On Monday, January 14, 2019 at 5:53:17 PM UTC-8, Charles Longley wrote:
There’s no such thing as an informational 337. A 337 is a 337. There’s several ways to get approved data. Not sure you guys understand the process. Charlie, the FAA has unfortunately chosen to use the 337 form to inform them of ADS-B installations, causing much confusion and consternation in the mechanic community. They have asked for these forms to go directly to OK City and not to the local FSDO. Please refer to AFS-360_2016-03-02 http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgPolicy.nsf/0/1fdea629cd029a7c86257f7900601653/$FILE/AFS-360_2016-03-02.pdf Yes, Darryl Ramm is our resident ADS-B expert. He has spent many hours working on the behalf of SSA and the US gliding community helping navigate the federal maze. Thanks, Craig Funston |
Craig sorry you don’t understand the FAA form 337 either.
Perhaps I should do a primer on here? Charlie |
As an FYI that memorandum is what I used to put the Stratus Transponder in 17Z last year.
Here’s some good reading-
https://www.faa.gov/training_testing...-g-8082-19.pdf and https://www.ecfr.gov/cgi-bin/text-id...117.b&rgn=div9 |
On Monday, January 14, 2019 at 8:45:35 PM UTC-8, Charles Longley wrote:
Here’s some good reading- https://www.faa.gov/training_testing...-g-8082-19.pdf and https://www.ecfr.gov/cgi-bin/text-id...117.b&rgn=div9 Not sure what you point really is. An A&P wishing to do an ADS-B Out install in a type certified glider has to just follow AFS-360. They just have to do the minimum of what is described there. As long as the installation is a minor alteration. And In almost all cases in gliders it hopefully is. An A&P can do whatever else they believe they need to do to comply with regulations if they determine an install is a major alteration and needs further approval. But that can quickly create problems, starting with there is no STC for any install of any transponder in any glider. And the TN70 STC is also not a STC with any gliders on the AML... it's used purely for establishing the pairing of the TT22 and TN70 is approved as required by AFS-360. There are other options than a STC for approval but that should not .be required. A recent thing I got involved with at the request of Pereguine, the STC holder for the TN70 STC, was to help an FAA DAR out with understand the paperwork/regulations for installation of a TT22+TN70, in a vintage power aircraft with no engine driven system, that FAA DAR was perfectly OK with everything I have basically represented on r.a.s., as was his FSDO. So I am pretty comfortable I have a good enough handle on this and how easy a TN70 install and it's paperwork should be in a typical type certified glider. If you don't like the associated 337 in this process being called an "advisory 337", then hey you can call it whatever you want. But that's the language I've been using to try to make it clear the STC involved here is not being used as the basis for an installation approval.... and to try to avoid things like folks approaching a FSDO and assuming these are necessarily major alterations and the STC is going to be the the basis for that major alteration.... the poor FSDO folks can then start assuming it is because the folks talking to them are saying it is. Doing this has caused pain for some type certified glider owners trying to get 2020 Compliant ADS-B out installs happening, and I am tying to help other avoid those mistakes. And the offer is there for anybody looking to do an TN70 install I can help talk them and/or their A&P thought this if they need to, but AFS-360 is hopefully clear enough. I was happy recently when one of the busiest glider A&P IA's I had helped understanding this stuff helped walk another glider repair shop though the process. Happy that the word is getting out here, and more ADS-B Out install are happening, which is great for safety for folks in busy airspace. |
Darryl I agree with you that you can use a pairing that has been approved by a STC, TC or ATC on another aircraft for approval basis on an aircraft that is not on an AML per the MOU. I used the MOU to put a Stratus transponder in a Pawnee that isn’t on the AML. What I don’t agree with is the term “informational 337.”
If you review the two documents I put a link up for you’ll see that there is several avenues for finding approved data. As an IA I can’t approve data. What I can do is determine if data is approved by someone else. (STC, DER, 43.13, MOU, etc) I then sign a 337 to attest to that fact. The 337 then gets sent to the nice folks at FAA registration. Where it gets put in the aircrafts records and pretty much never sees the light of day until the airplane crashes or someone buys it. My ASI is typically never involved unless I have a question. Years ago (before I became an IA) they had to approve every 337 but they got to busy with the airlines. The onus is now on the lowly IA. I hope this makes my position clear. |
Would it qualify for hazardous duty pay? | Byker | Aviation Photos | 0 | September 1st 15 03:42 AM |
Sustainers and Self-Launchers- How often and for how long do you runyour motors (after launch)? | son_of_flubber | Soaring | 5 | April 21st 14 06:56 PM |
FAR 61.58 regarding HpH 304SJ,Jonker JS1-CJT, et al jet sustainers | [email protected] | Soaring | 2 | May 23rd 13 04:52 PM |
73 old planes that qualify for Light-sport | [email protected] | Piloting | 1 | September 14th 10 12:35 AM |
Don't Know If It Would Qualify... | Jay Beckman | Home Built | 4 | March 30th 04 07:17 AM |
