LXNAV 8000 OAT Incorrect
Old December 13th 18, 10:23 AM posted to rec.aviation.soaring
Nick Hoare[_2_]
Default LXNAV 8000 OAT Incorrect
Worth bearing in mind that the OAT signal actually goes to the vario and
not the LX main unit.
The spec of the probe was changed a few years ago when some new vario types
were introduced (we had to fit a new probe when we upgraded to the V9
vario) so if you have changed the vario recently you may have the wrong
probe.
Also make sure the probe cable hasn't been cut and repaired, my
understanding is that you can't do this as it changes the resistance of the
unit and throws the readings off so if it has you need a new probe.
Old December 13th 18, 09:00 PM posted to rec.aviation.soaring
Deming Gray
Thanks Nick,
I have traced the wiring and do not see a damaged wire. This LX8000 and V8 were already installed in the aircraft when I purchased it. I didn't know the probe connected to the vario, I'm reading OAT on the LX8000. I'm still clueless as to why it is consistently off by 20 degrees F.
Deming
Old December 13th 18, 09:50 PM posted to rec.aviation.soaring
Tim Newport-Peace[_4_]
At 21:00 13 December 2018, Deming Gray wrote:
Thanks Nick,
V8=
know=
stil=
Deming
Earlier I posted "Email your problem to ". Have you received
a reply? I have found them to be quite helpful.
Old December 13th 18, 10:05 PM posted to rec.aviation.soaring
Nick Hoare[_2_]
Thanks Nick,
V8=
know=
stil=
Deming
Deming, as someone suggested earlier I would email LX, they respond very
quickly and always seem keen to sort out their users problems.
US 1986-08800 VC-25A as 82-8000.jpg Joseph Testagrose Aviation Photos 0 April 20th 15 12:46 PM
LX 8000 problem Philip van de Donk Soaring 0 February 24th 14 11:03 AM
Politically Incorrect, Historically Accurate Hymnals Bill Kambic Naval Aviation 0 November 10th 08 10:32 PM
Warning: GPS data incorrect Cheetah236 Instrument Flight Rules 17 September 23rd 05 07:50 AM
Incorrect Coastlines..Channel Islands....HELP !!!! Derek Simulators 0 March 23rd 05 11:50 PM
