This week's AW&ST: apparently THAAD will have some ABM (as in anti- *ICBM*) capability.
Old August 25th 04, 07:11 AM
Kevin Brooks
"Scott Ferrin" wrote in message
Scott, it is getting sort of hard to tell exactly *what* you are saying.
Not to anyone with even a passing understanding of the English
language. Let's take it step-by-step and see where you went galloping
off into the sunset.
I made my first post stating that AvWeek mentioned terminal ABM
capability for the THAAD. I made no mention of any other missile.
In YOUR first post in reply
"but its engagement footprint in that role is supposed to be
pretty small"
to THAT I said
" As for the footprint, terminal defenses
have never really had all that long of range anyway. Sprint was about
25 miles (although it could cover those miles a hell of a lot faster
than THAAD :-) ) and HIBEX was less than that."
Meaning essentially "so what, we're talking about TERMINAL
defense".
To which you wrote "Yes, but Sprint was merely the lower tier of a
two-tier system; Spartan had a significantly longer reach. "
Which is where you seem to have gotten lost. Who gives a **** about
Spartan? Spartan wasn't a terminal defense missile. We're talking
about terminal defenses.
Great, hope you are happy now; I generally prefer to talk about defenses
that *work*, and relying solely upon a very short range terminal defense
only is not probably the way to acheive that whole "works" goal--if you
doubt that, there is the FACT that the Sprint you brought into the equation
was merely a backup for Spartan, and there is the FACT that the military is
keenly interested in getting things like ABL and THAAD into service to
provide a higher tier for the current PAC-3 Patriot in the TBM defense role.
Given that an ICBM comes in from a lot higher, and one heck of a lot faster,
than TBM's, I'd posit that a terminal-only defense is not worth spit. You
know what? BMDO apparently agrees with that approach.
You
started this thread about THAAD and its ICBM intercept capability. When
fact that THAAD will have a reduced range when/if it engages an ICBM was
pointed out, you brought Sprint into the equation, and when it was
pointed
out that Sprint was however part of a two-tier system, you launched into
NMD
(as a whole?).
Ponting out that THAAD would ALSO be part of a tiered system. If me
saying "Well yeah. And NMD has a longer reach than THAAD *and*
Spartan." wasn't specific enough for you to follow well, that's not
really my problem. Maybe when I said "NMD" that's what threw you.
God knows they're are enough acronyms being tossed around about it.
For simplicity's sake I'm referring to
big-missile-in-hole-in-ground-in-Alaska."
Great. Wonderful. So you want to use THAAD as the second tier. If it is
existing-THAAD, welcome to the world of Nike Ajax revisited (not in terms of
exact range, but *concept*), in the sense that you are going to need a lot
of missile sites to cover the very large metropolitan areas strung up and
down the coast. Maybe you mean your AvLeak "Son of THAAD"? OK. Now you are
talking about the world of Nike Hercules revisited, in that while not as
dense a system as Ajax was required, you still need a few launch sites
spread out along the coast. And if the threat comes in the form of an
advanced SLBM (and remember the Chinese are working on the JL-2 with an 8K
kilometer range), then you'd likely expand the number of sites required due
to having to cover more southerly approaches (and you'd probably require
another GBMI site too, 'cause Alaska may not serve that need).
To keep it simple--yes, THAAD can apparently engage an ICBM,
but only at reduced range
Hence the statement T-E-R-M-I-N-A-L. On numerous occasions.
My point is that in this case it becomes pretty small, and with THAAD in the
anti-TBM role only offering some 200 km range, that means your anti-ICBM
range is going to be some (small) fraction of that--hence the need for that
whole Ajax-reminiscent deployment plan. Your Son-of-THAAD would ameliorate
that to some extent--if it works (and based upon past THAAD tests to date,
that road my be rocky).
, which means you need a fair number of systems to
make it work.
Which is what I've been saying. Which is why I was wondering how they
think ONE battery could defend an entire coast.
My guess is poor journalism--wouldn't be the first time. One battery
defending the entire coast would mean that in order to cover the farther
limits of its range envelope it would have to fire the interceptor pretty
darned early; that ICBM RV is moving in the neighborhood of six, seven, or
maybe a bit more km/sec, and a centrally located battery on the coast would
have to range out to some 1000 plus km in order to make that terminal kill.
Frankly, I don't see that being a very dependable scenario. I just read the
AvLeak article at Aerospace Daily, and did not see any reference to a single
battery being able to defend the western approaches, nor were any engagement
or detect/track range capabilites mentioned.
You mention new booster--great. But you are really not talking
about THAAD anymore when you do that (saying you are going to give it new
boosters and presumably new radars would leave you with a system that
shares
rather little with THAAD, IMO).
Of course I'm talking about THAAD. An SM-2MR Block I and SM-3 could
hardly be more different but they're both Standards and they're both
associated with the Aegis weapon system.
OK, THAAD in its original concept was designed as a *theater* system, and it
is sized accordingly. Based upon open source range, you are talking about
triple or quadruple the range of the current system if it were to be able to
cover the entire coast, and that is using its current anti-TBM max range as
a guide. That does not appear to jive with the AvLeak mention that the
currently proposed longer-legged version would only reduce the missile load
per vehicle from 8 to 6.
Spartan had a
reported max range of some 740 km!
Great. NMD is several THOUSAND *miles*.
Do you want to talk about GBMI or THAAD? Make up your mind.
I wanted to talk about THAAD but apparently you wanted to talk about
Spartan.
No, I want to talk about a system that works (or is likely to). Unless the
article you read was very different from the 20 Aug AvLeak piece in
Aerospace Daily, I think you have extrapolated some stuff that was not
there--I saw no mention of trying to cover the entire coast from one launch
site, and I saw no specific ranges mentioned. The only "could be" I saw was
mention of possibly emplacing the system to protect Hawaii "years earlier"
than 2009.
