Post Curing Composites
Old January 8th 19, 09:43 PM posted to rec.aviation.soaring
Bret Hess
Default Post Curing Composites
Here's a temperature controller and probe for $30, and a version of the same for $15 if you can scrounge up your own cords:
https://smile.amazon.com/Inkbird-Ele...ure+controller
https://smile.amazon.com/gp/slredire...getName=sp_atf
Old January 8th 19, 09:45 PM posted to rec.aviation.soaring
Bret Hess
Jim Marske's advice is to limit the T rise to about 1 deg F per minute, so I interpret that as every 5 min or so raise the temperature by 5 degrees.
Old January 12th 19, 11:19 AM posted to rec.aviation.soaring
Guy Palmer
of the
sa=
https://smile.amazon.com/Inkbird-Ele...c-Temperature-
Germination-Control=
ling/dp/B01486LZ50/ref=3Dsr_1_4?
ie=3DUTF8&qid=3D1546983554&sr=3D8-4&keyword=
s=3Dinkbird+temperature+controller
https://smile.amazon.com/gp/slredire...rect.html/ref=
3Dpa_sp_atf=
_aps_sr_pg1_2?
ie=3DUTF8&adId=3DA02927671UI46I5AKTV1Y&url=3Dhttps %3A%
2F%2Fsm=
ile.amazon.com%2FInkbird-All-Purpose-Temperature-Controller-
ITC-1000%2Fdp%2=
FB00OXPE8U6%2Fref%3Dsr_1_2_sspa%3Fie%3DUTF8%26qid %3
D1546983554%26sr%3D8-2-s=
pons%26keywords%3Dinkbird%2Btemperature%2Bcontrol ler%26
psc%3D1&qualifier=3D=
1546983553&id=3D6639836400413390&widgetName=3Dsp_ atf
This is the temperature controller I use for £7.42 inc postage! Works
very well:
AC 90V-250V MH1210W Digital Temperature Controller screen H2M6
can be found at:
https://www.ebay.co.uk/itm/AC-90V-250V-MH1210W-Digital-
Temperature-Controller-screen-H2M6/253816032413?
epid=1869137394&hash=item3b189d4c9d:g:HhsAAOSwRiNb dA4R
Questions on UV curing polyester resins. Fred the Red Shirt Home Built 4 March 21st 10 04:07 AM
Questions on UV curing polyester resins. Fred the Red Shirt Home Built 0 March 20th 10 07:23 PM
heater control for curing oven [email protected] Home Built 27 October 1st 05 07:03 PM
composites propeller Philippe Home Built 2 August 4th 04 10:45 AM
composites vs. aluminum John C Home Built 23 May 7th 04 04:31 AM
