On Monday, March 11, 2019 at 4:56:13 PM UTC, Dan Marotta wrote:
Not being a mechanical engineer, could anyone enlighten me as to why the o-rings are installed internally in the socket rather than externally on the probe?Â* In either case the o-rings are getting rubbed each installation/removal cycle and it seems light lubrication, like the skin oil from one's nose, would work nicely. That's how I lube the probe on my Stemme. And, BTW, the o-rings would be oh so much easier to replace... In ESA probes the UN sockets (eg for triple probes) have the O-rings in the socket and the ST sockets (eg for TE/Static double probes) have the O-rings on the aluminium probe fitting but those ones are more prone to fractures of the fitting on older probes - at the O-ring groove of course. |
Proper Way to Insert Multi-Probe | Dan Marotta | Soaring | 18 | February 19th 18 01:31 AM |
Prandtl multi probe receptacle used for TE only? | Matt Herron Jr. | Soaring | 12 | February 15th 18 08:32 PM |
castellated socket | Stuart & Kathryn Fields | Home Built | 1 | June 3rd 08 12:37 PM |
Replacing innertubes without replacing tires? | Ben Jackson | Owning | 28 | November 6th 06 04:54 PM |
Multi - probe | KP | Soaring | 1 | March 7th 05 06:03 PM |