THAAD comes in at about *on-third* the
size of Spartan (6.2 meter length bversus some 16 meters, diameter of
0.34
meters versus over one meter for Spartan. If you think THAAD is gonna
outreach Spartan, think again.
Where did I say that? I've said "terminal" and Sprint all along.
I've never once mentioned Spartan. You did. I don't think THAAD
would have any trouble at all reaching Sprint's 25 mile range.
Which makes it (THAAD, not your postulated "Great Big Son of THAAD") a
pretty lousy ICBM protection system, right?
Here you're just stating whatever the hell you feel like apparently.
That or you don't know what the hell "terminal phase" means.
What *does* it mean to you? To me, a 25, or even 100 mile range for that
matter, is going to mean you are sprinkling launch sites up and down the
coast if you want to make it viable, and even then it is only viable *if*
your GBMI is available to cover the entire coast to provide that upper tier.
The folks doing THAAD are referring to its ICBM intercept capability as a
"residual capability"--not something I'd want to hang my hat on.
*I*
said that *AW&ST* said THAAD as it is RIGHT NOW (not the test vehicles
of years back but the ones being built NOW) has *some* anti-ICBM
capability in their terminal phase, and they will be tested against
ICBMs.
And as I mentioned to you before, you can find stuff available via a Google
that shows that it was already expected to have a *very limited* anti-ICBM
capability a few years back, albeit with a smaller range fan.
My specific words we "According to
the article the data on THAAD in it's current incarnation indicates
that it may have some terminal-phase ABM capability."
Yep, it does. But you need more of them to cover the same area that one
battery would cover in terms of the TBM threat. This is not anything new;
the range basket of Patriot PAC-2 against TBM's was smaller than it was
against air-breathing threats.
How many 25-mile range missile
sites would you need just to cover the greater LA metropolitan area, much
less every other metro area along the coast?
Here's where your reading comprehension, such as it is, breaks down
again. What I said was,
"They also mentioned in the article that THAAD may reveive a "kick
motor" and larger booster and would be able to defend the entire east
or west coast against barge-launched (or sub-launched I suppose) TBMs
with one battery. "
Not in the Aerospace Daily version. How fast do you think that puppy is
going to have to move to cover the entire coast from a central firing
location, and hit a target at the periphery? How soon in the target's flight
will you have to make that launch, and with the RV moving at 7 km/sec, how
far *back* along its trajectory will it be? Sounds pretty fishy to me.
You do know the difference between a TBM and ICBM don't you? Even
the old version of THAAD had a 125+ mile range against TBMs. That 125
mile kill was at an altitude of 93 miles. So drop a 250 mile diameter
circle over LA and you'll see that even a battery of old model THAADs
would EASILY defend much more than the LA metro.
That is agianst TBM's!! They move one heck of a lot slower (and lower) than
ICBM's! Which is why your range basket shrinks when you try to make your
system defend against the faster ICBM. Do you remember how many Nike Herc
sites were required to defend large metro areas? There were *nine* Nike Herc
sites (one battery per site) protecting LA, with an eighty mile engagement
range. Let's assume that THAAD (right now) has an effective range against
ICBM's of, say, one half its range against TBM's, so your 125 mile range
becomes 75 miles, about the same as Nike Herc had against air-breathers.
Eliminate any requirement for sites guarding the "back door" (360-degree
protection was established by Nike around LA), you can cover LA with one
battery--barely. If you want to cover the San Diego through LA corridor (and
I don't see how you could not), then you are talking two and more likely
three launch sites to cover the area up through Burbank. You'll need another
one or (more likely) two batteries to cover the SF Bay area. Then you have
to cover Portland with another site, and the Puget Sound with three more,
which means you just covered *part* of the West Coast with, which gives you
a total of between seven and nine sites, with no overlapping coverage --and
you have left Sacramento, Salem, etc. with no coverage at all, something
those folks might be a tad resentful about.
And if you are going to try and protect the urban areas on the Left
Coast
with THAAD, don't you think you'd *need* dedicated basing?
Nope. Do you even know what a dedicated missile site is? Do a Google
on "Nike Hercules" and you'll get back two million hits with lots on
info. A dedicated missile site is NOT and Airforce or Army base with
a few missile launchers living there.
Bullpoopie.
So you ARE sayning a "dedicated" missile site is just a couple
launchers sitting at the end of an airbase?
No, I am saying I used to live down the street from Nike Herc crewmen, and I
have clambered around their bases (I used to squirrel hunt on an old BOMARC
site back when I was in high school), and I am quite well aware of what they
were.
I lived just down the street from both a Bomarc and a Nike Herc
site as a kid; crap, my brother's first job in the Army was Nike Herc
crewman, for gosh sakes. The Nike herc site even included *housing* (the
Bomarc site did not because it was able to use nearby Langley AFB).
EXACTLY. That's my point.
WHAT is your point? That those sites were not merely wide open spaces, I
hope. That they require acrage, and security, and siting of the radars so
they don't mess up Bob's satellite TV reception or make Bill's garage door
opener go berserk, and if they are not located near a military base that can
provide housing and subsistance, you have to do it some other way, as well,
I hope.
Now, if
you are going to use THAAD in this role, you WILL need dedicated launch
sites, and dedicated radar sites, and you will need a lot of them to
cover
the metropolitan areas on the west coast.
Not so. Read above (many times if you need to).
Fine. You go right ahead and keep thinking that THAAD can kill ICBM's at the
same range it kills slower TBM targets. This is obviously pointless.
Brooks
The crews would
get kind of tired of eating at the Golden Arches every meal (thought
they
might like the TDY pay....).
Why would they have to? Is there something inherently impossible
about stationing a couple THAAD launchers on an air base?
