![]() "Paul J. Adam" wrote in message ... In message , Ctenos writes Is there a consistent basis for this designation in aircraft armament? Not really. "Machine guns" traditionally went up to 12.7mm or 13.2mm, "cannon" were 20mm and up, and there was sort of a grey area in between: notably the Soviet 14.5mm and German 15mm weapons. The Soviets started with an anti-tank rifle and used its ammunition for a Really Heavy Machine Gun; the Germans made a 15mm weapon, then decided that it would be better necked out to 20mm and firing bigger rounds with more payload. I believe the MG151/15 and MG151/20 were designed at the same time with the same cartridge. The 15mm MG151/15 has a proportionatly longer barrel than the MG151/20 to exploit the hot gases appropriatly and achieved a much higher muzzle velocity. It had ballistics better than the US 50 caliber with an explosive shell to boot. Pilots who used it in the early Me 109F liked it because of its great accuracy and range. It lacked enough of an explosive filling to damage the heavy bombers the Germans were encountering so they had to resort to larger caliber weapons with lower muzzle velocities. It was simply to hard to get enough hits to get a heavy down. They needed about 20 hits of 20mm as it is. The designation MG means "MachineGewher" or machine gun. It seems that this ended at about 20mm The designation MK means "MachineKanone" or machine canon. It seems this started at about 30mm eg Mk 103 and Mk 108 which were the high and low velocity 30 mm guns used by the Luwftwaffe. They regarded the Mk 108 as firing 'mines'. They even had a hydrostatic fuse to detonate within the fuel tank. Only 3 hits were required to brring down a 4 engined heavy bomber and even a P47 couldn't survive more than a hit or two. (which made the Me 109 so deady if it got to within 200m) http://www.luft46.com/armament/mk108.html At some point, around 50mm the designation changed the BK (Bord Kanon) sometimes appeared. Believe it or not the Germans were planing to arm their fighters with the 55mm Mk 112. It was a scaled up Mk 108. It was actualy quite a feasigle weapon calculated to require only 1 hit. It was low velocity but the shear size of the shell gave it reasonable ballistics. There was also PAK (Panzer Abwher Kanone) literaly (tank anti canon) and FLAK (Flugzeug Abwher Kanone) literaly (Flyingthing anti gun). FLAK has ofcourse entered the english language. (Though they called both MG151/15 and MG151/20 'machine guns', as well as the 20mm MG/FF, further muddying the waters) The MG/FF was a liscence or import of the Swiss Oerlikon 20mm used by both allies and germans. It was recoil opperated and had a nice heavy shell but its cadence and velocity was relative low. British AAA used a modified version with higher velocity and even lower cadence (450rpm). It was however simple, compact and reliable and it fitted into the Me 109s wing. The Much Bigger compressed air opperated Mauser (known as the jack hammer becuase of its sound to the allies) had to be slung under the 109s wings becuase of the slats. In terms of aircraft armament, it's gone away because 20mm is low-end for fast-jet armament. Meanwhile, the old rule of thumb that you couldn't get a useful explosive round in less than 20mm has been overturned by Raufoss and their 12.7mm multipurpose round. What makes this round supposedly effective? New more powerfull explosives? Minaturised fuses? During the Korean war Sabre pilots often observed their 50 caliber rounds bouncing of Migs. The combination of extended ranges and thicker metal skins meant that the standard 50 caliber round lacked the punch needed. Basically, pick a position you like and stick to it ![]() -- He thinks too much: such men are dangerous. Julius Caesar I:2 Paul J. Adam MainBoxatjrwlynch[dot]demon{dot}co(.)uk |
"The" == The Enlightenment writes:
