On Friday, 8 March 2019 15:26:18 UTC, Paul Kaye wrote:
Many years ago the late Chris Rollins, while CFI at Booker GC in the UK, did some controlled testing of glider "kiting" behind tugs. He posted something about it on URAS he https://groups.google.com/forum/#!ms...g/Uz0Ga95XVCsJ It makes interesting and sobering reading. Some excerpts: "Third test: Terrier Tow-Plane, K 8b on C of G hook. I pitched the glider about 25 degrees nose up. The glider continued to pitch up fairly rapidly (as at the start of a winch launch) and substantial forward movement of the stick only slightly slowed the rate of pitch. The glider achieved about 45 degrees nose up, speed increased rapidly from 55 knots to about 75 knots and the glider was pulled back towards level flight (again as at the top of a winch launch). I released at that point. The entire sequence of events occupied a VERY short period of time (subsequently measured as 2 - 3 seconds). The Tow Pilot reported a marked deceleration and start of pitching down which he attempted to contain by moving the stick back; this was followed immediately by a very rapid pitch down accompanied by significant negative “G”. The tow-plane finished up about 70 degrees nose down and took about 400 feet to recover to level flight. We both found the experience alarming, even undertaken deliberately at 4000 feet. Our conclusion was that the combination of the initial pitch down and the upward deflection of the elevator caused the horizontal stabilizer/elevator combination to stall and the abrupt removal of the down-force it provided caused the subsequent very rapid pitch-down and negative “G”. " "These tests were repeated a few years later with a PA18 – 180 as the tow-plane, Brian Spreckley flying it. The third test described above was repeated and photographed from a chase plane using a 35 mm motor drive camera on automatic (this took a frame every half second – video camcorders of small size were not readily available then). The photo sequence started with the glider in a slightly low normal tow position and starting to pitch up, the second frame has the glider about 30 degrees nose up and about 20 feet higher than previously in the third frame it is about 45 degrees nose up and has gained another 30 feet or so, the tow-plane is already starting to pitch down, in the fourth frame the glider is about 100 feet higher than its original position and the climb is starting to shallow, the tow-plane is about 50 degrees nose down, the final frame shows the tow-plane about 70 degrees nose down and the glider almost back in level flight , almost directly above it (that was about the point that I pulled the release). Sufficiently alarmed by events, Brian Spreckley had been trying to pull the release in the tow-plane earlier and found that it would not operate until my releasing at the glider end removed the tension from the rope. Subsequent tests on the ground showed that the Schweizer hook fitted to the tow-plane, whilst perfectly satisfactory under normal loads, was jammed solid by the frictional loads when subject to a pull of around 700 lbs with a slight upwards component – not something that a normal pre-flight check would reveal. " |
On Friday, March 8, 2019 at 9:39:11 AM UTC-6, Paul Kaye wrote:
On Friday, 8 March 2019 15:26:18 UTC, Paul Kaye wrote: Many years ago the late Chris Rollins, while CFI at Booker GC in the UK, did some controlled testing of glider "kiting" behind tugs. He posted something about it on URAS he https://groups.google.com/forum/#!ms...g/Uz0Ga95XVCsJ It makes interesting and sobering reading. Some excerpts: "Third test: Terrier Tow-Plane, K 8b on C of G hook. I pitched the glider about 25 degrees nose up. The glider continued to pitch up fairly rapidly (as at the start of a winch launch) and substantial forward movement of the stick only slightly slowed the rate of pitch. The glider achieved about 45 degrees nose up, speed increased rapidly from 55 knots to about 75 knots and the glider was pulled back towards level flight (again as at the top of a winch launch). I released at that point. The entire sequence of events occupied a VERY short period of time (subsequently measured as 2 - 3 seconds). The Tow Pilot reported a marked deceleration and start of pitching down which he attempted to contain by moving the stick back; this was followed immediately by a very rapid pitch down accompanied by significant negative “G”. The tow-plane finished up about 70 degrees nose down and took about 400 feet to recover to level flight. We both found the experience alarming, even undertaken deliberately at 4000 feet. Our conclusion was that the combination of the initial pitch down and the upward deflection of the elevator caused the horizontal stabilizer/elevator combination to stall and the abrupt removal of the down-force it provided caused the subsequent very rapid pitch-down and negative “G”. " "These tests were repeated a few years later with a PA18 – 180 as the tow-plane, Brian Spreckley flying it. The third test described above was repeated and photographed from a chase plane using a 35 mm motor drive camera on automatic (this took a frame every half second – video camcorders of small size were not readily available then). The photo sequence started with the glider in a slightly low normal tow position and starting to pitch up, the second frame has the glider about 30 degrees nose up and about 20 feet higher than previously in the third frame it is about 45 degrees nose up and has gained another 30 feet or so, the tow-plane is already starting to pitch down, in the fourth frame the glider is about 100 feet higher than its original position and the climb is starting to shallow, the tow-plane is about 50 degrees nose down, the final frame shows the tow-plane about 70 degrees nose down and the glider almost back in level flight , almost directly above it (that was about the point that I pulled the release). Sufficiently alarmed by events, Brian Spreckley had been trying to pull the release in the tow-plane earlier and found that it would not operate until my releasing at the glider end removed the tension from the rope. Subsequent tests on the ground showed that the Schweizer hook fitted to the tow-plane, whilst perfectly satisfactory under normal loads, was jammed solid by the frictional loads when subject to a pull of around 700 lbs with a slight upwards component – not something that a normal pre-flight check would reveal. " Thanks Paul, very instructive. Makes me wonder why that Schweizer tow-hook is still legal and widely used. |
