Looking for A-14 (or similar) pressure breathing diluter demand regulator
Old December 18th 18, 06:06 PM posted to rec.aviation.soaring
Default Looking for A-14 (or similar) pressure breathing diluter demand regulator
On Tuesday, October 30, 2018 at 2:32:17 PM UTC-7, Keith Schwab wrote:
Hi Everyone!
I'm looking for an A-14 regulator, or something similar, to prepare for higher altitude wave flights in the Sierra. Curious if anyone has an one laying around they might be willing to part with or lend for a season.
Thanks!
Keith
Following up on Keith's post, I've done a lot of work investigating A14 regulators as I too am interested in getting equipped to fly high the Sierra wave. I'll spare you all the gory details of my research but here follow the key points to consider. I also found a line on several "NS", new surplus, A14s that meet all the the requirements for safe use and I will be glad to hook up interested pilots. Getting quantity and pricing info now.
A14 Issues
* vintage units use Radium-226 paint and are no longer legal. No one will work on these even if brand new.
* vintage units were only rated for 500 psi maximum inlet pressure and had a brass inlet housing. Need stainless steel inlet housing or an insert modification for anyone to overhaul.
* only FPI out of Ohio will overhaul A14s. Demand was too low for other shops to continue so most, if not all, discontinued service. If anyone knows of another shop let me know. Monopoly shops tend to charge more!
* FPI will only service FPI units build in 1990 with part #1550. They will return all other units to you. Liability issues? New A14s from FPI are $1,700.
* for the purpose of this listing, vintage = 1989 and older. I bought a "NS" unit from 1954. Beautiful but only good as a boat anchor.
A MH system will only get you to single Lennie territory (FL250). To get to double and triple Lennie altitudes, up to FL400+, you will need a diluter demand pressure breathing unit like the A14.
Masks, hoses, flow meters, pressure gauges, bailout bottles, and microphone amplifiers, jacks and plugs, to convert from military to civilian impedance radio systems, are also readily available in new condition. Contact me for details on suppliers and part numbers.
VVII
Old December 19th 18, 05:39 AM posted to rec.aviation.soaring
Tango Whisky
At FL300+, you will need a pressure suit.
Old December 19th 18, 06:20 AM posted to rec.aviation.soaring
TW,
Not so. FL500 is the generally accepted altitude where pressurized suits are required and by FL620 your blood at body temperature boils.
I think you are mixing up pressurized breathing with pressurized suits which is needed above FL400. I've flown to FL280 with an Alps mask on a MH system and had no difficulties. I know pilots who pushed this limit to FL320 with a MH system and an unpressurized system but this is certainly not recommended. The A14 will allow you to pressure breath at FL400 and above and apparently even a short duration trip to FL500 is possible. I personally would not go above FL450.
If you recall the recent passing of Bob Harris you will note that he flew to FL490 with a redundant A14 system. Probably the best lesson learned from his flight was the importance of having a well secured mask. Apparently he had to limit his climb because he couldn't keep his mask on as the pressure increased! He did not have a pressure suit.
VVII
Old December 19th 18, 11:07 AM posted to rec.aviation.soaring
Duster[_2_]
The A-14 system, so I thought, is not a true pressure-demand type required at greater altitudes, but is a diluter-demand pressure regulated system with manual pressure valving available(?) Not to be confused with "pulse-demand" EDS. If needed I have a diluter-demand mask with microphone that can be loaned to Keith for his adventure.
While a cup of blood (or water for that matter) will boil at that altitude, circulating blood in a semi-sealed body will likely not (look up "Myth, boiling blood"). Mouth saliva would freeze first. Amazingly, experts say the astronaut in "2001 a Space Odyssey" caught in open space could theoretically have survived his short exposure.
If there's one locally, take a "flight" in an altitude chamber to discover how you function under hypoxic conditions (or you can try breathing a mixture of N2 with air/O2 to get your blood sat to 90% and less).