Gee, and I guess you are going to conveniently have an airbase located
every
100 km or so along the coast?
Get off the crack. That or learn some math. Even with the old THAAD
you'd have 50 miles of overlapping coverage if you stationed launchers
two HUNDRED MILES (over three times the distance you mention) apart.
THAAD ain't gonna cut it as a metro defense
system covering the west coast;
Well certainly not in the world *you* live in. For those of us who
can add and read it's EASILY a "metro defense system" (whatever the
hell THAT is).
whether or not your Great Big Son of THAAD
will is another issue (maybe we ought to worry about getting the kinks
ironed out of vanilla THAAD first?).
Maybe you need to stay out of the sugar. It's not MY "Great big son
of THAAD".
each with a dozen
or two launchers for LARGE missiles with quite a bit shorter range.
Those "LARGE" missiles were not much bigger than THAAD
10,000 pounds and 41 feet (Hercules) vs 2000 pounds and 20 feet for
THAAD. You're right, they're damn near identical. How many Nike
Hercules you think they could squeeze onto a THAAD launcher? Ten?
Five? One?
I said AJAX! You were arguing about AJAX sites.
(Damn, I just sprayed my keyboard with Pepsi). We were arguing the
need for dedicated sites. And the Hercules use the same launch rails
and sites the Ajax did.
Compare Ajax and THAAD and
then get back to me, OK?
Let's see:
Ajax THAAD
Fixed site. 10 missiles on a mobile launcher
Mach 2.3 Mach 9.5
Range 30 miles 125+ miles (old THAAD- not today's)
Altitude 70,000 ft 93+ MILES
Yep, you're right. Exactly the same.
Well, being as you have bounced from a question about THAAD to GBMI, from
comparing Ajax siting requirements to hercules, etc., it appears my
reading
comprehension may not be the problem here.
LOL. You haven't even been able to follow your *OWN* comments let
alone mine.
Hey I didn't write the article. In fact if you had any reading skills
at all you'd see I was wondering about it myself.
Then why are you so hellfire determined to argue that deploying THAAD to
cover west coast metro areas would really be 'no big deal', so to speak?
I never said it was. I said *they* seem to think so and *I* want to
know what they're basing that assertion on.
Once you have done that, I think you will see where your
holes are, and they will be large ones. That is a LONG coast line
along
Pacific, with a lot of population centers distributed along it.
They said that with the different booster THAAD could cover an
entire coast with one battery. Last I heard a THAAD battery was
suppose to be something like ONE radar and 32 missiles or so.
That will be one hell of a booster, and it will no longer be a THAAD.
A Titan IV isn't a Titan I but it's still a Titan. An SM-3 isn't an
SM-1 MR but it's still a Standard. An AIM-9X isn't an AIM-9B but it's
still a Sidewinder. Need I go on?
No. As you have plainly lost the bubble already.
How so? Perhaps a better example would have been the AA-10/ AA-10
"long burn". It's still the same basic missile.
Old August 28th 04, 07:15 PM
Scott Ferrin
You know what? Apparently you STILL need to go back and reread what I
said. I have NEVER said that THAAD could cover an entire coast
against *ICBMs*. I brought up Sprint because I am supposing THAAD's
range would be similar against an ICBM. 20ish miles. While the
Sprint had a much faster reaction time from a flight point of view, I
suspect that THAAD with more modern software/radar/etc. would know
*where* it needs to go sooner than Sprint did so it could launch
sooner than a Sprint could.
No. I'd want to use it in the terminal phase. "Second tier" and
"terminal phase" are not always synonomous.
If it is
down the coast.
Yeah, if we're talking about ICBMs. We're not. Or *I* never have
been anyway.
Nope. I never mentioned that protecting an entrie coast against
ICBMs.
OK. Now you are
We're not even on the same page. Read my original post or two. I
never said anything other than THAAD has some ability in the terminal
phase against ICBMs and will be tested in such a role and that the
THAAD with a bigger booster will have the long range capability
against T-B-Ms.
Which is what "terminal" means. As I've mentioned (repeatedly)
terminal is in the last phase of flight -when then reentry vehicles
are entering the atmosphere- and it is SHORT range. Sprint, HiBEX,
and HEDI were all less than 30 miles range (and HiBEX about half
THAT).
Slow down. Find where I have EVER said THAAD could engage *ICBMs* at
long range and quote it for me. If I did say it then yeah it's my
mistake, but rereading my posts I've not said it and I certainly don't
think THAAD could take out ICBMs at long ranges. On the other hand if
you really think about it, against a purely ballistic target all you
have to do is be in the area when the thing is going to pass by.
Depending on how accurately they can predict the flight path and how
long it takes them you could conceivably have a THAAD in the right
place at the right time at longer ranges. Against an RV with even
minimal manuevering ability you'd be screwed of course.
And we're still talking about TBMs remember.
make it work.
"MDA already is planning upgrades for Thaad. Around 2008, the system
will receive new software to triple the engagement area. Moreover, two
years later Thaad may receive a kick-motor and a larger diameter
booster to provide a ten-fold increase in the area the system can
protect. Then one battery should be able to protect each U.S. coast
against a barge-launched ballistic missile, one of the threats
officials worry about. "
My thoughts on it are this. The radar has a 600 mile range they say
so I'd think you'd need at least a couple radars with the coverage
overlapping enough so there isn't a spot they could come in close to
the coast and shoot off a SCUD-type. There's no reason the missiles
have to be colocated with the radar so you could have launchers up and
down the coast. You're not talking about defending against barrages
of barge launched missiles so it's more a matter of deploying five or
ten launch vehicles and spreading them out enough to get the coverage
you want.
shares
"The first operational Thaad equipment would be fielded in 2009, with
a radar, battle management suite, three launchers and 24 missiles. "
Which makes it eight still. And the current launcher has ten
missiles. I didn't see anywhere that it mentions how many
bigger-booster THAADs would fit on the truck. I know that when PAC-3
gets it's bigger booster it will reduce the number of rounds per
launcher. Which is why the European MEADS people aren't thrilled
about it.
