Early Twin-2’s had aerodynamic elevator trim (trim tab), but later models went with spring trim. The jumping back reminds me of a slipping trim bar where the desired trim position doesn’t hold its setting. Recommend you pull the front seat and see if there is any slipping of the desired trim position. Can’t remember exactly what the trim setup is on the Twin Two, but a look under the seat will reveal any malfunction.
Hope this helps, JJ |
Normal bias configuration. Springs attached pushrod.
Front spring fully fwd on pushrod, rear spring 110 mm from the rear end of pushrod t 18:02 11 February 2019, wrote: Early Twin-2=E2=80=99s had aerodynamic elevator trim (trim tab), but later = models went with spring trim. The jumping back reminds me of a slipping tri= m bar where the desired trim position doesn=E2=80=99t hold its setting. Rec= ommend you pull the front seat and see if there is any slipping of the desi= red trim position. Can=E2=80=99t remember exactly what the trim setup is on= the Twin Two, but a look under the seat will reveal any malfunction. Hope this helps, JJ |
Maybe it's really a 2-33 in disguise...
66 |
Grob SB's | Alan Garside | Soaring | 14 | January 19th 19 02:26 PM |
Grob Value? | Charlie Papa[_2_] | Soaring | 5 | March 19th 12 06:27 PM |
Grob Value? | Frank Whiteley | Soaring | 0 | February 7th 12 04:43 AM |
Grob | Bob O'Rilley | Soaring | 3 | April 29th 05 07:22 PM |
GROB 102 | Vorsanger1 | Soaring | 4 | July 11th 03 11:34 PM |
