grob main wheel and brake disk
Old May 8th 19, 05:52 PM posted to rec.aviation.soaring
Default grob main wheel and brake disk
James,
Our aircraft mechanic put aviation brake fluid into our Grob brake and all the seals swelled up and are no good. Do you recall which master cylinder rebuild kit you used?
Thanks,
Chris
On Thursday, July 26, 2018 at 9:36:33 AM UTC-4, wrote:
On Tuesday, July 24, 2018 at 11:07:52 AM UTC-4, Charlie Quebec wrote:
Quit so, normal brake fluids are hygroscopic, and easily absorb water, which then causes vapour issues in the lines when heated, allowing it to be compressed.
Sounds to me like dot5 is a better option.
I've forgotten if this was the original problem or not, but I've been through the whole process of rebuilding the hydraulic brake system on a Grob 103. Complications arise because Grob used an off-the-shelf master cylinder derived from a motorcycle application. That requires a different type of fluid than the usual hydraulic fluid used in aircraft brakes, and expected by the Cleveland wheel cylinder O-ring. One of us went to a mechanic that works on power planes, and he handed us an O-ring based on the Cleveland part number. Then I went to a real glider mechanic, and he threw that one away, because it wasn't going to be compatible. I think we got some help from Robert(?) Mudd, and once you know the material you're looking for, McMaster has them cheap (but you probably have to buy at least 25 to get 1). Unfortunately I've forgotten when that material was, but I could look around in my spare parts box, if it's important to anybody.
I got the master cylinder overhaul parts from a company that supplies parts for old BMW (Oilheads?) motorcycles.
Jim Beckman
WTB - used Cleveland 40-78B main wheel Roy B. Soaring 1 February 19th 18 08:25 PM
hydraulic disk brake upgrade shkdriver Soaring 2 June 27th 13 05:41 PM
ASW-24 Main Wheel Removal Lauren Rezac Soaring 5 March 19th 12 04:20 PM
Tost 5“Penta disk brake wheel Mod for Duo Discus Mike I Green Soaring 0 February 6th 12 09:38 PM
Tost Disk Brake rebuild? Paul Cordell Soaring 10 April 17th 08 07:20 AM