The fuse to detonate within the fuel tank. Only 3 hits were The required to brring down a 4 engined heavy bomber and even a The P47 couldn't survive more than a hit or two. (which made the The Me 109 so deady if it got to within 200m) As loing as it was _behind_ the P-47 at the time g The At some point, around 50mm the designation changed the BK The (Bord Kanon) sometimes appeared. Believe it or not the The Germans were planing to arm their fighters with the 55mm Mk The 112. It was a scaled up Mk 108. It was actualy quite a The feasigle weapon calculated to require only 1 hit. It was low The velocity but the shear size of the shell gave it reasonable The ballistics. I suppose much like the vaunted 18" guns on Furious. Only one gun, only need one hit. But one shot also takes out the carrier aircraft, rattle rattle splat. Sorry, I couldn't resist, hard day at work... (PS The Japanese pilots carried swords for really close-range work - *kathwap* there goes the enemy's aerial wire, *thwakaaa* there goes the venturi, *bong bong bong* sound of hilt on the canopy). -- G Hassenpflug * IJN & JMSDF equipment/history fan |
In article , The
Enlightenment writes "Paul J. Adam" wrote in message ... Big SNIP The designation MG means "MachineGewher" or machine gun. It seems that this ended at about 20mm The designation MK means "MachineKanone" or machine canon. It seems this started at about 30mm eg Mk 103 and Mk 108 which were the high and low velocity 30 mm guns used by the Luwftwaffe. They regarded the Mk 108 as firing 'mines'. They even had a hydrostatic fuse to detonate within the fuel tank. How on earth did that work, given the inevitable cavitation in the body of the fuel as the projectile passed through? Only 3 hits were required to brring down a 4 engined heavy bomber and even a P47 couldn't survive more than a hit or two. (which made the Me 109 so deady if it got to within 200m) http://www.luft46.com/armament/mk108.html N'other SNIP Cheers, Dave -- Dave Eadsforth |
On Mon, 23 Aug 2004 08:14:56 +0100, Dave Eadsforth
wrote: How on earth did that work, given the inevitable cavitation in the body of the fuel as the projectile passed through? Our nazi loving chum is emitting yet more uninformed bull****. greg -- Es ist mein Teil - nein Mein Teil - nein Denn das ist mein Teil - nein Mein Teil - nein |
Subject: Gun, machine gun and/or cannon?
From: "The Enlightenment" Date: 8/22/2004 10:49 PM Pacific Standard Time Message-id: Only 3 hits were required to brring down a 4 engined heavy bomber and even a P47 couldn't survive more than a hit or two. (which made the Me 109 so deady if it got to within 200m) http://www.luft46.com/armament/mk108.html During our training in WW II the number of hits to bring down any plane was a point of important study for us. Bringing down a heavy bomber with three hits regardless of where it was hit is in itself an unreasonable concept. Studies showed that an ME 109 would have to put almost 75 hits into a B-17 to bring it down. The most vulnerable enemy fighter was the Jap zero (after the JU 87) and it needed 12 hite to bring it down. Arthur Kramer 344th BG 494th BS England, France, Belgium, Holland, Germany Visit my WW II B-26 website at: http://www.coastcomp.com/artkramer |
![]() "ArtKramr" wrote in message ... Subject: Gun, machine gun and/or cannon? From: "The Enlightenment" Date: 8/22/2004 10:49 PM Pacific Standard Time Message-id: Only 3 hits were required to brring down a 4 engined heavy bomber and even a P47 couldn't survive more than a hit or two. (which made the Me 109 so deady if it got to within 200m) http://www.luft46.com/armament/mk108.html During our training in WW II the number of hits to bring down any plane was a point of important study for us. Bringing down a heavy bomber with three hits regardless of where it was hit is in itself an unreasonable concept. Studies showed that an ME 109 would have to put almost 75 hits into a B-17 to bring it down. The most vulnerable enemy fighter was the Jap zero (after the JU 87) and it needed 12 hite to bring it down. That kinda dependson what its hit with and where its hit doesnt it ! The German jet fighters carried a 30mm cannon with rather more stopping power than the .50 calibre machine guns carried by US aircraft. Keith ----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 100,000 Newsgroups ---= 19 East/West-Coast Specialized Servers - Total Privacy via Encryption =--- |
