Grob 103 Spoiler Mechanism Removal?
Old January 7th 19, 03:39 AM posted to rec.aviation.soaring
Scott Williams
Default Grob 103 Spoiler Mechanism Removal?
On Sunday, January 6, 2019 at 9:06:11 AM UTC-6, wrote:
Don’t remove the pushrods, unless you must. The guides have a sliding sleeve with little plastic balls, when the pushrod is pulled out,one hears rattle, rattle, tink, tink..........as the balls fall out inside the wing! Inspect the spoiler plates, pivot bushings and bolts in place and if all looks good, lube and walk away. Pull up on the caps to check the springs, then close and lock to check for nothing sticking up.
Hope this helps,
JJ
select Grob 103 serial numbers have a reoccurring inspection of the spoiler bellcranks for cracks. there is a access hatch modification to get to them to repair/replace. you might check http://www.ltb-lindner.com/ for more information.
good luck,
Scott
Grob twin II rear canopy hinge release mechanism mas Soaring 2 July 5th 17 06:06 PM
Looking for Grob Twin Astir Gear Retract Mechanism AJM Soaring 0 August 18th 09 05:03 AM
Fowler Flap Mechanism Dick Home Built 9 September 6th 06 06:05 PM
protecting sliding mechanism Ernest Christley Home Built 11 May 14th 05 05:03 AM
Anti-collision mechanism Ramapriya Piloting 42 January 5th 05 03:17 PM