Old December 19th 18, 11:11 AM posted to rec.aviation.soaring
Duster[_2_]
If there's one locally, take a "flight" in an altitude chamber to discover how you function under hypoxic conditions (or you can try breathing a mixture of N2 with air/O2 to get your blood sat to 90% and less). "drunk" pilot: https://www.reddit.com/r/videos/comm...are_emergency/
Old December 19th 18, 03:34 PM posted to rec.aviation.soaring
The diluter-demand function of the A14, from what I have read, occurs below a certain altitude, 30,000' if I recall correctly. In this mode the mixing chamber mixes cabin air with O2 and the amount of O2 increases with altitude. Above this altitude it supplies 100% O2. The pressure breathing function is a separate function that has different dial settings for increasing altitudes. Here the pressure of the O2 supplied not the mixture to the mask increases. The markings on the A14 dial suggest 5 different pressures for settings of Safety, 41,000', 43,000', 45,000', & above 45,000'. Not sure why the 1st dial setting is marked Safety but it is the 1st position when the dial is turned off normal.
I've read the same about blood boiling. I think, as you have pointed out, they are referring to an uncontained and uncirculating liquid and meant to make a point about how low the pressure is. Articles I've read also use statements like "seems to boil" instead of boils. I guess the body can contain the vapor pressure sufficiently so it doesn't reach atmospheric pressure and really boil. Apparently the skin will expand and early experiments with dogs in space or a vacuum chamber discovered this. Saliva boiling on the tongue makes sense.
I do plan to get experience in a hypobaric chamber and am hoping they will let me use my own mask, regulator, and bottle however, I suspect this might be considered a liability for then to allow. I still plan to ask. What better way to test the performance of the system I intend to use at FL350-400!
Old December 19th 18, 07:20 PM posted to rec.aviation.soaring
BobW
Default Looking for A-14 (or similar) pressure breathing diluter demandregulator
FWIW...
Everything I've read (inhaled, unavoidable pun) since the early 1970s -
primary source: "Soaring" mags" (multiple/excellent "near-first-hand"
articles/columns throughout '70s/'80s) - said the same thing(s). Nothing on
RAS to which I lend credibility (i.e. "hearsay" seriously discounted) has
contradicted any of the above, since my RAS-introduction/continuing-exposure
ca. '96.
be considered a liability for them to allow. I still plan to ask. What
FL350-400!
That's "exactly" what the late Bill Ivans (ca. '92) told me he did in the
years after WW-II before setting the world-altitude soaring-record (42,100',
as I seem to recall; '52?) that Paul Bikle broke (1961); memory sez both were
set in Schweizer 1-23s. Excerpts of my tape-recorded interview with Ivans
about those years of his soaring can be found in the book "Exploring the Monster".
Kinda-sorta related, I also interviewed (several times) Dr. J. Kuettner
(credited with the "scientific discovery" of standing lee waves, & Lead
Investigator of the subsequent Sierra Wave Projects), about: wave; his
experiences in same; his involvement(s) in illuminating waves' atmospheric
physics; his perception of "existing knowledge" of high-altitude physiology in
the timeframe ~'35-'55; etc.
My takeaways from my brain-picking - and a "chamber ride" ca. early-'80s) -
were/remain several...
- humans are physiologically complex critters, and one size definitely does
NOT fit all; almost certainly YMWV
- any "cast in concrete" safety claims regarding "high-altitude (say 35k'),
unpressurized-cockpit, supplementally-O2-assisted" flight beyond "It's
definitely life-threateningly risky," are likely misleading/inaccurate. "Back
then," high-altitude human physiology was FAR from being "pigeon-holed by
science" in "absolute safety" terms, and in a related vein,
"personally-derived high-altitude limits" seemed to be the accepted norm, at
least among the Sierra Wave Project participants. (Anecdotes below...)
Bill Ivans couldn't remember exactly how high he'd been taken in his chamber
ride, but "definitely" above 40k' (possibly 46k'). Without digging into
ancient notes, I can't remember how-high he set his personal limits prior to
his record-setting altitude flight, but I DO remember him chuckling that the
flight completely satisfied his "altitude curiosity!" I took that to mean he
felt he'd no continuing need to soar "near the physiological edge" going
forward. His job prevented him from piloting during the Sierra Wave Projects,
and I don't know if he was sounded out about doing so or not, but had he been
able, my long-after-the-fact guess was he might've declined.
