Nazi attempt to match the B-17
Old August 17th 04, 08:43 PM
B2431
Default Nazi attempt to match the B-17
During WW2 the Nazis were so impressed by the B-17 they designed their own
version. I think they only built 2. If memory serves it was called the Ou812.
The only known picture of it flying has for some reason shown up on a military
humour site.
http://www.strategypage.com/humor/ar...ruttan_b17.asp
Dan, U.S. Air Force, retired
Old August 17th 04, 08:53 PM
Jukka O. Kauppinen
It's not the April 1st, wink wink.
jok
humour site.
Old August 17th 04, 08:58 PM
OXMORON1
Part of Dan's message was the name proposed for the "German B-17"
That is no worse than having "Unzip" as a tactical callsign for a month or so.
Rick
Old August 17th 04, 08:59 PM
Kevin Brooks
"B2431" wrote in message
Ou812.
military
humour site.
You are gonna be sorry you did this when someday in the future our resident
Germany-did-everything-first-and-better clown tosses this back as "proof"
that the Nazis were really ahead of the power curve when it comes to using
canards...
Brooks
Old August 17th 04, 09:40 PM
B2431
Date: 8/17/2004 2:59 PM Central Daylight Time
Message-id:
Ou812.
military
humour site.
canards...
Brooks
Not really, I had planned on making an observation that I was surprised he
hadn't provided this proof earlier. That would have been a cheap shot g
Old August 18th 04, 12:36 AM
Richard Brooks
their own version. I think they only built 2. If memory serves it was
called the Ou812.
Try Kg200 DL+XC fin No.124585 originally "Wulf Hound" of the 303rd Bomb
Group at Molesworth, force landed December 1942!
Richard.
Old August 18th 04, 08:36 AM
Eunometic
"Kevin Brooks" wrote in message ...
Ou812.
military humour site.
canards...
Brooks
I can't resist.
This Messerschmitt P.1011 "Ente" proposal is a clear canard designe:
http://www.luft46.com/mess/meente.html
"This was another variation of the P.1110 design. The design was of a
"duck" (Ente) configuration, that is, small wings (or canards) in
front with the larger wing to the rear. This was felt would allow good
pitch and lateral stability for low-speed flight characteristics. "
So clearly Messerschmitt were aware of the advantages a canard
offered.
Also these two Henschell designes the Hs P.75 and Hs P.87
http://www.luft46.com/henschel/henschel.html
It is interesting why the word "canard" is used: perhaps because the
leading winglets are "misleading". The Germans were using "Ente"
which is their word for "Duck" and the French word "canard" of course
means "duck".
This is the Google dictionary Definition:
canard:
An unfounded or false, deliberately misleading story.
A short winglike control surface projecting from the fuselage of an
aircraft, such as a space shuttle, mounted forward of the main wing
and serving as a horizontal stabilizer.
An aircraft whose horizontal stabilizing surfaces are forward of the
main wing.
[French, duck, canard, probably from the phrase vendre un canard à
moitié, to half-sell a duck, to swindle, from Old French quanart,
duck, from caner, to cackle, of imitative origin.]
Old August 18th 04, 06:09 PM
Kevin Brooks
"Eunometic" wrote in message
om...
own
Ou812.
resident
"proof"
using
canards...
Brooks
I can't resist.
offered.
Wow. And only what, forty years or so after the Wright bothers used a
canard?
"So many pilots forget, or never knew, that the earliest heavier-than-air
birds pretty much all flew beak-first. But check out any photo of the
Wrights' earliest machines and some built by their followers ... the
canard."
www.avweb.com/news/newacft/182746-1.html
Brooks
means "duck".
canard:
main wing.
Old August 18th 04, 06:44 PM
Robert Briggs
offered.
canard?
Rats! You beat me to it ...
50% of NAZI oil was supplied from US Grantland Military Aviation 106 January 18th 14 07:58 PM
Assassination Attempt on Musharraf Fails Dav1936531 Military Aviation 0 December 16th 03 05:31 AM
"Bush - Nazi Dealings Continued Until 1951" - Federal Documents B2431 Military Aviation 0 November 13th 03 04:26 AM
Scaled Composites builds plane for solo nonstop globe circumnavigation attempt David O Home Built 23 October 30th 03 11:15 AM
