Herb, I know you, FWIW......
I have assembled many gliders over the decades...... At least once a season, clean fuselage pins and lube....same for spar pins and bushings....... A "slightly smaller" alignment pin (usually concentric, no real need in 99.9% of times for cam type), helps for first main pin alignment. Clean pins and sorta decent lube is about all that is needed....... |
Alignment tool for spar pins | soartech[_2_] | Soaring | 5 | September 6th 12 05:39 PM |
Make yourself known by the market - Powerful marketing tool: | MarketingTool | Aviation Marketplace | 0 | December 13th 04 03:48 AM |
INS Alignment at Sea | Gary Watson | Naval Aviation | 5 | November 9th 03 05:14 PM |
INS Alignment at Sea | Larry | Naval Aviation | 28 | November 5th 03 12:58 PM |
Seneca De-Ice Brush Alignment Tool | John | Owning | 0 | September 9th 03 11:03 PM |
