ClearNav Instruments software update for CN2
Old April 9th 19, 02:08 PM posted to rec.aviation.soaring
Tango Eight
Default ClearNav Instruments software update for CN2
Bug fixes and performance improvements in this maintenance release. Recommended for all CN2 users.
Get it he http://clearnav.net/main/cn-downloads.html
See release notes and installation instructions.
best regards,
Evan Ludeman
Old April 9th 19, 04:01 PM posted to rec.aviation.soaring
Thanks for the heads up Evan.
Old April 20th 19, 11:12 PM posted to rec.aviation.soaring
Paul Natkiel
best regards,
Evan Ludeman
Evan, I have just started to feel comfortable with managing CN to SeeYou and Google Earth file management. If I update CN to this version will I consider or need to jump out of a window?
Old April 21st 19, 12:07 AM posted to rec.aviation.soaring
best regards,
Evan Ludeman
I downloaded and installed. No issues. Many won'tnotice the changes.
UH
Old April 21st 19, 01:10 AM posted to rec.aviation.soaring
Just updated mine 3 hours ago. All is well.
Old April 21st 19, 02:22 AM posted to rec.aviation.soaring
Tango Eight
best regards,
Evan Ludeman
This is a maintenance release. It kills a few bugs that most users never see. There's no change in functionality or feature set.
best,
Evan
Old April 21st 19, 02:53 AM posted to rec.aviation.soaring
3C
Down loaded this morning and flew this afternoon. Worked for me.
Old April 21st 19, 04:20 PM posted to rec.aviation.soaring
John DeRosa OHM Ω http://aviation.derosaweb.net
Just a warning about how to update. USE A BLANK MEMORY STICK. I used one I had used from a prior year and got some rather odd results (due to a mix of old and new files). Did the update again with a blank stick and all was well. Lesson learned.
- John OHM
Old April 21st 19, 04:42 PM posted to rec.aviation.soaring
JS[_5_]
On Sunday, April 21, 2019 at 7:20:47 AM UTC-7, John DeRosa OHM Ω http://aviation.derosaweb.net wrote:
- John OHM
Called Rex about a problem with my CN2, happened to be the day after this update was put on the website. He told me about the update, which fixed it.
Used the old stick. Believe my issue was the number of files stored in memory, now not a problem.
Another part of the update is to ignore files beginning with a dot. Useful for anyone running OSX.
Old April 22nd 19, 12:25 AM posted to rec.aviation.soaring
On Sunday, April 21, 2019 at 10:20:47 AM UTC-4, John DeRosa OHM Ω http://aviation.derosaweb.net wrote:
- John OHM
No need for new stick. Just delete the old updater files.
UH
ClearNav Instruments Co. SOLD - New Owner is.. Larry Roberts Soaring 0 February 4th 17 12:00 AM
ClearNav CNv vario software update Evan Ludeman[_4_] Soaring 5 April 17th 13 01:28 AM
ClearNav Flight Computer Software Update Available Evan Ludeman[_4_] Soaring 0 March 9th 13 02:40 AM
ClearNav Instruments Discussion Board Evan Ludeman[_4_] Soaring 2 October 22nd 12 03:54 AM
ClearNav Instruments Variometer Paul Remde Soaring 0 December 20th 10 05:45 PM
