lithium cells. The other fire occurred in a
trailer where the batteries had been stored
with the units still connected, a big “no no“
according to FES maintenance manuals. While
the exact cause of the fires has not been
determined, any fire involving lithium
batteries can be extremely serious – these
units pack a lot of energy and must be handled
with respect.
In response to the fires, LZ Design, the
Slovenian manufacturer of the FES system, has
recalled all the battery packs for disassembly
and inspection. LZ is checking for the
suspected presence of small metal shards, a
possible by-product of machine work on the
battery case cover. Since the individual
lithium cells are housed in plastic bags
rather than hard cases, if a shard were
present it would be possible for it to migrate
during battery usage and penetrate a lithium
cell, potentially causing a short and a
resulting fire. After each inspection is
complete, LZ re-installs all the lithium cells
in a solid matrix of silicon gel, which should
correct the problem.
Regards,
Matt Herron
  #76
Old November 27th 18, 08:22 PM posted to rec.aviation.soaring
On Tuesday, November 27, 2018 at 2:26:46 PM UTC-5, Matt Herron (Sr) wrote:
Hi John:
with respect.
Regards,
Matt Herron
3 fires. One in the US
UH
  #77
Old November 28th 18, 01:12 AM posted to rec.aviation.soaring
John,
I took a chance to try on Jamie Shore's Mini LAK here at SCOH and I did fit - barely. I am 6'2" and I think with some fiddling of the seat cushion type I would fit very comfortably. Did not get to fly it so cannot comment on how comfortable I would be after 3 to 4 hours in it - guess I'll have to fly before I buy.
Tony Smolder
TS1
  #78
Old November 28th 18, 04:01 AM posted to rec.aviation.soaring
2G
Hi John:
with respect.
Regards,
Matt Herron
UH
I went to the FES presentation in Reno this year. I was unimpressed in the resolution of the fires that have occurred (I am an electrical engineer), especially in not acknowledging the third fire. My advice is to wait until the root cause of these fires has been conclusively identified. Having a parachute (as one friend of mine opined) is not an adequate backup plan.
Tom
  #79
Old November 28th 18, 04:54 AM posted to rec.aviation.soaring
kinsell
Hi John:
with respect.
Regards,
Matt Herron
UH
Tom
The third fire was disclosed in one of the papers I read, it was about
40 pages on the testing and corrective actions that were being taken.
It did strike me as random shotgunning of fixes, replacing the carbon
fiber battery cases with fiberglass would seem to be minimally effective
for a lithium fire. Improving the terminal insulation, when terminal
insulation had no apparent involvement in the fires, may not do
anything. Hard to argue with an improved fire detection system, but
does nothing to prevent the fires.
-Dave
  #80
Old November 28th 18, 05:03 AM posted to rec.aviation.soaring
kinsell
Hi John:
with respect.
Regards,
Matt Herron
UH
Tom
Page number 38, brief mention
https://assets.publishing.service.go...GSGS_09-18.pdf
Would you rather fly a Sailplane? Karen Soaring 18 June 7th 12 02:28 AM
Best Looking Sailplane glider[_2_] Soaring 52 November 23rd 09 04:29 PM
Could this be used in a sailplane? Spam Soaring 6 July 5th 09 08:16 PM
Another Sailplane Ben Jeffrey Aviation Photos 2 June 24th 08 08:11 PM
Sailplane Upholstery Gadget Guy Soaring 3 February 15th 06 09:54 PM
