As others mentioned, the wind calculation from Air Glide is in a class of its own and gives interesting insighta. The vario is on par with for example ClearNav-Vario. I am very happy with this instrument.
Critical factors for ISU installation are the absence of magnetic compass and speakers within 50cm. If you plan to install the ISU somewhere in the instrument panel, you will have to remove the magnetic compass and put the speakers near the headrest. Usually, a place right under the instrument cover works well. Use non magnetic screws/nuts for fixation, do not fix any cables to the ISU and align carefully as instructed in the manual. Best, Christoph |
In Canada a compass is not required in a glider if you have magnetic sensor. I put the Air Glide speaker in the nose cone ahead of the rudder pedals (might not work for really tall folks).
New LXNAV S8 vario | Paul Remde | Soaring | 5 | October 12th 15 04:14 PM |
Wanted: LXNav V7 Vario | Greg Delp | Soaring | 0 | April 1st 14 10:18 PM |
New vario by LXNAV | [email protected] | Soaring | 6 | May 22nd 13 11:15 PM |
LXNav V7 vs Butterfly vario? | Chris Davison[_2_] | Soaring | 32 | January 8th 13 09:37 AM |
Performance loss versus yaw string deflection | Eric Greenwell | Soaring | 7 | July 20th 09 03:27 AM |
