TOW PLANE Accident
Old March 13th 19, 04:47 AM posted to rec.aviation.soaring
Charlie Quebec
Default TOW PLANE Accident
Yep Australia is exclusively low tow, with a couple of rare types with a belly hook only that must use high, the Diamant comes to mind.
Whilst I can understand kiting from a belly hook, I would have thought a nose hook would be better in this aspect. For many years the GFA made nose hooks mandatory on all imported gliders.
Ive just recently done my first few tows on a belly hook, as my glider (DG202-17C) has no nose hook, and $5K au seems excessive. No issues so far.
From below the wake you have much more time to prevent a kiting incident before it gets serious, and the tug disappears below the nose.
I stay as low as possible after liftoff (top of tug fin height) and wait until the tug climbs above me, then follow in station. Ive never got even above the wake, as
the turbulence clearly unmissable indicates the out of position, as opposed to high tow, where the air you kite into is no different, giving no warning.
Twice I have released the tow at low level, once thru tug fuel runout, and once where I got higher than I liked, and when I couldn’t be sure I could get back in station in time for the tow plane
to safely take off. In both cases, the tug pilots said it would probably have been ok, but thanked me for making sure.
Fatal glider/tow plane accident, France Sean F2 Soaring 44 May 22nd 12 07:11 PM
Tow plane / glider accident, Adrian MI? Sean Fidler Soaring 5 August 23rd 11 03:39 PM
F-35: Second test plane powers up, but first plane stays grounded Mike[_7_] Naval Aviation 1 October 29th 07 09:40 PM
Float Plane Accident Mike Schumann Piloting 8 October 31st 06 05:15 PM
Walmart heir dies in light plane accident Allen Piloting 1 June 30th 05 11:01 AM