On Friday, March 8, 2019 at 1:05:48 PM UTC-5, wrote:
On Friday, March 8, 2019 at 9:39:11 AM UTC-6, Paul Kaye wrote: On Friday, 8 March 2019 15:26:18 UTC, Paul Kaye wrote: Many years ago the late Chris Rollins, while CFI at Booker GC in the UK, did some controlled testing of glider "kiting" behind tugs. He posted something about it on URAS he https://groups.google.com/forum/#!ms...g/Uz0Ga95XVCsJ It makes interesting and sobering reading. Some excerpts: "Third test: Terrier Tow-Plane, K 8b on C of G hook. I pitched the glider about 25 degrees nose up. The glider continued to pitch up fairly rapidly (as at the start of a winch launch) and substantial forward movement of the stick only slightly slowed the rate of pitch. The glider achieved about 45 degrees nose up, speed increased rapidly from 55 knots to about 75 knots and the glider was pulled back towards level flight (again as at the top of a winch launch). I released at that point. The entire sequence of events occupied a VERY short period of time (subsequently measured as 2 - 3 seconds). The Tow Pilot reported a marked deceleration and start of pitching down which he attempted to contain by moving the stick back; this was followed immediately by a very rapid pitch down accompanied by significant negative “G”. The tow-plane finished up about 70 degrees nose down and took about 400 feet to recover to level flight. We both found the experience alarming, even undertaken deliberately at 4000 feet. Our conclusion was that the combination of the initial pitch down and the upward deflection of the elevator caused the horizontal stabilizer/elevator combination to stall and the abrupt removal of the down-force it provided caused the subsequent very rapid pitch-down and negative “G”. " "These tests were repeated a few years later with a PA18 – 180 as the tow-plane, Brian Spreckley flying it. The third test described above was repeated and photographed from a chase plane using a 35 mm motor drive camera on automatic (this took a frame every half second – video camcorders of small size were not readily available then). The photo sequence started with the glider in a slightly low normal tow position and starting to pitch up, the second frame has the glider about 30 degrees nose up and about 20 feet higher than previously in the third frame it is about 45 degrees nose up and has gained another 30 feet or so, the tow-plane is already starting to pitch down, in the fourth frame the glider is about 100 feet higher than its original position and the climb is starting to shallow, the tow-plane is about 50 degrees nose down, the final frame shows the tow-plane about 70 degrees nose down and the glider almost back in level flight , almost directly above it (that was about the point that I pulled the release). Sufficiently alarmed by events, Brian Spreckley had been trying to pull the release in the tow-plane earlier and found that it would not operate until my releasing at the glider end removed the tension from the rope. Subsequent tests on the ground showed that the Schweizer hook fitted to the tow-plane, whilst perfectly satisfactory under normal loads, was jammed solid by the frictional loads when subject to a pull of around 700 lbs with a slight upwards component – not something that a normal pre-flight check would reveal. " Thanks Paul, very instructive. Makes me wonder why that Schweizer tow-hook is still legal and widely used. I do not wonder why, I know why. It is largely a "we've always done it this way" attitude and a financial consideration. The cost of retrofitting a tow plane with a Tost system and a release handle up where the tow pilot can reach it in the seated, upright position WITH adequate mechanical advantage to effect a release is a few thousand dollars, not something some are willing to spend. The FAA in their own Advisory Circular, date 3/3/08 AC No 43.13-2b, Page 76, Par 808 states as follows: “When the glider under tow operates above a certain angle to the tow plane, the ring may slide upwards on the hook, causing excessive load on the hook and difficulty in releasing the tow rope ring.” The Soaring Society of America thru their Soaring Safety Foundation, Tow Pilot Training course additionally acknowledges IN RED as follows: “If at any time the nose of the tow plane is pulled to a dangerously high or low pitch attitude, - PULL THE RELEASE!” It goes on to say: “Depending on the installation of the tow hitch, it may be possible for the release mechanism to become jammed due to the excessively high position of the glider, (American style hook).” What they mean by “depending on installation of the tow hitch,” is that if you install it upright instead of inverted it may be possible for the release mechanism to become jammed due to the excessively high position of the glider. The SSA and the FAA are well aware of this situation and have been for many, many years and yet the system remains approved. I can assure you that not all kiting incidents are slowly developing situations. I've been there at just above 300 feet when in the blink of an eye you find yourself nose down before you could even think of releasing. The gentleman who died in this tow plane incident was probably 100 feet below the level at which mine started. In both cases our tow ropes broke, the glider pilot didn't release. I had barely enough room to recover, he did not. Walt Connelly Former tow pilot 7000 tows |
