WTB - ASW-27 Schleicher Factory Sized O2 Bottle
Old May 29th 19, 02:34 PM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
Default WTB - ASW-27 Schleicher Factory Sized O2 Bottle
On Tuesday, May 28, 2019 at 10:32:55 PM UTC-7, 2G wrote:
On Tuesday, May 28, 2019 at 9:26:42 PM UTC-7, JS wrote:
Some medical supply houses may still have steel D cylinders. Here's one..
https://www.boundtree.com/Oxygen-Equ...ize-D/p/020916
"This cylinder comes standard with a CGA870 medical post valve but can be fitted with a toggle valve, or a CGA540 valve."
Their prices are hidden unless you're logged in.
Another site charges $18 for the CGA540 option. But the spec'd volume on their D cylinder is odd.
https://www.emtmedicalco.com/MD-D-CY...70-K870MDS.htm
I recently bought 2 D size alum cylinders from Mountain High for $205 each. The fit perfectly into my new ASH31Mi with the factory supplied cylinder fittings. I also bought a M122 alum cylinder (3455 liters) from wtfarley.com for $299 and a CGA540 trans-fill adapter from ebay for $70:
https://www.wtfarley.com/M122-Alumin...-CGA-540-Valve
https://vod.ebay.com/vod/FetchOrderD...&ul_noapp=true
Everything has DOT stamps - no Euro crap. I got the M122 filled with aviator's O2 at the local Oxarc for $40 (aviator's O2 is regular O2 that has been tested for moisture). By way of comparison, filling a single D2 cylinder at the airport typically costs $40. This should cover me for an entire season of soaring and pay for the cost of the equipment. And I can fly from ANY airport, including those that don't have O2 service. Note: you can fill ANY cylinder you want from your own supply cylinder - no DOT stamp required!
Tom
http://www.mhoxygen.com/index.php/co...s/download/629
A very good PDF about oxygen and transfilling.
Richard
www.craggyaero.com
Old May 29th 19, 06:44 PM posted to rec.aviation.soaring
JS[_5_]
Tom
Just spoke with Bound Tree. They have sold all of those steel D cylinders. Tried EMT, but got voicemail.
Where does the O2 cylinder fit in the ASH31? Same as ASH26, behind your left shoulder?
Al cylinders don't fit ASW27, 28, ASG29 which have a tight tube behind the seat back on the right side.
Anyone having a problem finding the steel D required for 27/28/29 could modify the baggage compartment like 27058, allowing the use of an "E" sized Al cylinder.
This does not work if you have a sustainer.
There's a photo of the baggage compartment of 27058 after the O2 mount and extractor mods in the ASW27 newsgroup. Or:
https://www.dropbox.com/sh/0gh8y9b7p...ykXOTBjEa?dl=0
Navaho - Navaho_SM_64.sized.jpg J Three Aviation Photos 0 April 19th 16 02:36 AM
Best way to hoist an over-sized pilot out of the cockpit? (post landing) son_of_flubber Soaring 7 July 5th 12 04:14 AM
Group P-39 Aircobra: 29 of 32- 024_P39_7.sized.jpg (1/1) Rogue Aviation Photos 0 October 25th 09 06:12 PM
Finally: The right-sized Thielert Thomas Borchert Owning 38 June 14th 06 03:46 PM
fire at Schleicher factory facilities Eric van Geetsum Soaring 7 July 24th 03 04:56 AM