Spartan had a
Spartan.
site,
It must be:
"...Then one battery should be able to protect each U.S. coast against
a barge-launched ballistic missile, one of the threats officials worry
about. "
than 2009.
Just as a backup to NMD in the ABM role. In the case of Hawaii it's
small enough that you're talking terminal defenses again. It doesn't
NEED to have a real long range against ICBMs in this case.
0.34
You're still talking ICBMs (which I've never associated with the
defend-an-entire-coast idea).
The as-the-crow-flys distance between Loring AFB and Homestead AFB
(pretty much the furthest north and south points on the east coast) is
1634 miles. Old THAAD had a range of 125 miles. Today's THAAD?
Don't know. For sake of argument let's use the 125 mile range. Now
the future THAAD with a bigger booster (the one claimed to defend a
coast with one battery against TBMs N-O-T ICBMs) would supposedly be
able to defend an *area* ten times the size of the current THAAD.
Doing a little math today's= pi * 125 miles^2 times that by ten,
take the sqrt, divide by pi gives you a range of 223 miles. So with
that figure it gives you a circle 446 miles in diameter in which one
THAAD launcher can reach out and touch. With minimal overlap you
could cover that 1634 miles with four launchers (this may have been
the way the journalist came up with his one-battery-per-coast idea).
Of course you wouldn't want minimal overlap. So bump it to five
launchers and you get about 150 miles of overlap at each intersection.
((446x5)-1634)/4 = 149 miles.
Me either. Reminds me of Patriot's original ATBM capablility.
*I*
ICBMs.
That I was not aware of.
That's why nobody in their right mind would put the launchers in a
little circle around the radar. They'd be WAY far apart.
Well THAT's what I've been talking about from the very beginning. I
don't know WHERE the hell you got the idea I was talking about ICBMs.
True. If we were talking about ICBMs. Which we're not.
Coast
Bullpoopie.
were.
I hope.
What I'm talking about is think Patriot launchers at the end of an
airbase in the middle east instead of dedicated missile sites that are
bases in and of themselves as the Nike bases were.
Now, if
cover
Well at least until you learn to read a little better it is. Quote
where I said "a single battery could defend an entire coast against
ICBMs".
Old August 29th 04, 01:41 AM
Kevin Brooks
news
equation
is
role.
faster,
against *ICBMs*.
You said that was what the article indicated, did you not?
And you are still talking about a rather small range fan, so you are back to
having to put quite a few sites into service if it is to be used as a
terminal defense against ICBM's for US targets. Off the top of my head, I
can't think of many places we'd *worry* about *ICBM's* hitting us other than
in the fifty states--in those other areas the threat will be TBM's, for
which THAAD should indeed be a capable response, as it has been designed for
that primary role.
You got three flight phases to deal with--boost, midcourse, and terminal. We
stand a reasonable chance of deploying a system that can handle TBM's in the
boost phase (i.e., ABL), but in many cases hitting an ICBM in the boost
phase is going to be kind of hard to accomplish (i.e., PRC). So yes, for all
intents and purposes, you are looking at a two-tier system against ICBM's,
GBMI and terminal. Unless you want to go to space based systems, which are a
bit out of reach at present.
If it is
of
lot
down the coast.
been anyway.
You have and you haven't, so to speak. Your initial post was dedicated to
the question of using THAAD against ICBM targets. EVERYBODY knows (or should
know) that THAAD is intended to handle TBM's already--but tweaking it to
handle ICBM's is something that a lot of folks, including your's truly, was
unaware of (though it is obvious that it has been looked at as having *some*
kind of anti-ICBM capability at least as far back as 2000 IIRC, albeit with
a reduced range fan).
ICBMs.
I just went back and reread your posts, and no, you did not say that; you
instead forwarded AvLeak's posit that a single battery could deal with TBM's
launched against the coast. My apologies for misreading your statements, but
when you start out talking about THAAD in the anti-ICBM role, then it sort
of sets the stage for that being the threat being covered.
OK. Now you are
8K
due
against T-B-Ms.
And IMO THAAD in the anti-ICBM role is therefore a waste of spit; it is too
short legged, and nobody is going to budget and support emplacing the
required sites to handle the coast. Your Son-of-THAAD versus TBM's is more
interesting, but again IMO is not very likely to see the the light of
day--we apparently have outr hands full just getting vanilla THAAD to work
as advertised.
THAT).
Spartan was also a "terminal" system, albeit one with a longer reach than
the lower tier Sprint. It only had a max engagement range of less than 500
miles, which kind of rules it out in the midcourse role, especially as it
was based nextdoor to the Sprints at the defended location. Look at it
another way--the USN has two "terminal" defense systems against anti-ship mi
ssiles, ESSM and Phalanx--one outreaches the other by quite some distance,
but it is still a terminal defense system. Vanilla THAAD will have a very
small range against ICBM's, making it of minimal use in the role.
that
There are only two places we really have to worry about ICBM's--Hawaii, and
the West coast. Could THAAD play a role in Hawaii, where the defended area
is finite? Yep. Could it play such a role on the West coast? Not really. Is
anybody going to argue to deploy THAAD along the coast to defend against
ship-launched TBM's? Very doubtful, to say the least. This has all the
earmarks of some LMCO guy feeding a line to AvLeak in an effort to pump up
THAAD, and little to offer in terms of real usefulness.
date,
make it work.
or
would
kill.
single
engagement
you want.
It is a heck of a lot easier to just take down the barges before they ever
get close enough.
new
shares
it
to
as
load
about it.
