high tow vs low tow
Old February 25th 19, 03:09 PM posted to rec.aviation.soaring
Cookie
Default high tow vs low tow
You make some very good arguments in favor of low tow....Does that mean you win the overall argument?...I dunno?..most glider ops in USA still use high tow. ( guess they have their reasons?)
My concern about all of this tow position stuff is this....
Does using low tow simply mask the "symptom", the larger problem of not-so-proficient glider pilots on tow?
In the incidents I've seen or heard about... It was always the glider pilots lack of skill, or inattention, which caused the problem...the root cause was the glider pilot, not the tow position...
That being said....If I were a tow pilot (I'm not)...and I were towing somebody in a glider, who I had no idea of his ability, experience, etc....I would be much happier if he flew low position...
Cookie
On Monday, February 25, 2019 at 8:54:59 AM UTC-5, wrote:
On Sunday, February 24, 2019 at 10:27:25 PM UTC-5, Steve Koerner wrote:
As a US pilot, I've flown low tow a few times but mostly just high tow as that is the convention here. I'm wondering what all of the trade-offs are by the two methods? Might it be time to reconsider this?
As pointed out on another thread, low tow would seem to be safer against the problem of glider kiting up to overpower the tugs up elevator. I'm wondering if it's ever possible for a low tow glider to go too low and overpower the tugs down elevator?
Also, how does low tow compare in the other common dangerous towing situation wherein the tug flys too slow for a highly ballasted glider? My own experience with a seriously too slow tug is that I end up falling to low tow whether I like it or not.
Has anyone done a lot of tows both ways and have reasons as to which way is better?
I've done something over 20,000 flights at both ends, 12k or so at the back and something over 8k at the front.
Properly flown, as high as possible without being in the wake, the glider is very closely aligned with the thrust line of the tug and has almost no effect on trim.
Flown too low, the glider pilot can have a poorer view of the horizon.
Being a bit high is obvious.
The rope wrapping hazard happens if there is slack caused by a fairly quick, big descent. I have never witnessed this happening in operations I have been involved with.
We tested the "pull the tail down" risk and could not accomplish it. The angles don't work. In trying this we had our Cub down to below 45 MPH with the glider behind hanging low. It was more stable with the glider on at that speed.
My experience is that low is easier to teach and do at the beginning because the view is a bit better and the wake is not anywhere near as much of an issue.
Get slack- Move to the side to take it out, just like high(normal?) tow.
Rope will hit the glider. Could happen if way too low when tug releases it. If the glider is in proper position when releasing the rope doesn't go much up or down. If the tug releases the rope drops below and behind and probably, but not surely back releases.
Rope will wrap around the glider- I have yet to figure out how a rope can go upwind against a 60 mph headwind.
The rope will scratch my belly when using a CG hook. No scratches on my ships in 40+ years of low tow.
Most training, from my experience, teaches pilots to fly too low.
If one wants to get better at this, a couple dual flights with an experienced instructor can be useful.
Also note that many tugs have mirrors set up such that the tow pilot can't see the glider in low tow.
Tell your tow pilot what you plan to do. Trim settings are different so he or she may want to adjust.
To finish. Both options can be done safely. I believe low tow is more easily done safely.
Flame suit on.
UH
Old February 25th 19, 04:45 PM posted to rec.aviation.soaring
Cookie
Not trying to win anything but if I can clear up some misinformation it could be a good thing. Knowledge is important and commonly limited.
Low tow may mask proficiency issues a bit simply because it is a bit easier to do- my experience.
I completely agree that proficiency is a major concern. How many things do we do only 20 or 30 times a year that can kill somebody if we do it wrong?
The point Chris R made about rope length is also very important.Short ropes make position errors more critical.
UH
Old February 25th 19, 04:59 PM posted to rec.aviation.soaring
Tango Eight
Cookie
UH
Jus' for clarity, the only bits I quoted Chris on are in quotes. I get the blame for everything else in that post.
T8
Apollo 13 pix last batch includes .par2s - "Apollo 13 Saturn V with boilerplate spacecraft during transfer move from High Bay 2 to High Bay 3 ap13-KSC-69P-684.jpg" yEnc (1/1) [109K] hielan' laddie Aviation Photos 0 September 12th 08 03:17 PM
Apollo 13 pix last batch includes .par2s - "Apollo 13 Saturn V with boilerplate spacecraft during transfer move from High Bay 2 to High Bay 3 ap13-KSC-69P-683.jpg" yEnc (1/1) [121K] hielan' laddie Aviation Photos 0 September 12th 08 03:17 PM
Apollo 13 pix last batch includes .par2s - "Apollo 13 Saturn V with boilerplate spacecraft during transfer move from High Bay 2 to High Bay 3 690808 ap13-KSC-69P-684.jpg" yEnc (1/1) [137K] hielan' laddie Aviation Photos 0 September 12th 08 03:17 PM
Apollo 13 pix last batch includes .par2s - "Apollo 13 Saturn V with boilerplate spacecraft during transfer move from High Bay 2 to High Bay 3 690808 ap13-KSC-69P-683.jpg" yEnc (1/1) [155K] hielan' laddie Aviation Photos 0 September 12th 08 03:17 PM
IVO pireps wanted.. high performance/high speed... Dave S Home Built 8 June 2nd 04 04:12 PM