The long-standing 2-seater world-soaring-altitude/gain flight of ~42k' set in
a Pratt-Read by Larry Edgar and Hal Klieforth (broken by Einar Enevoldsen and
the late Steve Fossett, I believe), had been intended to go no higher than
40k', the nominal limit the Sierra Wave Project soaring participants
pre-selected as their safety-limit for physiological reasons. The extra height
was due solely to the search time required to find descending air, once the
crew had decided "enough for today."
None of the Sierra Wave Project pilots could remember, or admitted to, any
"serious physiologic issues" on/after any of their high-altitude forays
(intestinal gas and cold temperatures notwithstanding). They all practiced
"best practices" before/during each flight, e.g. dietary choices, sleep
practices (not always hewed to, per Dr. K., commonly becuzza the need to
change-out batteries post-flight during a spell of more-or-less-daily standing
waves good for research), pre-breathing 100% O2, etc.
My sense is much of the "high-altitude-physiological-related" institutional
knowledge within the general sport-soaring world (U.S. anyway) has been
gradually lessened/lost due to the passage of time/aging/decreasing
availability of high-altitude chamber access for civilians/etc., to be
"commonly replaced" by a generation of pilots having distinctly different
norms for acceptable risk than the WW-II and immediately-following generations.
Insofar as deciding to take up a voluntary sporting activity (soaring, in this
case), some level of general ignorance is normally the beginning state.
Sometimes (often?) this natural ignorance is expressed in
needlessly/misguidingly stated maxims that quite simply are incorrect. This -
IMHO - is fairly common regarding high-altitude soaring flight...which is
definitely increasingly-seriously risky with increasing altitude, but those
risks are "adequately comprehensible and systematically-addressable," as
(thinks I) the history of post-WW-II high altitude soaring in the U.S. well
documents.
Personally, have at it and may good fortune accompany your preparations!
Bob W.
This email has been checked for viruses by AVG.
https://www.avg.com
Old December 19th 18, 10:05 PM posted to rec.aviation.soaring
Wow, thats quite some history Bob! I need to read up on wave history a lot more! Did you ever track any of the flights from up in Cowley, Alberta at the so called Diamond Mine? I had my 1st wave flight there about 9 years ago and I was hooked! I also learned a few new acronyms from you-FWIW and YMWV I could decipher but RAS? Silent Leader? Appreciate all your comments and I do look forward to a chamber ride before committing to anything above FL300! This is purely a recreational pursuit and one of several gliding challenges for me but it's definitely not to be taken lightly as my two favorite aviation sayings remind me......1) takeoffs are optional but landings are mandatory &...... 2) I'd rather be on the ground wishing I was in the air than (very high) in air wishing I was on the ground!
VVII
Old December 19th 18, 05:44 PM posted to rec.aviation.soaring
Just updating my initial post with availability and cost of New Surplus (NS) A14 regulators manufactured by FPI in 1990 with part #1550. These are new in the original OEM packaging. Stock is currently 10 units and the cost is $600 per unit. Let me know if anyone needs a unit and I will put you in touch with the shop in CA that is stocking these. Also, if anyone knows of a shop that can overhaul these units besides FPI, and especially someone out west, please advise.
VVII
Pressure breathing O2 regulator these days? Bob Kuykendall Soaring 11 November 16th 14 11:48 PM
A-14 Diluter Demand Regulator with blinker, tank, bailout bottle flgliderpilot[_2_] Soaring 0 July 18th 14 04:55 AM
Fuel Pressure Regulator for Aviation DonMorrisey Home Built 2 March 23rd 07 03:00 AM
Scott oxygen mask and diluter demand regulator for sale nzuri Soaring 0 October 5th 03 08:18 AM
Scott oxygen mask and diluter-demand regulator for sale in UK nzuri Soaring 0 September 28th 03 10:46 PM
