Implausible Time Records
Old May 8th 19, 03:58 PM posted to rec.aviation.soaring
Dan Marotta
Default Implausible Time Records
I can't fault software for failing to filter out bad data.Â* Having
submitted a number of logs to OLC from a cell phone, I don't see the
type of errors described here.Â* Maybe better gps engines are in order?
Seems like producing good data is better than filtering out bad data.
What you say has merit, but I can't see opening up my ClearNav computer
and vario and attempting to replace the GPS engines.
Since both and my PowerFlarm portable experience the drop outs, I've got
three new antennae on order.Â* We'll see how that works.
Funny how this just started happening in the end of April...
Dan, 5J
Old May 8th 19, 07:16 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
I thought: have you got another logger you could leave running on the
field away from the runway but where it gets a decent signal?
If that also gets the time hiccup, then you'll know the problem is
outside the Stemme.
Martin | martin at
Gregorie | gregorie dot org
Old May 8th 19, 11:28 PM posted to rec.aviation.soaring
Dan Marotta
I have a Dell Streak in the cockpit (right side) for my wife's use. It
also records an igc file which I can post on skylines.org.Â* It is not
acceptable to OLC due to no ENL recorder.Â* Maybe the XCSoar troops would
write a module to access the Streak's microphone and record engine
noise...Â* Or maybe one of the XCSoar clones already does that?
outside the Stemme.
Dan, 5J
Old May 9th 19, 02:58 AM posted to rec.aviation.soaring
kinsell
I see a flight on Jan 27 this year that had the same highly compressed
altitude graph, so something wasn't right well before end of April.
Sounds like you've got problems due to jamming, in addition to at least
one other issue.
Should be plenty of other gliders flying out of Moriarty to compare logs
with. Suppose you could submit one from the Dell Streak and lie about
the glider type, then delete it after seeing how OLC likes it.
-Dave
outside the Stemme.
Old May 9th 19, 03:38 PM posted to rec.aviation.soaring
Dan Marotta
Good idea.Â* I noticed the time compression some time ago but chalked it
to OLC doing something new.Â* It's cloudy and rainy today but I need to
go to the airport anyway.Â* I'll get the Streak.
least one other issue.
logs with.Â* Suppose you could submit one from the Dell Streak and lie
about the glider type, then delete it after seeing how OLC likes it.
-Dave
It also records an igc file which I can post on skylines.org.Â* It is
not acceptable to OLC due to no ENL recorder.Â* Maybe the XCSoar
troops would write a module to access the Streak's microphone and
record engine noise...Â* Or maybe one of the XCSoar clones already
does that?
outside the Stemme.
Dan, 5J
All US Records are Now Motor Glider Records Tango Eight Soaring 99 March 23rd 17 12:07 PM
OT 4 airport round robin - time lapsed / real time with ATC COMS -video A Lieberma[_2_] Owning 0 August 30th 09 12:26 AM
OT 4 airport round robin - time lapsed / real time with ATC COMS -video [email protected] Instrument Flight Rules 0 August 30th 09 12:26 AM
4 airport round robin - time lapsed / real time with ATC COMS - video [email protected] Piloting 0 August 30th 09 12:25 AM
they took me back in time and the nsa or japan wired my head and now they know the idea came from me so if your back in time and wounder what happen they change tim liverance history for good. I work at rts wright industries and it a time travel trap tim liverance Military Aviation 0 August 18th 03 12:18 AM