Look at the size. Current THAAD is a pretty small missile, and getting it to
the range mentioned is going to take some pretty serious size increase.
Compare MLRS, at twelve rounds per, to ATACMS, at two per; MLRS can reach
out to around 60 or more klicks, IIRC in its latest GMLRS form, while ATACMS
covers the 200-300 km gamut. One sixth the number of missiles.
Spartan had a
Spartan.
launch
site,
It must be:
about. "
The only access I had does not indicate any of that:
http://www.aviationnow.com/avnow/new...s/tha08204.xml
earlier"
than 2009.
Agreed, see above.
of
0.34
gonna
tier.
Whatever. I'll be looking for winged pigs the day THAAD is fielded in the
West Coast protection role, and if it can't handle the ICBM threat, it is an
utter waste.
*I*
ICBMs.
Google
anti-ICBM
Which means multiple bases, in a region that is not surfeit with active
bases. We could bring back the Presidio...
No, we have obviously been talking about two different things. I fixated on
your initial ICBM post--mea culpa. That said, I see little use in fielding
anything in that area that *can't* provide a relaiable defense against
ICBM's. Let's be real here--we know that everyone says we are not deploying
BMD to defend against the PRC, but *really*...
Herc
engagement
(and
another
have
you
coverage --and
One of us was, and the other started this thread in that vein. To me, anyone
wanting to install a major missile system to cover the Left Coast that
*couldn't* deal with the greater ICBM threat is a bit shy in the area of
common sense.
Coast
Google
with
Bullpoopie.
and I
BOMARC
they
were.
(the
door
can
well,
I hope.
But we have been talking about defending the Left Coast, not an airbase in
the Middle East.
Now, if
launch
cover
ICBMs".
I already apologized for that misunderstanding. But I am still of the
opinion that installing a *TBM* defense for the West Coast that can't handle
ICBM's is ludicrous.
Brooks
Old August 29th 04, 05:13 AM
Scott Ferrin
I never implied that was the plan. Nobody has except you. To have a
terminal defense for every area in the US no matter what missile you
used would be extremely expensive. All anybody is saying is "hey if
THAAD has reliable terminal defense capabilities against ICBMs it
opens up our options". In time of crises you could deploy them
wherever you thought you needed them (obviously you're limited by how
many systems you have on hand).
that primary role.
That depends. How long is THAAD suppose to be in service? Who's to
say China wouldn't try to hit a staging area with an ICBM?
There's an excellent report on that particular problem right he
http://www.xmission.com/~sferrin/BPI-Full_Report.pdf
(tried to find the original link but not too hard)
So yes, for all
GBMI and terminal.
You might not be familair with this:
http://www.globalsecurity.org/space/systems/kei.htm
http://www.orbital.com/MissileDefens...KEI/index.html
No prob. Sometimes I think one or the other of us could state the
moon is round and we'd still end up arguing about it.
against T-B-Ms.
Nobody has ever suggested that. What they ARE suggesting is that it
could be used as a MOBILE terminal ABM. That gives you more options
than if it had no ABM capability. Nobody has suggested deploying it
like the Nikes were in the 50's and 60's.
as advertised.
All of them had problems. The only one that's been mostly successful
from the get go is the FLAGE/ERINT/PAC-3. And I'd be more surprised
if the upgraded THAAD *didn't* see the light of day. It's cheaper to
upgrade what you've already got working than to start over from
scratch.
Depends how you define "midcourse". Since GBI and Spartan both go
after the RVs in space the only real difference is that Spartan
couldn't reach out as far. Distance isn't what determines what
"phase" a missile is in. You have the boost phase which is
self-explanitory but midcourse is considered the entire time the RV is
in space. That's where both GBI and Spartan were designed to kill
their targets. It doesn't become "terminal" phase until the RV is
reentering the atmosphere. That's pretty much how the "phases" have
been differentiated from day one.
especially as it
The Spartans and *some* of the Sprints were colocated mainly out of
convenience. If you check out this aerial if the Stanley R. Mickelson
Complex you'll see there are only 16 of the 70 Sprint silos located
there with the Spartans.
http://www.paineless.id.au/missiles/HSafeguard.html
The Sprints were spread out somewhat. How much I don't know. Miles
or tens of miles would be my guess. Since the ABM site was only
allowed to defend one location by treaty you'd WANT the Spartans near
the defended target for best coverage.
Look at it
You find it's going to be an either/or in most situations. ESSM is
*replacing* Phalanx in some instances. RAM is replacing Phalanx in
others.
But still better than none at all. If all it does is make an
adversary think twice then it's worth it.
the West coast.
Yeah, for now.
Well yeah, but five years ago if someone had tried to sell the idea of
shooting down airliners over the US it would have been met with
similar scorn.
you want.
get close enough.
Come up with a way to determine which one has a missile before launch
and I'm sure you'll have everybody's attention.
Not really. Compare the dimensions of THAAD and SM-3 and SM-3 ranges
270+ miles. And according to the article they'll get a threefold
increase in coverage from software improvements alone with THAAD. As
far as size, even just a bump from 13" to 15" on the booster diameter
will give you a 33% increase in volume of propellant you can carry.
Not even remotely similar comparison. A more accurate would be
Sparrow and ESSM. Similar front end, bigger booster, same launcher,
double the range.
It must be:
about. "
earlier"
than 2009.
Yeah, that's a completely different article.
Whatever.
Whatever? Do the math.
utter waste.
That's absurd. That's like saying if an F-35 can't outperform an F-22
in the air to air role it's an utter waste.
You're telling me there aren't four or five active military bases on
each coast?
ICBM's.
It's not *designed* to fill that role. Any ABM capability is a BONUS.
There's no sense in not using it in an emergency just because it
wasn't designed in from the beginning. Nobody would suggest taking
out helicopters with LGBs as a matter of course but it's been done.
