Lubricating Control system components
Old April 12th 19, 04:57 AM posted to rec.aviation.soaring
George Haeh
Default Lubricating Control system components
My AME swears by Tri Flow Superior. If it's good enough for rotor heads, it should work for gliders.
Old April 13th 19, 05:01 PM posted to rec.aviation.soaring
On Thursday, April 11, 2019 at 12:16:39 PM UTC-4, wrote:
What oil to use for lubricating control system bearings and components.
Dan
Checked my Ventus maintenance manual:
"The Ventus" should be lubricated with acid free grease and oil customary in trade"
"ball bearing with sealed grease filling do not require service"-are these the bearing with a felt enclosure ?
Dan
Old April 14th 19, 02:49 PM posted to rec.aviation.soaring
Thank you all for the advice !
Dan
Old April 14th 19, 09:29 PM posted to rec.aviation.soaring
Wit Wisniewski
A big problem, especially with an older glider is getting to moving parts that you can't see, and certainly not reach with a needle and syringe. I've spent many trials making a PIK-20B's controls operate smoothly. Bearings deep inside the wings and tail were intended to be "permanently lubricated", but that permanence was intended for perhaps a decade, not four.
My current solution is to run a small plastic tube along a bendable but otherwise rigid long rod along with a cheap USB endoscope, both attached at the end of the rod. This allows seeing and reaching several meters into structures to drip lubricant on redirects, rollers, and belcranks far inside.
I use LPS-2, as it lasts for a year on most moving contacts. Flap hinges seem to dry out faster so they need a second application mid season.
Old April 14th 19, 09:55 PM posted to rec.aviation.soaring
With the exception of WD-40, used for it's original intended purpose, I try to avoid anything that come in a spray can. Spray stuff gets all over and collects dirt and makes repair work more complicated on composite ships. If the lubricant dries out, it's probably not the right stuff to use. Lubricating does 2 things- reduce friction and wear, and keep moisture out.
UH
Old May 7th 19, 10:32 PM posted to rec.aviation.soaring
K m
On Thursday, April 11, 2019 at 2:16:11 PM UTC-6, JS wrote:
Whatever happened to Marvel Mystery Oil?
That's a mystery...……..
Old May 7th 19, 10:37 PM posted to rec.aviation.soaring
JS[_5_]
It took nearly 4 weeks, but K m wins!
Grob gliders, new TM about control system pulleys Robert M Soaring 5 February 14th 14 04:47 PM
latest control system! Jordz Piloting 0 July 23rd 07 02:48 PM
sim cockpit control system El Baron Rojo Simulators 0 July 28th 05 09:32 PM
A New Air Traffic Control System On The Horizon Larry Dighera Piloting 0 June 17th 05 03:03 PM
Tactical Artillery Command and Control Information System (TACCIS) Roberth Andersson Military Aviation 0 May 25th 04 11:33 AM
