LXNAV 8000 OAT Incorrect
Old December 7th 18, 06:25 PM posted to rec.aviation.soaring
Deming Gray
Default LXNAV 8000 OAT Incorrect
Hello everyone, this is my first post. I am new to soaring and have acquired a glider with an LXNAV 8000 already installed. I noticed yesterday that the outside temperature (OAT) is incorrect by about 20 degrees F. I placed the probe in a bath of ice water and it read 50 degrees F and responded to temperature changes. I have not found anything in the manual nor on the LXNAV website. Does anyone know where I should go to look for information on this issue? I don't know if the instrument is adjustable, programable or if the probe needs replacment, etc. Any ideas or thoughts would be appreciated. Thanks,
Deming
Old December 7th 18, 09:25 PM posted to rec.aviation.soaring
Tim Newport-Peace[_4_]
acqui=
tha=
plac=
responded
the=
information=
programable
appr=
eciated. Thanks,
Deming
Email your problem to
Old December 7th 18, 10:13 PM posted to rec.aviation.soaring
Dave Springford
Deming,
In the user manual for Ver 6.04, section 5.1.11.1 it explains how to adjust the temperature offset.
Manuals can be downloaded from the LXNAV website he
https://gliding.lxnav.com/lxdownloads/manuals/
I'm also not sure that putting the probe in water was a good thing as I believe there is a small current that runs through the probe and getting it wet may not be good.
Old December 7th 18, 10:57 PM posted to rec.aviation.soaring
Darryl Ramm
On Friday, December 7, 2018 at 2:13:56 PM UTC-8, Dave Springford wrote:
Deming,
Getting the probe wet is not a problem and calibrating for 0C in an ice bath is a great diagnostic idea.
Dan Marotta
Putting the probe in ice water is the best way to get a true 32 deg F
reading.Â* It won't hurt the probe.
On 12/7/2018 3:13 PM, Dave Springford wrote:
Deming,
Dan, 5J
Old December 8th 18, 02:10 PM posted to rec.aviation.soaring
Deming,
Dan, 5J
Perfect, Dan! That's how you calibrate a temp probe. If we ditched the lousy Fahrenheit scale for Centigrade this would be known more widely. Melting ice and boiling water are the Standards (at sea level) to establish 0 deg C and 100 deg C.
Congrats, you made an important step to seeing the superiority of the metric system. Now let's talk about how a 10x10x10 cm volume of water makes 1 liter and also weighs 1kg. It could all be so easy...
Herb, J7
Old December 8th 18, 04:45 PM posted to rec.aviation.soaring
Dan Marotta
Sorry Herb, but that was Darryl who used the 0 deg C for the ice bath.Â*
I was just musing the other day about why, when listening to our AWOS
recordings they use inches of mercury for the altimeter setting, feet
for cloud layers, knots for winds, and, phhhht... Celsius for the
temperature.
Why screw up a perfectly good recording with that metric crap?Â* My pink
little body is comfortable at 72 deg F.Â* I just don't comprehend
22.22222 deg C, 295.3722 deg Kelvin, or 531.67 deg Rankin.Â* Real men
don't need 10, 10, 10 to make their calculations easy.Â* We still can,
but we just don't want to.Â* Can't we all just live together in peace?Â*
Kum bi ya... :-D
Deming,
Dan, 5J
Herb, J7
Dan, 5J
Old December 10th 18, 04:18 PM posted to rec.aviation.soaring
temperature.
Kum bi ya... :-D
Deming,
Dan, 5J
Herb, J7
Dan, 5J
Dan, background and personal history matter. If you had spent the first 35 years of your life around a highly rational (metric) system of measures - which the French came up with, hail to them - you'd feel different about the helter-skelter BS system we are using. Btw, if you work in most any industry these days in the US, you're on metric. Of course, the sciences have been forever.
Has nothing to do with peaceful co-existence, all with sanity and rationality.
Herb, J7
Old December 10th 18, 04:43 PM posted to rec.aviation.soaring
Tango Eight
temperature.
Kum bi ya... :-D
Deming,
Dan, 5J
Herb, J7
Dan, 5J
Herb, J7
Says the guy that thinks a turnip has a gender, but an unmarried woman does not :-).
best,
Evan / T8
Old December 11th 18, 01:15 AM posted to rec.aviation.soaring
Scott Williams
Sorry Herb, but that was Darryl who used the 0 deg C for the ice bath..Â*
temperature.
Kum bi ya... :-D
Deming,
Dan, 5J
Herb, J7
Dan, 5J
Herb, J7
best,
Evan / T8
Isn't it all arbitrary after all, while it may appear valid on the macro scale, get down to the physics and it's all relative! ;-)
US 1986-08800 VC-25A as 82-8000.jpg Joseph Testagrose Aviation Photos 0 April 20th 15 12:46 PM
LX 8000 problem Philip van de Donk Soaring 0 February 24th 14 11:03 AM
Politically Incorrect, Historically Accurate Hymnals Bill Kambic Naval Aviation 0 November 10th 08 10:32 PM
Warning: GPS data incorrect Cheetah236 Instrument Flight Rules 17 September 23rd 05 07:50 AM
Incorrect Coastlines..Channel Islands....HELP !!!! Derek Simulators 0 March 23rd 05 11:50 PM
