Greatest Strategic Air Missions
Old August 23rd 04, 06:37 PM
Kevin Brooks
"Matt Wiser" wrote in message
news:412a26b3$1@bg2....
It took a double-whammy of the A-bomb and Ivan crossing into Manchuria and
Korea to end the war. The A-bomb alone might not have been enough.
Anything
that prevents OLYMPIC and CORONET from having to be executed had to be
done.
Period. The Japanese Cabinet was meeting to discuss Hiroshima and the
Soviet
invasion when word reached them of the Nagasaki strike. Next day Hirohito
decides that enough is enough. 14 Aug is the attempted putsch that fails
and the Surrender announcement comes on the 15th. Next probable nuclear
strike
date was on 18 Aug with Kokura as the primary. Bomb #3 was about to leave
Los Alamos on 10 Aug when a hold order arrived. Two bombs and a million
and
a half Russians in the space of four days forced Japan's surrender. End of
story and of war.
Overly simplistic, at least those last two sentences. A hell of a lot more
than that went into the Japanese surrender equation. The tightening sea
blockade, effective inshore mining by B-29's, the creeping effects of the
B-29 raids against industrial and urban areas, the gaining of bases at Iwo
Jima and Okinawa that now moved even more landbased airpower into range of
Kyushu and Honshu, the isolation of large troop garrisons in far-flung and
by then bypassed areas, the fact that they no longer had any navy to speak
of outside kamikaze attack light combatants being horded, along with their
remaining aircraft, to counter the feared invasion of Kyushu, and of course
that feared homeland invasion itself (and the fact that the more reasonable
Japanese leaders by then realized that "Ketsu-Go" was invariably doomed to
failure when that invasion did come)...all of these factors contributed to
the Japanese surrender. The first atomic bomb was an attention getter, the
Soviet invasion was the closure of their forlorn negotiated surrender hopes,
and the second bomb was the final closer.
Brooks
snip
Old August 24th 04, 03:27 PM
Matt Wiser
"Kevin Brooks" wrote:
"Matt Wiser" wrote
in message
Anything
done.
Soviet
strike
and
story and of war.
The tightening sea
Brooks
snip
And there was no way that the Kyushu invasion (OLYMPIC) could have been
repelled: Most Japanese defenses were on the beaches and inland in range
of NGFS, and a suggestion that the defense of Okinawa and Luzon be emulated
was rejected-the plan was defend on the beaches and in strength inland, but
once the beach defenses are broken, the Japanese coastal divisions have had
it, and the attempts to move reserves from South-Central Kyushu to counterattack
(Ariake Bay, where XI Corps with 1st Cav, 43rd and Americal Divisions would
have landed was considered by the Japanese to be the main battle area in
Kyushu) would have been exposed to air attack and have had very poor roads
on which to move anyway. Mostly grunts with little heavy equipment anyhow
and what armor they had would have suffered from air and naval gunfire before
even getting to the battle. Best case for Kyushu is 30 days, more likely
45-50 days before Southern Kyushu is relatively secure and the base-building
gets underway for to support CORONET.
Posted via www.My-Newsgroups.com - web to news gateway for usenet access!
Old August 24th 04, 04:21 PM
Kevin Brooks
news:412b51f9$1@bg2....
"Matt Wiser" wrote
in message
Anything
done.
Soviet
strike
and
story and of war.
The tightening sea
Brooks
snip
repelled
That is what I meant when I said that their more competent leaders realized
that Ketsu-Go was not a winning option; Ketsu-Go was their defensive plan
for the home islands that had succeeded the previous Sho-Go.
emulated
but
True, but you must remember that their strategy was to try and neutralize
the NGFS and CAS superiority the US would have enjoyed by making it a
close-in "knife fight" that would have limited the usefullness of each of
those fire support systems. They were hamstrung, though, by their lack of
engineer units with which to prepare adequate defenses.
had
it,
The Japanese had already recognized that allowing the US to gain a beachhed
*anywhere* typically resulted in a rapid buildup of combat power that their
forces could not subsequently cope with, which is why they depended upon
first trying to hammer the invasion fleet with kamikaze attacks from the
air, the surface of the sea, and under the sea, and then engaging the
spearhead forces in close combat. Their best hope was that they could make
the cost so bloody to the allies that we would decide it was not worth the
effort--not a very likely outcome. But it would have likely been plenty
bloody for both sides.
would
The Japanese staff did a pretty good job in terms of identifying the likely
invasion sites and arraying forces accordingly. And you are right, their
CATK forces would have been hard pressed to do their job; their plans called
for them to arrive and launch directly into battle from march order, so
those that *did* survive the inevitable pounding from allied air
interdiction efforts would have found themselves being fed into the
gristmill in a piecemeal fashion, not a good thing (for them).
before
base-building
I'd be careful about overestimating the value of WWII long range NGFS;
history shows that it was often of limited value (the most valuable NGFS in
numerous operations was that provided by the tin cans operating
up-close-and-personal). Time and again we pounded the hell out of Japanese
defenses with NGFS, only to have to tangle with them when they emerged from
their bunkers and hidey-holes.
Brooks
Greatest Strategic Air Missions? Leadfoot Military Aviation 66 September 19th 04 05:09 PM
Russian recon planes fly ten missions over Baltics B2431 Military Aviation 4 March 2nd 04 04:44 AM
New Story on my Website ArtKramr Military Aviation 42 February 18th 04 05:01 AM
French block airlift of British troops to Basra Michael Petukhov Military Aviation 202 October 24th 03 06:48 PM
Strategic Command Missions Rely on Space Otis Willie Military Aviation 0 September 30th 03 09:59 PM