From: "Keith Willshaw" Date: 8/23/2004 7:44 AM Pacific Standard Time Message-id: "ArtKramr" wrote in message ... Subject: Gun, machine gun and/or cannon? From: "The Enlightenment" Date: 8/22/2004 10:49 PM Pacific Standard Time Message-id: Only 3 hits were required to brring down a 4 engined heavy bomber and even a P47 couldn't survive more than a hit or two. (which made the Me 109 so deady if it got to within 200m) http://www.luft46.com/armament/mk108.html During our training in WW II the number of hits to bring down any plane was a point of important study for us. Bringing down a heavy bomber with three hits regardless of where it was hit is in itself an unreasonable concept. Studies showed that an ME 109 would have to put almost 75 hits into a B-17 to bring it down. The most vulnerable enemy fighter was the Jap zero (after the JU 87) and it needed 12 hite to bring it down. That kinda dependson what its hit with and where its hit doesnt it ! The German jet fighters carried a 30mm cannon with rather more stopping power than the .50 calibre machine guns carried by US aircraft. Keith ----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 100,000 Newsgroups ---= 19 East/West-Coast Specialized Servers - Total Privacy via Encryption =--- Y'think maybe the guys doing the surveys of battle damage were aware of that? I'll bet they might have been. If you know it, I guess they may have known it as well. Y'think so? Arthur Kramer 344th BG 494th BS England, France, Belgium, Holland, Germany Visit my WW II B-26 website at: http://www.coastcomp.com/artkramer |
![]() "ArtKramr" wrote in message ... Subject: Gun, machine gun and/or cannon? Y'think maybe the guys doing the surveys of battle damage were aware of that? I'm sure they were. It was after all the reason the germans uprated the cannon fit. I'll bet they might have been. If you know it, I guess they may have known it as well. Y'think so? Sure. Doesnt alter the fact that a 30mm cannon can blow a hole the size of your fist in a B-17 and its not going to take too many of those before its in deep ****. Based on the damage done to downed B-17's the Luftwaffe estimated that it took an average of 20 hits from the 20mm cannon to destroy a B-17 but as few as 3 hits from the 30mm. see http://www.afa.org/magazine/1993/0993Against.asp Keith ----== Posted via Newsfeed.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeed.com The #1 Newsgroup Service in the World! 100,000 Newsgroups ---= 19 East/West-Coast Specialized Servers - Total Privacy via Encryption =--- |
![]() "ArtKramr" wrote in message ... Subject: Gun, machine gun and/or cannon? From: "Keith Willshaw" Date: 8/23/2004 8:58 AM Pacific Standard Time Message-id: "ArtKramr" wrote in message ... Subject: Gun, machine gun and/or cannon? Y'think maybe the guys doing the surveys of battle damage were aware of that? I'm sure they were. It was after all the reason the germans uprated the cannon fit. I'll bet they might have been. If you know it, I guess they may have known it as well. Y'think so? Sure. Doesnt alter the fact that a 30mm cannon can blow a hole the size of your fist in a B-17 and its not going to take too many of those before its in deep ****. Based on the damage done to downed B-17's the Luftwaffe estimated that it took an average of 20 hits from the 20mm cannon to destroy a B-17 but as few as 3 hits from the 30mm. see http://www.afa.org/magazine/1993/0993Against.asp Keith ----== Posted via Newsfeed.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeed.com The #1 Newsgroup Service in the World! 100,000 Newsgroups ---= 19 East/West-Coast Specialized Servers - Total Privacy via Encryption =--- We took more hits than that on Willie the Wolf and I am still here to tell about it. Well, you have told us a lot of other crap that we have not bought into, either, so what's new? How many 30mm hits did you take? Heck, you have also told us your unit *never* missed its assigned target, which is of course patently false, as *no* unit could honestly make that claim during WWII (proven by the fact that your unit was NOT recognized as having the best bombing accuracy amongst B-26 units in the ETO, and the one that *was* acknowledged having around five or so of their assigned targets that they did not hit). Brooks Arthur Kramer |
Ultralight Club Bylaws - Warning Long Post | MrHabilis | Home Built | 0 | June 11th 04 05:07 PM |
Democracy Expires | Grantland | Military Aviation | 14 | March 8th 04 04:54 AM |
Titor's Time Machine... USAF Missile Box??? | Jason Strong | Military Aviation | 8 | November 28th 03 12:51 AM |
marlin aerial machine gun spad? | old hoodoo | Military Aviation | 0 | August 10th 03 09:06 PM |
Machine Tool Co. Bankruptcy Sends Ripple Through JSF Program | huuto | Military Aviation | 3 | July 29th 03 05:59 AM |
