Cobra Trailer Brakes
Old May 20th 19, 08:40 PM posted to rec.aviation.soaring
Default Cobra Trailer Brakes
A more open wheel with some hubcaps could do some venting. There are some OEM car wheels (Corvette and others) that do exactly that.
Scoops/channels are likely to get torn off, especially a retrieve in a field that is soft, rough or tall grass.
While I have not made it a habit to check trailer wheel temps when towing, if the surge brake actuator is lubed and not bent, there should be almost no brake usage. Thus, no heat generated.
Old May 20th 19, 09:37 PM posted to rec.aviation.soaring
As far as I can tell, every time that the tow vehicle uses its brakes, the brakes on the trailer engage. Is this not the way it is supposed to work?
DVM
Old May 20th 19, 09:47 PM posted to rec.aviation.soaring
AS
DVM
No - only if the towing vehicle decelerates fast enough so that the trailer does overcome the force of the damper in the tow bar will the brakes be engaged. If you feel a subtle 'bump in the rear' every time you tap the brake, check/replace the damper.
Uli
'AS'
Old May 20th 19, 10:00 PM posted to rec.aviation.soaring
How much force does it take to compress the trailer tongue. My estimate was about 75 pounds. Does this seem about right?
DVM
Old May 20th 19, 11:19 PM posted to rec.aviation.soaring
AS
DVM
I would guess that depends on the weight of the trailer. Mine is a two axle one with a max weight of around 3,500#. I would imagine that my damper requires more force to collapse than one in a trailer for a 1-26. I tried to compress my tow bar by hand and couldn't.
Only if I have to do a 'panic stomp' on the brake do I feel the bump in the rear. The three grease fittings get a few shots every year and that seems to be all required to keep it happy.
Uli
'AS'
Old May 20th 19, 11:42 PM posted to rec.aviation.soaring
JS[_5_]
DVM
Uli
'AS'
To order the correct tongue damper for a Cobra requires sending the information stamped on the trailer's AlKo tongue to Ralf at Spindelberger.
This would imply there are different dampers, different forces.
(several are in stock at W+W)
When the damper is REALLY gone, you'll feel and hear a loud clunk on starts and stops.
Old May 21st 19, 12:09 AM posted to rec.aviation.soaring
I have contacted Cobra and they told me that my trailer has 2051 brakes and the overrun device is 161S. However; that still does not tell me what the compression force is? As noted above the trailer tongue compresses with i'm guessing 75 pounds of force and then extends out to its full extension in about 10 seconds.
DVM
2013 Cobra trailer price list needed for TA trailer sale [email protected] Soaring 0 June 22nd 13 02:42 PM
cobra wheel bearings and brakes [email protected] Soaring 4 August 13th 12 11:21 PM
Cheap Cobra Trailer Lights 1998 Trailer on E-bay USA ONLY! flyingmr2 Soaring 4 November 16th 10 02:11 AM
Cobra surge brakes on mountain grades. [email protected] Soaring 12 May 21st 07 02:15 AM
Cobra Trailer brakes R Barry Soaring 22 July 19th 04 04:51 PM
