...and another question: why do so many YouTube videos show the
glider pilot on tow NOT holding the release knob? In fact it's hard to find a video where the glider pilot does hold the release throughout the tow! In a flapped machine that might require a flap change during the initial stages of the launch it's understandable, perhaps for a few seconds, but even after the flap change no one ever seems to hold the release knob. In the dim and distant past when I was taught aerotows they was certain to be very loud angry noises from the rear seat if one let go of the yellow knob. Has something changed in the instructor manual? Dave Walsh |
On Thu, 21 Feb 2019 14:02:56 +0000, Dave Walsh wrote:
..and another question: why do so many YouTube videos show the glider pilot on tow NOT holding the release knob? In fact it's hard to find a video where the glider pilot does hold the release throughout the tow! In a flapped machine that might require a flap change during the initial stages of the launch it's understandable, perhaps for a few seconds, but even after the flap change no one ever seems to hold the release knob. In the dim and distant past when I was taught aerotows they was certain to be very loud angry noises from the rear seat if one let go of the yellow knob. Has something changed in the instructor manual? Dave Walsh Agreed. Two seaters or single seaters and winching or aerotowing, when I'm in control my left hand is holding the yellow knob from 'taking up slack' to release. That's what I was taught and that's what I do. No reason to do otherwise in our club two-seaters and Juniors or my Libelle. My only exception has been when moving flaps from negative to zero when the ailerons bite in an ASW-20 on aero tow, but even then its hand back on yellow knob right away. -- Martin | martin at Gregorie | gregorie dot org |
I have a long talk with my students about doing nothing else during the first 1000' of the tow except focus on the tow plane, and emergency options. Then, during the first 1000' I ask them to toggle the radio. Then I YELL at them for doing it, and we have another long discussion during post flight about killing tow pilots. I repeat this until they do nothing except focus on the tow plane, and emergence options.
Also, I disagree with holding the release during tow. Turbulence can cause a premature termination of the tow if you are holding the release. Boggs |
At 14:30 21 February 2019, Martin Gregorie wrote:
On Thu, 21 Feb 2019 14:02:56 +0000, Dave Walsh wrote: ..and another question: why do so many YouTube videos show the glider pilot on tow NOT holding the release knob? In fact it's hard to find a video where the glider pilot does hold the release throughout the tow! In a flapped machine that might require a flap change during the initial stages of the launch it's understandable, perhaps for a few seconds, but even after the flap change no one ever seems to hold the release knob. In the dim and distant past when I was taught aerotows they was certain to be very loud angry noises from the rear seat if one let go of the yellow knob. Has something changed in the instructor manual? Dave Walsh Agreed. Two seaters or single seaters and winching or aerotowing, when I'm in control my left hand is holding the yellow knob from 'taking up slack' to release. That's what I was taught and that's what I do. No reason to do otherwise in our club two-seaters and Juniors or my Libelle. My only exception has been when moving flaps from negative to zero when the ailerons bite in an ASW-20 on aero tow, but even then its hand back on yellow knob right away. -- Martin | martin at you need an extended release cable or a piece of line on it so you can hook it over your hand. Can't change flap setting otherwise,and you can get in a position with the stick hard over where you can't get to the handle in discus/ventus type layout. Gregorie | gregorie dot org |
On Thu, 21 Feb 2019 16:11:22 +0000, Jonathon May wrote:
you need an extended release cable or a piece of line on it so you can hook it over your hand. Fair comment. My Libelle has a fairly long release cable so my hand is resting on my leg with fingers loosely round the knob. Cable is slack and hand supported by leg. Juniors are also good: arm supported on the cockpit rail with fingers on top of, but not round, the T-bar release. Needs little more than closing fingers to pull the release. -- Martin | martin at Gregorie | gregorie dot org |
I do NOT do or teach keeping a hand on the release during tow. In anything........
Never. In several glass ships I fly (mostly AS.....) we may have a loop of rope on the release to make a bigger target.....yes, I stated that before. |
I don't hang onto the release during tow.
I never taught to hang onto the release during tow. In glass ships, we have a looped rope tied to the release and laid across our thigh to make a quick release easier. Why no holding the release? Many things..... A sneeze can pull it Turbulence can pull it Something sudden (like a bee/wasp flying around) can pull it You do your thing, I'll do mine. ;-) |
On 2/21/2019 10:13 AM, Charlie M. (UH & 002 owner/pilot) wrote:
I don't hang onto the release during tow. I never taught to hang onto the release during tow. I wasn't taught to hold the release during tow, and I don't teach that to my students. You are more far likely to cause an accident that way (through PTT) than to ever prevent one. That said! Every glider pilot should give serious thought to the position of the left hand during (especially) early tow. Depending on your glider and its cockpit ergonomics, the answer will not always be the same. Myself, particularly in 2-place gliders, I often have my closed fist firmly behind the spoiler handle. (Never with fingers wrapped around it, because that could also lead to a PTT) This ensure that the spoilers can't accidentally open, while at the same time anchoring my hand near the release so that I can instantly grab it if necessary. YMMV By all means, let's do whatever it takes to keep our tow pilots alive! Vaughn --- This email has been checked for viruses by AVG. https://www.avg.com |
On Thursday, February 21, 2019 at 10:13:06 AM UTC-5, Charlie M. wrote:
I don't hang onto the release during tow. I never taught to hang onto the release during tow. In glass ships, we have a looped rope tied to the release and laid across our thigh to make a quick release easier. I totally agree with this and use the looped cord! My release "knob" is a small diameter sphere and it too easily has slipped from my grasp. Thanks, Charlie for pointing out the best course of action here. |
On Thursday, February 21, 2019 at 5:13:06 PM UTC+2, Charlie M. (UH & 002 owner/pilot) wrote:
I don't hang onto the release during tow. I never taught to hang onto the release during tow. In glass ships, we have a looped rope tied to the release and laid across our thigh to make a quick release easier. Why no holding the release? Many things..... A sneeze can pull it Turbulence can pull it Something sudden (like a bee/wasp flying around) can pull it You do your thing, I'll do mine. ;-) Exactly, keeping your hand on release greatly increases risk for inadverted release which on many airfields leads to accident when done at low altitude. Only time I keep my hand on the release is beginning of take of roll, for aborting the tow if wingtip catches ground: https://youtu.be/WduEiQqLWJU |
Fatal glider/tow plane accident, France | Sean F2 | Soaring | 44 | May 22nd 12 07:11 PM |
Tow plane / glider accident, Adrian MI? | Sean Fidler | Soaring | 5 | August 23rd 11 03:39 PM |
F-35: Second test plane powers up, but first plane stays grounded | Mike[_7_] | Naval Aviation | 1 | October 29th 07 09:40 PM |
Float Plane Accident | Mike Schumann | Piloting | 8 | October 31st 06 05:15 PM |
Walmart heir dies in light plane accident | Allen | Piloting | 1 | June 30th 05 11:01 AM |
