LX Nav Varios, Bluetooth & XCSoar
Old February 21st 19, 11:31 PM posted to rec.aviation.soaring
Default LX Nav Varios, Bluetooth & XCSoar
Questions have been asked about both LXNav and LX Navigation devices. Most recently the questions have been in relation to the S10 and S100 which are both LXNav products.
Have you tried using the XCSoar LXNav driver with an LX Navigation device? It works.
Nick.
On Friday, February 22, 2019 at 8:58:42 AM UTC+10:30, SoaringXCellence wrote:
On Thursday, February 21, 2019 at 12:29:54 PM UTC-8, wrote:
XCSoar does have a driver for LXNav, although possibly not quite as functional as the C302 driver.
http://max.kellermann.name/projects/xcsoar/vendor.html
Nick.
On Friday, February 22, 2019 at 2:22:29 AM UTC+10:30, Dan Marotta wrote:
XCSoar may or may not have a driver specific to that device.Â* I use a
CAI-302 driver built in to XCSoar to drive my ClearNav XC vario. They
use the same protocol where it counts.Â* Can't say about the LXNAV.
On 2/20/2019 7:22 PM, Richard Pfiffner wrote:
On Wednesday, February 20, 2019 at 12:00:38 PM UTC-8, SAM wrote:
Thank you Paul, David & Jim!
The LXNAV S10 and S100 has internal Bluetooth.
http://www.craggyaero.com/lxnav_vario.htm
Richard
www.craggyaero.com
Dan, 5J
Remember we're talking about NX NAVIGATION, not LXNav, two different protocols. LX Navigation has not been helpful to the XCSoar team and so doen't get much in the way of attention from the developers. I just checked the list of device drivers in XCSoar and there is nothing with the LX Navigation device listed.
On the other hand, every LXNav device I've used works with the software.
Mike B.
Old February 21st 19, 11:40 PM posted to rec.aviation.soaring
JS[_5_]
Nick.
Good to hear, Nick.
Suspected that.
Old February 22nd 19, 10:17 AM posted to rec.aviation.soaring
krasw
Nick.
Richard
www.craggyaero.com
Dan, 5J
What a nice blacklist you have there.
Old February 22nd 19, 10:37 AM posted to rec.aviation.soaring
Roy Garden
I'm running an Eos which (sometimes) speaks to my Samsung S9 running
XC soar.
I use XC soar as a back up to the Zeus and it's handy for getting a
heading up display which the Zeus currently doesn't do. (windy here)
I get mount problems with Bluetooth if I let the phone pair with the Bose
Speaker in the glider before it mounts the Eos output.
Switching the speaker off, re-booting the phone.
Mount the Eos stack then the Bose stack seems to work ok.
Bluetooth is a bit iffy on multiple device connections.
YMMV, or you may be confusing the stack less by not having in flight
entertainment throwing a spanner in the works.
Old February 23rd 19, 01:26 AM posted to rec.aviation.soaring
WaltWX[_2_]
I'm the one JS was referring to when the LX NAV S100 paired and worked with my Nokia 8 Android phone and LK8000 software. It works beautifully... but. You have to spend some time at the desk testing all this and making sure the operator (me) understands how to pair on the Nokia 8 and get it working with my Flight Software LK8000. Once understood, it all works just fine.
Last summer at the Standard Nationals I used my Nokia 8 and LK8000 to fly for 100 full days with no problem. Just remember to test the connection and demonstrate it's working well before getting into the cockpit. For this contest I used a Nano and it's BT with my Nokia 8 and LK8000.
Old February 23rd 19, 01:29 AM posted to rec.aviation.soaring
WaltWX[_2_]
Power was from a "Juice" 5V battery in the side pocket of my D2a.
I'm convinced that connecting with BT is reliable enough these days. It's a lot simpler than a wired connection with IOIO-OTG boxes for Android. It even works with my Vertica V2.
Walt Rogers
Old February 23rd 19, 01:37 AM posted to rec.aviation.soaring
WaltWX[_2_]
I'm the one JS was referring to when the LX NAV S100 paired and worked with my Nokia 8 Android phone and LK8000 software. It works beautifully... but. You have to spend some time at the desk testing all this and making sure the operator (me) understands how to pair on the Nokia 8 and get it working with my Flight Software LK8000. Once understood, it all works just fine..
Walt Rogers
Make that 10 days! I don't have the stamina to fly 100 days...
Old February 23rd 19, 09:38 AM posted to rec.aviation.soaring
Charlie Quebec
I’m using a Borgelt Bluetooth blade, which combines FLARM and Vario data and sends them combined bluetooth, with Lenovo TAB 7 XCSoar Works very well with a minimum of configuration.
The Borgelt blade can handle up to 3 data sources, combine them and forward on Bluetooth. I carry a stand-alone Sony Z3 as a fully independent back up..
Mike pre configures the devices for the blade when you order.
Old February 23rd 19, 02:35 PM posted to rec.aviation.soaring
Paul Remde
Hi,
The K6BtMux can also be used to combine FLARM and vario data and send it over Bluetooth.
http://cumulus-soaring.com/k6.htm#K6BtMux
But the K6BtMux is not required when using an LXNAV S100 or similar. The S100 receives the FLARM data and forwards it to the display over Bluetooth, along with vario and airspeed and other data.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
_____________________________________
Old February 24th 19, 05:32 AM posted to rec.aviation.soaring
As a scorer Walt, It worked well, I just wished you didnt turn in 3 logs every day
Varios For Sale [email protected] Soaring 1 December 14th 13 05:04 PM
Talking Varios glider[_2_] Soaring 10 May 19th 10 05:35 PM
Varios [email protected] Soaring 9 January 5th 09 08:51 PM
Opinions on Varios Bruce Soaring 8 March 1st 05 03:57 PM
Super Varios John Scott Soaring 1 February 25th 05 02:14 AM
