As Dan had pointed out to me in an e-mail, if you use the software switch in the transponder and are flying in wave or against strong winds, it would show you as on the ground while you are at altitude. The software switch is based on GPS ground speed. Not good. So I will be installing the hardware airspeed switch.
Bruce For experimental gliders fly in 'adsb airspace' after 2020, the Trig website guidance (below) is to use an uncertified puck gps antenna, TN72, and TT22 with SIL=3 setting. Also an 'airspeed switch', but they aren't clear if this must be hardware or can be the software setting of the TT22. https://www.trig-avionics.com/librar...ust%202018.pdf |
How gliders fly | Frank Whiteley | Soaring | 6 | March 19th 15 01:31 PM |
Pure Pointless Leftard Rant | Eunometic | Naval Aviation | 0 | March 6th 11 03:09 AM |
J3, It is pure perversity to post jpeg in par and rar files! | Abc | Aviation Photos | 4 | August 11th 08 07:30 PM |
Silent 2 pure sailplane soars 900+km / April 24th | Blake Miller | Soaring | 2 | April 26th 05 08:02 PM |
What is an air combat victory? Pure egoism. | Cub Driver | Military Aviation | 9 | July 2nd 03 09:36 PM |
