Replacing a multi-probe socket
Old March 11th 19, 04:56 PM posted to rec.aviation.soaring
Dan Marotta
Default Replacing a multi-probe socket
Not being a mechanical engineer, could anyone enlighten me as to why the
o-rings are installed internally in the socket rather than externally on
the probe?Â* In either case the o-rings are getting rubbed each
installation/removal cycle and it seems light lubrication, like the skin
oil from one's nose, would work nicely. That's how I lube the probe on
my Stemme.
And, BTW, the o-rings would be oh so much easier to replace...
On 3/10/2019 7:11 PM, JS wrote:
On Sunday, March 10, 2019 at 5:41:10 PM UTC-7, Darryl Ramm wrote:
Yep done the outer, dental pick tool, and a Delrin rod to seat the new O-ring in place. Done outside on the ramp at an airport, and yes lots of swearing...
There's a kit labeled "TE Probe" at home. Came with one of the 27s.
Also a spare UN socket which by now could need new O-rings.
The kit is like what you describe. Not thrilled about using it without better currency at swearing in German. Perhaps time to practice on the spare one.
For a replacement... Is there a difference in serviceability between type UN, UNG and SUN sockets?
This is for a friend's DG.
There's always the possibility that any leak is the probe itself. I've seen two triple probes and a standard TE probe that didn't seal, when other probes used in the same socket did.
Thanks,
Dan, 5J
Old March 11th 19, 05:15 PM posted to rec.aviation.soaring
my Stemme.
In ESA probes the UN sockets (eg for triple probes) have the O-rings in the socket and the ST sockets (eg for TE/Static double probes) have the O-rings on the aluminium probe fitting but those ones are more prone to fractures of the fitting on older probes - at the O-ring groove of course.
Proper Way to Insert Multi-Probe Dan Marotta Soaring 18 February 19th 18 01:31 AM
Prandtl multi probe receptacle used for TE only? Matt Herron Jr. Soaring 12 February 15th 18 08:32 PM
castellated socket Stuart & Kathryn Fields Home Built 1 June 3rd 08 12:37 PM
Replacing innertubes without replacing tires? Ben Jackson Owning 28 November 6th 06 04:54 PM
Multi - probe KP Soaring 1 March 7th 05 06:03 PM
