One-man rigging aids - is the electric up/down control worth it?
Old June 5th 19, 10:18 AM posted to rec.aviation.soaring
Frank Whiteley
Default One-man rigging aids - is the electric up/down control worth it?
On Tuesday, June 4, 2019 at 9:12:09 PM UTC-6, Jonathan St. Cloud wrote:
On Tuesday, June 4, 2019 at 3:23:36 PM UTC-7, Charlie M. (UH & 002 owner/pilot) wrote:
Older GRP maybe....I haven't seen a tool like that in anything made in 30+ years.
I have seen SGS-1-35, and older glass ships, but I usually deal with "AWx" ships, so, I am not an expert.
Most "newer" ships can use a longer tapered pin to align the first hole (assuming 2 root pins) to get one started, then fiddle the 2nd one in......
I know of at least two Nimbus 4's delivered with the "crowbar tool". I put rubber hose over mine, but I have seen another one used on someone's glider without any covering
Factory graunch bars were pretty common, but sometimes the lift pins showed some wear of using muscle over mind. Alignment is worth the time spent on it, so good rigging aids really help.
Soaring Aids Variometer Tony Condon[_2_] Soaring 4 July 4th 09 11:24 AM
Soaring Aids Variometer Tony Condon[_2_] Soaring 0 July 2nd 09 04:00 PM
Hearing Aids Casey Wilson Piloting 9 February 20th 06 01:40 AM
Yet another case of AIDS jsmith Piloting 12 March 18th 05 01:20 AM
MT Props w/Electric Pitch Control x Home Built 6 April 1st 04 02:44 PM