If the ability is there it would be foolish not to take advantage of
it.
Preaching to the choir.
common sense.
That's not at all what they're talking about. One battery does not
constitute a "major missile system". All they're saying is "hey this
bigger THAAD will be able to cover a coast with one battery. Since
we're going to have the systems ANYWAY let's cover that potential
threat (the TBMs launched from ships) and kill two birds with one
stone".
the Middle East.
Are you telling me you REALLY can't follow that analogy?
Now, if
launch
cover
ICBMs".
So you'd rather park the missiles in a garage instead of using them?
Brilliant plan.
Old August 29th 04, 07:14 AM
Kevin Brooks
to
than
for
that primary role.
Where? You'd have to posit China lobbing an ICBM at a target being used by
the US during a third-party operation? I don't think that is realistic
enough to worry about--somewhere in the same category as say, "Protect
against RN Trident attack against US target". As to staging areas where we
would be operating against the PRC, maybe Australia? But that is in IRBM
range. Anything in their own periphery they could hit with a shorter range
missile. Which IMO takes you back to the "only US-proper targets have to be
defended from ICBM".
We
So yes, for all
ICBM's,
GBMI and terminal.
I don't do the "go to links" bit unless it looks like it is something worth
bothering with--a sysnopsis of the pertinent info is usually given with the
link.
TBM's
but
sort
against T-B-Ms.
too
Which takes us back full circle to the "what targets would we want to
protect against ICBM threats other than those in the US" bit. I see great
utility in an anti-TBM capability to protect contingency forces in the
theater of operations, but I see danged little use for protecting them from
ICBM threats that would come from outside the T/O. If you change the focus
back to the US proper, then I still don't see a lot of gain in terms of
THAAD in the terminal defense role unless you want to build and deploy
enough of them to protect *every* target within the bad guy's range fan.
Protecting only SF, LA, and SEATAC merely means the bad guys hit Portland,
Monterey, and Eugene instead. Or maybe Sacramento. Or Phoenix (it is not as
if the PRC is going to limit their range of future systems to being able to
only strike the beach cities--witness that new SLBM they are developing with
a nearly 6K mile range).
work
as advertised.
scratch.
But from what I have read, we don't really have *THAAD* "working" (yet). As
of this past January, only two of the planned eight intercept tests were
successful. Not a great track record as of yet. Hopefully it will improve,
and it will turn out to be a bang-up anti-TBM system. Which would be great.
Until that time, however, I'd be wary of corporate-sponsored "we are ready
to stretch/enhance it so it can *also* do..." stuff.
500
Take a gander at the max altitude that the *existing* THAAD acheives (at
least some 150 km), and by that reasoning it is a mid-course interceptor,
right? I don't think so.
especially as it
The Spartan's were tasked with "area" defense, the Sprints with point
defense. IMO, Spartan did not rise to what could be considered mid-course
intercept status.
Look at it
mi
distance,
others.
OK, my bad example; consider Sea Sparrow and Phalanx, from the near
past--plenty of vessels had *both*.
But it won't, unless we deploy them around virtually every target set he
could strike! As I pointed out earlier, take SF from his list and he
replaces it with Sacramento. Are you willing to give up one but not the
other? I doubt you are.
and
the West coast.
Yeah, for now.
For the forseeable future, with the caveat that "West Coast" extends inland
through the depth that the DF-31 can strike, which just about gets them to
Phoenix. There are a *lot* of major urban areas west of that longitudinal
line.
Is
up
similar scorn.
Two successes out of eight intercept attempts, and that does not include the
earlier non-intercept goal failures. But they are ready to already start
*expanding* its capabilities? I don't think so.
you want.
ever
get close enough.
It would be a lot easier to set up an exclusion zone than it would be to set
up terminal defenses around all of the potential targets. You said we'd be
able to deploy these systems to protect these areas *when they are needed*,
right? So that rules out protecting against the "bolt from the blue"
scenario. If the threat is some scow launching a TBM, then taking out the
launcher is a heck of a lot more sensible than trying to take out the
missile after it is launched.
to
But aren't they talking about a three or four fold increase in range? You
are not going to get that by increasing the booster by 3 inches. As to the
software bit, that may refer to improving the radar and its capabilities,
for all we know.
ATACMS
double the range.
But you are not talking about doubling the range here. And why does the
MLRS/ATACMS comparison not meet the same criteria, or at least come darned
close?
It must be:
about. "
http://www.aviationnow.com/avnow/new...story.jsp?id=n
ews/tha08204.xml
earlier"
than 2009.
Whatever.
Why *bother* doing the math when the critter has yet to prove that it can
reliably acheive the *lesser* requirements already in place?! And why bother
when protecting only against TBM's, and only when you think they *might* be
used against you (I assume you are still saying that this would be a nifty
"deploy it only when you need to" system) is pretty much worthless?
an
utter waste.
No, that is not the same thing. The F-35 is intended to perform a somewhat
different set of missions, at a cheaper cost. OTOH, what you seem to be
saying (using your F-35/F-22 model) is, "Hey, we should go ahead and plan on
giving the F-35 the same exact mission requirements we have set up for the
F-22--forget about the fact that it is a program that has yet to prove
itself capable of doing its current, more limited roles...expand the
envelope!" Two successes out of eight attempts ain't a very good place to
start expanding your envelope.
each coast?
Let's see, AFAIK Fort Ord is largely being passed over to the local
community as we speak, and there is nothing I know of between that location
and the Trident base up off the Puget Sound that meets your criteria. We
gave up those coastal artillery sites in between to the Park Service some
decades back... :-)
on
fielding
ICBM's.
No, it was designed from the outset as an ABM system, just not one aimed at
the longer ranged/faster missiles in the ICBM class.
it.
