One-man rigging aids - is the electric up/down control worth it?
Old June 4th 19, 06:12 PM posted to rec.aviation.soaring
Default One-man rigging aids - is the electric up/down control worth it?
On Tuesday, June 4, 2019 at 3:06:03 AM UTC-5, Gary Wayland wrote:
On Sunday, June 2, 2019 at 10:44:34 AM UTC-4, Paul Kaye wrote:
My new club seems to have a culture of rig in April and derig in October! Personally I prefer to rig and derig for each flight, unless I know that there is a run of several days good weather and I'm available to fly. I have covers (Cloud-dancers) but I really don't think they offer the protection against UV that is needed for leaving it outdoors for long periods.
Anyhow, as a consequence, it's not always easy to get help to rig/de-rig so I'm thinking of getting a on-man rigging aid. It seems that I can get one from IMI for about €900 that is manually-adjustable for height and sideways alignment, or I could pay around €1500 for an electrically-adjustable version. I'm happy to pay for the more expensive one, if it's worth it. So, if any of you have any experiences/opinions, I'd be happy to hear them!
Thanks in advance.
I have a Fonz-Mobile one man rigger... No Motors! Use the cradle carriage pump to do the up and down when adjusting for the final pin in the spar...
Gary
"SQ"
Looks like we have a bunch of girly luddites on this topic. Two points: the linear actuators are dirt-cheap and easy to fit even to existing riggers. I built my own. Second, remote control of those actuators cost you a whopping $10-20 and makes it super easy to get the pins in. Here is my rigger whirring away in my basement (no wing saddle fitted).
https://www.youtube.com/watch?v=N43YMoq2h7s&t=3s
Now watch it in action, ~7 min for the inside wings. Try to beat that.
https://www.youtube.com/watch?v=jnmaUsPtvSI&t=1s
Old June 4th 19, 07:38 PM posted to rec.aviation.soaring
ripacheco1967
you built that rigger yourself? that is nice... looks awesome
When you know... you know!
Old June 5th 19, 11:59 AM posted to rec.aviation.soaring
Tango Eight
Thanks in advance.
I have a Fonz-Mobile one man rigger... No Motors! Use the cradle carriage pump to do the up and down when adjusting for the final pin in the spar....
Gary
"SQ"
Looks like we have a bunch of girly luddites on this topic. Two points: the linear actuators are dirt-cheap and easy to fit even to existing riggers.. I built my own. Second, remote control of those actuators cost you a whopping $10-20 and makes it super easy to get the pins in. Here is my rigger whirring away in my basement (no wing saddle fitted).
That looks pretty sweet Herb. What's the mode of failure if the reduction gears break? Does the lead screw unwind under load and drop your wing to minimum height?
best,
Evan Ludeman
Old June 5th 19, 02:46 PM posted to rec.aviation.soaring
Hi Evan, no the failure mode is wherever it left off. I have one, Glider-Rigger, I demoed at Perry this year that uses the same actuators as Herb's wireless remote and breaks down small and packs up in a nice padded covers and softcase all designed to go in the front of the trailer. he is working on revision 3.2 now. It comes with wireless remote and uses 1.5 amp hour cordless drill batteries about 10 or so rigging before charging. It will ship with 2 batteries and charger identical to the Milwaukee 18 volt cordless drill batteries. Website is still under construction but will be:
Glider-Rigger.com email is ventureflight (at) gmail (dot) com
CH ASW27
Old June 5th 19, 03:12 PM posted to rec.aviation.soaring
Thanks in advance.
Gary
"SQ"
best,
Evan Ludeman
Not sure what you mean by 'failure mode', Evan. There is no brake mechanism in the actuator as far as I know. It just stops and locks due to the small pitch of the spindle/screw system. A short push on the remote button will give you a rather constant 3-5mm travel so you can finely adjust the position.
Old June 5th 19, 05:24 PM posted to rec.aviation.soaring
Tango Eight
Thanks in advance.
Gary
"SQ"
Now watch it in action, ~7 min for the inside wings. Try to beat that..
best,
Evan Ludeman
Gear failures in these low cost actuators are not unknown. If the gears break, but the motor is the only brake, can you see the potential problem?
Sorry -- it's my job to think about crap like this.
best,
Evan
Old June 5th 19, 06:51 PM posted to rec.aviation.soaring
Thanks in advance.
Gary
"SQ"
best,
Evan Ludeman
best,
Evan
Evan,
If I get really bored some day, I will take out the gears from the motor to the spindle (or maybe it's the nut that is being turned) and see how the system reacts to compression. I strongly assume that the pitch of the screw is so low, that it is self arresting - just like in all our fasteners.
Old June 5th 19, 09:35 PM posted to rec.aviation.soaring
Herb, I think Evan asked a valid question, seems like you gave a valid answer. I see no need to "remove gears" to test a geartrain failure issue.
If a fine pitch (as you indicated), likely basically no issue.
Thick grease may negate an issue on a coarser pitch.
Unless, of course, a major earthquake that rattles bits around......then, what a wing rigger when it fails is doing is likely a moot point.... ;-)
Old June 6th 19, 01:26 AM posted to rec.aviation.soaring
JS[_5_]
On Wednesday, June 5, 2019 at 1:35:52 PM UTC-7, Charlie M. (UH & 002 owner/pilot) wrote:
I've seen wing stands that would do more damage in failure mode, and nobody cares.
Soaring Aids Variometer Tony Condon[_2_] Soaring 4 July 4th 09 11:24 AM
Soaring Aids Variometer Tony Condon[_2_] Soaring 0 July 2nd 09 04:00 PM
Hearing Aids Casey Wilson Piloting 9 February 20th 06 01:40 AM
Yet another case of AIDS jsmith Piloting 12 March 18th 05 01:20 AM
MT Props w/Electric Pitch Control x Home Built 6 April 1st 04 02:44 PM
