OAT sensor placement
Old May 14th 19, 07:12 PM posted to rec.aviation.soaring
Dan Marotta
Default OAT sensor placement
I've installed them in 3 gliders.Â* In the LS-6a and the LAK-17a, I
installed them in the nose vent.Â* My Stemme has a NACA vent on the under
side of the fuselage just about where the pilot's knees are. There's a
removable panel which grants access to the inner surface of the vent.Â* I
simply drilled the proper size hole, glued the temperature probe in the
hole, and ran the wires to the instrument panel.Â* Easy peasy!
On 5/14/2019 8:39 AM, Rob Shepherd wrote:
Where would be the best place to install an OAT sensor?
I'm assuming somewhere on the underside of the glider but out of the
airstream.
Constructive comments appreciated.
Cheers
Rob
Dan, 5J
Old May 14th 19, 09:15 PM posted to rec.aviation.soaring
What are the implications of not having the sensor directly in an outside airflow stream - other than getting an incorrect temperature reading. What calculations are dependent on the OAT and how will they be affected by having an incorrect temperature?
Robert
airstream.
Cheers
Rob
Dan, 5J
O2 sensor? Blueskies Home Built 16 July 3rd 07 04:36 PM
Nav Antenna Placement Jim Pensinger Home Built 7 October 4th 04 09:55 PM
Westach 720-4a sensor Ira Rampil Home Built 1 June 21st 04 03:41 AM
temperature sensor Philippe Vessaire Home Built 2 March 3rd 04 03:37 AM
Ki-100 armament placement N-6 Military Aviation 2 October 18th 03 12:09 AM