So you are saying it is a great system to have available if we get intel
that says Johnny Jihad is planning on putting up towards the coast in a dhow
with a Scud under a tarp, at which point we would presumable deploy our
THAAD systems around each and every possible target he could stike in that
manner? Sorry, but I still find that pretty lame. It is not going to be
worth spit against the unplanned-for launch, and it is not going to be worth
much against the more lethal (and just as likely) PLA DF-31 orPLAN JL-2 that
could threaten the region. IMO, let THAAD mature such that it can do what it
was intended to do--protect deployed forces from enemy TBM attacks. Anything
further is just buying into the contractor's change-order-yielded-profit
plan.
anyone
common sense.
stone".
Well, we also have to worry about the possibility that they could send it
*into* the US via cargo container, and launch it from *within* our borders,
right? yes, I know that is a bit fascetious, but the point is that we can't
*afford* to dump the inevitable few billion bucks it would take to turn
THAAD into Son-of-THAAD on the basis of wanting to protect against an
*extremely* unlikely threat category. Develop vanilla THAAD such that it
actually reliably works as it is supposed to, deploy it as required to
protect US forces in threat areas, let GBMI handle the ICBM threat, and take
those extra billions you saved by NOT developing THAAD into son-of-THAAD and
use them to enahnce our targetring capabilities, or our countermine
capabilities, or our ISR capabilites...the things that we DO need to do, and
for which plenty of threats do actually exist.
in
the Middle East.
See my earlier comments. Against a TBM threat to CONUS, either you have them
in place 24/7, or you are better off just planning on setting up that
exclusion zone while saving all of that additional R&D money.
Now, if
launch
to
cover
at
ICBMs".
handle
Brilliant plan.
No, I am saying that you have not shown where there is, or is likely to be,
a sufficient threat of that nature (TBM's versus CONUS) that can't be more
easily addressed with other means.
Brooks (Who, while he has historically has been pro-BMD, is getting a bit
tired of it turning into an endless money pit that sucks funding away from
more readily available and vitally needed requirements, and sees this
contractor-initiated ploy as just another attempt to pad the corporate
nest).
Old August 29th 04, 06:12 PM
Scott Ferrin
Hard to say. Let's not forget two things: 1. China isn't the only
country out there of questionable status who is trying to develope
ICBMs (Iran, India, etc.) and 2. THAAD isn't the result of a "we
need terminal defenses against ICBMs for the entire US" but a theater
defense missile *that happens to have some anti-ICBM capability*.
So yes, for all
ICBM's,
GBMI and terminal.
link.
Too good for it or does it strain your brain too much? My guess is
you want an abstract with the link so you can not go to it anyway and
still pretend like you did. Just on this thread there have been
numerous times in which you have missed what has been written or saw a
big paragraph so didn't read it at all. And it shows. My point in
providing those links (if you've read this far) is to enlighten you on
the BPI issue. Where's the harm in going to the link and reading? It
can only help you have a better undertanding of a subject you
apparently take an interest in.
too
You're missing the point entirely. Anywhere you park a THAAD you're
going to have terminal ABM capability. You're going to have it
whether you use it or not. This isn't a case of "what targets do we
need to defend and if there are none we won't build the system".
I see great
So essentially you're saying "since we arent' going to protect
everything we shouldn't protect anything"? Correct? And if not what
ARE you saying?
Great. That means we dictate what they DON'T hit. Pretty simple
concept isn't it? As for the SLBM it's more like 5000 miles and they
are not even CLOSE to fielding it.
work
as advertised.
scratch.
The way it seems to be scheduled is that we'd know if things were
working right before changing things. I'm guessing it would be
similar to the way they've done AIM-120. It's "pre-planned product
improvements" have been public knowledge for years.
500
I was thinking the same thing when I wrote that. The fact remains
though that Spartan has NEVER been considered a terminal phase
missile.
especially as it
intercept status.
That's fine. There are those who think the earth is flat and that the
moon landing was staged. Everyone's entitled to their opinion.
Look at it
mi
distance,
others.
Sea Sparrow has a minimum range and that's the area Phalanx covers.
In that situation Phalanx is the terminal defense. Let's not forget
that Sea Sparrow is also great for smacking small ships in close. The
reasons Phalanx is being replaced and CAN be replaced by RAM and ESSM
are because the minimum range of RAM and ESSM is less than that of
Sparrow (admittedly that's pure speculation on my part), missile
reliability is getting better, and with today's faster missiles
Phalanx's utility is going down.
Am I willing to give up SF to protect the Trident base up the coast?
HELL yeah. Atlanta over Washinton DC? Damn straight. You'd prefer
to lose both Atlanta AND Washington DC correct?
and
the West coast.
Yeah, for now.
line.
Yeah. And?
Is
up
similar scorn.
*Planning*. As I mentioned earlier AMRAAM's improvements were laid
down before it even entered service (I remember reading about them in
the 80's) too. I don't see what the problem is. It's business as
usual in just about every area of manufacturing/ product developement.
How successful do you think Intel would be if they didn't plan what
would come after the Pentium 4 until AFTER they'd decided they
wouldn't make anymore Pentium 4s? Same thing.
you want.
ever
get close enough.
Factor in the necessary ships and infrastructure to intercept, detain,
and inspect probably THOUSANDS of ships and barges EVERY DAY and
you'll see how impractical that idea is.
You said we'd be
scenario.
You're mixing and matching ICBM and TBM defense without any thought to
CONTEXT. The TBM defense one-battery-per-coast idea is an always-on
type of thing. The "let's move some THAADs to DC for a while to
protect against ICBMs" idea is a crisis thing. AFAIK there is no (and
has never been any) plan to deploy THAAD as a perminant ICBM terminal
defense system in any location.
Great. So what are you going to do, start sinking every ship off the
coast? Great idea.
to
No. If you'd read what I wrote instead of saying "whatever" you'd see
they're not even looking at a TWO fold increase in range. They're
talking 223 miles vs 125.