On Saturday, March 9, 2019 at 8:24:04 AM UTC-5, wrote:
I can assure you that not all kiting incidents are slowly developing situations. I've been there at just above 300 feet when in the blink of an eye you find yourself nose down ***before you could even think of releasing***.. [emphasis added] Right. So after all the brouhaha and threats to write the FAA about our equipment, it turns out that in at least one of the events that got you goin', you say the hook/release doesn't matter because you didn't even have a chance to respond. Would you care to clarify? Btw, how long was your rope? T8 |
On Saturday, March 9, 2019 at 1:37:18 PM UTC-5, Tango Eight wrote:
On Saturday, March 9, 2019 at 8:24:04 AM UTC-5, wrote: I can assure you that not all kiting incidents are slowly developing situations. I've been there at just above 300 feet when in the blink of an eye you find yourself nose down ***before you could even think of releasing***. [emphasis added] Right. So after all the brouhaha and threats to write the FAA about our equipment, it turns out that in at least one of the events that got you goin', you say the hook/release doesn't matter because you didn't even have a chance to respond. Would you care to clarify? Btw, how long was your rope? T8 First of all I do not make threats, I make promises. "Our equipment?" If YOUR equipment is such that it could (and has) lead to the death of a tow pilot I have a right then to express my learned opinion, especially as one who has experience the situation. Where did I say the "hook/release doesn't matter?" THAT was YOUR characterization of my words. What I said was that "in the blink of an eye you find yourself nose down before you could even think of releasing." This point is important in that every report by the NTSB I have read seems to fault the tow pilot for not releasing early enough. The fact that these situation can and do occur in the wink of an eye does not dismiss the fact that the tow pilot should have a system that functions in the seconds after the occurance allowing for an unquestioned release and an opportunity to recover before impacting the ground. The Schweizer hook with a release down on the floor of the Pawnee as I have pointed out is well documented with regards to not functioning under the pressure exerted by a suddenly kiting glider. Any first year engineering student has heard the term "form follows function." The form of this system fails to function under the conditions in which it must function and therefore the form must be changed, reengineered or replaced. Any first year engineering student has heard the term "mechanical advantage.." The requirement for a 5-1 release handle ratio is obviously inadequate to overcome the pressures exerted on the Schweizer hook when the glider kites suddenly and yet this requirement seems to persist. The tow pilot who lost is life in the incident at Skyline I understand had a Tost system with a guillotine. I have been informed that even these systems can fail although I understand there is no pressure on the release. I have sent an email to the NTSB regarding this incident asking "where was the release?" IF it was down on the floor he may not have been able to grasp the handle. In short, every known design flaw in these systems needs to be recognized and redesigned. As for "how long was my rope?" I made my ropes longer than 200 feet, usually 220 to 230 so we could repair the ends and get a few more tows on the rope. I meticulously inspected the rope each morning and would do so throughout the day as opportunity permitted. The rest of the time one must count on the individual hooking up the glider to adequately inspect the rope for knots and weak areas. The rope in this incident would have been 200 feet or more. I would keep any rope shorter than 200 for tow outs on retrieves which were generally tows for highly experienced pilots. I took my responsibilities as a tow pilot very seriously. The incident in question at Skyline points out that even instructors can't be trusted to always do things right. Your comments indicate to me that you are not or never have been a tow pilot. Am I right? Walt Connelly Former Tow Pilot 7000 tows |
(…) I took my responsibilities as a tow pilot very seriously.
(…) Walt Connelly Former Tow Pilot 7000 tows You did, Walt. It was always a pleasure to be towed by you. I still have your voice recorded in one of my videos, responding on the radio to my self-announcement in the pattern for landing. I will always remember how you once taxied to my parking position, seeing my hesitation and checking if I needed a tow. Friendly and responsible. Thanks! |
On Sunday, March 10, 2019 at 9:48:10 AM UTC-4, wrote:
Your comments indicate to me that you are not or never have been a tow pilot. Am I right? I'm a tow pilot of modest experience (+/-500 tows, my club prefers me in the back seat of a glider on days I work). Nothing else to add at this time. T8 |
Fatal glider/tow plane accident, France | Sean F2 | Soaring | 44 | May 22nd 12 07:11 PM |
Tow plane / glider accident, Adrian MI? | Sean Fidler | Soaring | 5 | August 23rd 11 03:39 PM |
F-35: Second test plane powers up, but first plane stays grounded | Mike[_7_] | Naval Aviation | 1 | October 29th 07 09:40 PM |
Float Plane Accident | Mike Schumann | Piloting | 8 | October 31st 06 05:15 PM |
Walmart heir dies in light plane accident | Allen | Piloting | 1 | June 30th 05 11:01 AM |
