Commercial operators can offer a single-seat ship for rent when it has a Special - experimental exhibition & racing A/W cert...
On Monday, May 6, 2019 at 7:21:20 PM UTC-4, wrote:
Commercial operators can offer a single-seat ship for rent when it has a Special - experimental exhibition & racing A/W cert... I just looked at the limitations on one of my ships. It expressly refers to 91.319 with respect to purposes of operation. 91.319(e) specifically does not allow use for compensation or hire. FWIW UH |
It’s pretty common to have experimental gliders in a club. They’re not put out for compensation or hire but owned by the club members with shared expenses.
Common, doesn't make it right.
Are they submitting program letters? |
Correct me if I am wrong but not all experimental gliders need program letters. Guess I’ll find out I am going to be buying my first experimental glider this weekend.
Basic common sense tells me that it would be OK for a club to own a single seat experimental glider and fly it. They’re not letting it out to the public. What would the difference be between a club and a consortium of say 4 pilots owning and flying one? |
So you’re saying that all experimental gliders need program letters? I didn’t see any mention of a program letter in the glider I am buying.
I don’t know the answer if any particular club is submitting a program letter. Whenever I do a condition inspection and notice one in the files I remind the owner to submit their yearly letter. |
On Monday, May 6, 2019 at 7:30:09 PM UTC-7, Charles Longley wrote:
So you’re saying that all experimental gliders need program letters? I didn’t see any mention of a program letter in the glider I am buying. That depands on how the original operating limitations and program letter were written. Some have just a few paragraphs and just one program letter. DO NOT let the registration expire on that one. Some (mostly newer) have several pages of limitations and the requirement of an annual program letter. If an FSDO is specified in the original and that FSDO is no longer operational, or if the aircraft is moved away from that FSDO's jurisdiction you may have to redo the paperwork. Again, depends on the wording. But in my experience, it's more difficult to fix the bad title on a glider trailer than comply with the details of an EXP registration. Jim |
On Monday, May 6, 2019 at 10:30:09 PM UTC-4, Charles Longley wrote:
So you’re saying that all experimental gliders need program letters? I didn’t see any mention of a program letter in the glider I am buying. I don’t know the answer if any particular club is submitting a program letter. Whenever I do a condition inspection and notice one in the files I remind the owner to submit their yearly letter. I don't recall exactly when the requirement for program letters was added to the operations limitations for Experimental exhibition and air racing category gliders, but it was more than 15 years ago. When moving to a new operating area, sending a program letter to notify the cognizant FSDO of the change of base will normally suffice. Some limitations may require issuance of new operating limitations. This is fairly rare has gone away in more recent times with standardization. Older ships may have no such requirement. Don't lose those operating limitations because you will then have to get new ones to later standards. Unless otherwise stated in the docs, duration is unlimited. Change in N number triggers all new stuff when new airworthiness certificate is issued. The key thing is to review the operating limitations that are part of the airworthiness certificate and comply. It isn't all that hard but I still find ships that don't have correct paperwork. UH |
" So you’re saying that all experimental gliders need program letters? "
No, I didn't say that. I was just pointing out one of the obstacles of useing an experimental glider in a club environment. ---------- I just pulled up a copy of a current "old style" ops limitations. Paragraph 1 says "no person may operate this aircraft for other than the purpose for which the special purpose airworthiness certificate was issued and shall be operated in compliance with applicable FAA general operating and flight rules. " What's the special purpose airworthiness certificate issued for, Exhibition and Racing. Not meandering,training,time building or sight seeing. Exhibition and racing uses are further defined by the FAA. Club use does not fit. I guess there's no problem with a club owning one. It's the pilot that is at risk, and in a club environment most pilots have no idea. They probably never even read the ops limitations. Perhaps we should start a new thread if we are going to continue this communication, rather than drift from the OP,original questions. |
On Tuesday, May 7, 2019 at 6:45:24 AM UTC-6, wrote:
On Monday, May 6, 2019 at 10:30:09 PM UTC-4, Charles Longley wrote: So you’re saying that all experimental gliders need program letters? I didn’t see any mention of a program letter in the glider I am buying. I don’t know the answer if any particular club is submitting a program letter. Whenever I do a condition inspection and notice one in the files I remind the owner to submit their yearly letter. I don't recall exactly when the requirement for program letters was added to the operations limitations for Experimental exhibition and air racing category gliders, but it was more than 15 years ago. When moving to a new operating area, sending a program letter to notify the cognizant FSDO of the change of base will normally suffice. Some limitations may require issuance of new operating limitations. This is fairly rare has gone away in more recent times with standardization. Older ships may have no such requirement. Don't lose those operating limitations because you will then have to get new ones to later standards. Unless otherwise stated in the docs, duration is unlimited. Change in N number triggers all new stuff when new airworthiness certificate is issued. The key thing is to review the operating limitations that are part of the airworthiness certificate and comply. It isn't all that hard but I still find ships that don't have correct paperwork. UH Pre-moratorium imports generally had permanent operating limitations and no annual program letter. Post-moratorium imports had operating limitations that required re-issue when base of operations and FSDO changed and annual program letters. There was some effort to get permanent operating limitations re-authorized through efforts of the Type Club Coalition, but I don't think that got traction. FAA modified FAA Order 8130.2 quite a bit between versions D and J and pre and post moratorium are no longer included. Frank Whiteley |
Buying a glider, advice on type and prices | John[_37_] | Soaring | 57 | December 2nd 16 07:13 PM |
Buying my first glider | [email protected] | Soaring | 24 | November 14th 13 03:19 AM |
Buying a glider from Canada | Bmwbob | Soaring | 1 | August 6th 10 11:20 PM |
US resident , no greencard, buying a glider in the US | Peter[_1_] | Soaring | 18 | October 29th 09 04:27 AM |
Buying a used GLider | JSF-TC | Soaring | 2 | June 25th 07 05:55 AM |