You
True, but they're not looking at increase in range of three or four
times. And BTW 15-13 is 2 not 3.
As to the
for all we know.
No kidding?
ATACMS
double the range.
You're right. I'm talking about LESS than doubling the range.
And why does the
close?
Because ATACMs carries four times the payload five times the range.
We're talking about carrying the SAME payload maybe 80% further.
Because then you wouldn't look like an idiot when you go off about
increasing the range by three or four times when that's never been
suggested.
And why bother
Well DUH. The THAAD is intended to fulfill a different mission than
GBI. Just as the F-35 has some air-to-air capability, the THAAD would
have some anti-ICBM capability.
envelope!
Nope. What I'm saying is that just because the F-35 isn't as good as
the F-22 in air-to-air doesn't mean it should be cancelled.
each coast?
decades back... :-)
Go he
http://www.globalsecurity.org/milita...lity/conus.htm
on
fielding
ICBM's.
That's part of your problem. ABM refers to missiles designed to take
out ICBMs. Thus the A-B-M Treaty. The ABM treaty didn't give a rat's
ass about missiles designed to take out tactical or theater missiles
as long as they couldn't hit an ICBM. In the literal sense a
catcher's mitt is an ABM. It stops ballistic missiles. (Go look up
the word "missile" if you're lost). "ABM" as it's used in the rocket
sense means a system designed to take out an ICBM.
it.
I would too. However if you had any reading skills at all you'd see
that's never been suggested. What's been suggested is that with that
bigger booster it'd ALWAYS be online against that kind of threat.
Just as likely? How many terrorist attacks have their been in the
last five years? How many missiles has China launched at other
countries in the last five years?
plan.
Those who fail to plan. . .
stone".
right?
So we shouldn't defend against a threat that we CAN defend against
because a different threat is more difficult? Great plan. That's
like saying you're not going to put a smoke alarm in your house
because it wouldn't help if it got hit by a hurricane. Great plan.
If you'd been reading (and retaining the words) you'd see that the
"few billion bucks" are going to be spent ANYWAY. As I've said before
(AISB from here on out) improvements to THAAD are going to happen to
make it function in it's ATBM role better regardless. The coastal
defence/ terminal ABM capability is a bonus result of those
improvemnts. If you make improvements to your car engine that are
designed to improve fuel economy are you going to complain if it
happens to make the engine more powerful in the process?
Apparently the US military doesn't share your assessment of the
threats.
in
the Middle East.
AISB. . .
Brilliant plan.
Describe those means.
nest).
Old August 29th 04, 10:58 PM
Jack
Can't anybody in this thread exercise a little common sense and snip the
extra crap? It might have been enlightening, but NO, you can't be bothered!
The only apparently knowledgeable person, O. Fairbairn, has done exactly
that, and restored some order, thankfully.
Jack
Old August 30th 04, 03:42 AM
Kevin Brooks
by
we
range
be
So what? I have seen nobody (other than you) postulate any potential ICBM
threat to US forces deployed outside the US; the ICBM threat is being
considered against the US proper.
And we do need a defense capability against TBM's for contingency forces--no
argument there. But again, nobody is claiming there is an ICBM threat
against deployed US forces, are they?
snip
http://www.orbital.com/MissileDefens...tors/KEI/index.
html
worth
link.
No, I just find playing a simple "battle of links", with no abstract, a bit
tedious and basically lazy on the part of the naked-link poster. Now look
here, paisan--I have tried to be reasonably nice to you, to include
acknowledging that I did misinterpret some of your earlier postings in this
thread and apologizing for same. Why don't you make the same effort towards
civility that I have?
OK, enough is enough. You got an apology, so what the hell else you want is
beyond me. I suggest you read Orvil's post and take heed--he apparently
knows quite a bit more about this than either you or some AvLeak writer (and
more than me as well). You'll note that his conclusions are generally in
linne with what I have been telling you. If you want to conduct further
discussion of topics, be energetic enough to at least indicate what your
links are saying and provide them "for further reference", and get off your
high horse, OK?
Adios.
Brooks
snip
Old August 29th 04, 09:18 PM
Orval Fairbairn
I have been following this thread recently. As a retired Lockheed
engineer who did performance studies on THAAD, I can clear up a few
things.
1. THAAD is not currently an anti-ICBM system. It does not have the
performance (except on a lucky shot) to shoot down ICBMs consistently.
They travel too fast for THAAD's performance envelope. Specific numbers
would be classified.
2. THAAD had some development problems. They did not have even the
second team working on the original design. It appeared that a lot of
the design was made by people who had not taken "Missile Design 101." A
lot of the problems were simply stupid design and manufacturing errors.
We can only hope that those problems have been cleared up.
3. THAAD should be an effective TBM defense. That is what it is designed
for, and simulations show that it can hit a variety of targets.
4. An anti-ICBM missile would be a completely new, much larger design,
which would probably use only the basic interceptor technology, not the
same hardware.
Old August 31st 04, 02:24 AM
Scott Ferrin
On Sun, 29 Aug 2004 20:18:28 GMT, Orval Fairbairn
things.
So is it's residual ABM capability something like Hawk did - before
they made the modifications? The impression I'd gotten with Hawk is
they went "hey let's try it against a missile" and it worked. After
that they made some changes to the system to make it a little better
in the ATBM role.
That would explain why AW&ST said the configuration of THAAD is quite
a bit different now than those test vehicles.
same hardware.
I don't think the idea has ever been to have THAAD as a dedicated ABM.
It's more like a bonus. ATBM as you said is the role it was designed
for. All I've ever seen written suggested that they just not let that
residual capability go to waste.
Weeks Solution and Weeks Special Mirco Aerobatics 0 October 2nd 04 04:11 PM
