Oops
Old June 10th 19, 12:45 AM posted to rec.aviation.soaring
George Haeh
Default Oops
There's two kinds of failed final glides:
1. Pilot continues until out of options and puts glider into bad place - or botches low approach at fixated destination.
2. Pilot decides insufficient margin and either selects good field or heads to landable terrain that can be reached at height allowing field selection and acceptable circuit.
With sustainers it's more complicated and we are learning that remaining battery capacity can be uncertain. The gas powered folks have long had their problems.
If you have a sustainer or SL, and are uncertain whether it will get you all the way back, you might want to consider climbing until the fuel or volts are depleted and then seeing where you can get from that height.
Old June 10th 19, 02:00 AM posted to rec.aviation.soaring
JS[_5_]
Default Oops
A big consideration for arrival over a landable place if not in a pure glider is allowing extra height to safely try the engine/motor.
Eric Greenwell published a handbook for this ages ago. It's called "A Guide to Self-Launching Sailplane Operation". Much of it is still valid for even FES. The attitude that there's no guarantee is an important part of operating a sustainer or SLSP, even electrics.
Oops, concluded - Oops 82.jpg (1/1) Mitchell Holman[_9_] Aviation Photos 0 July 28th 17 12:54 PM
Oops, concluded - Oops 81.jpg (1/1) Mitchell Holman[_9_] Aviation Photos 0 July 28th 17 12:54 PM
More Oops - Oops Holy Crap 00127.jpg J3mia03 Aviation Photos 0 August 12th 10 07:56 PM
Oops, concluded - Oops 76.jpg (1/1) Mitchell Holman[_5_] Aviation Photos 4 August 8th 10 07:19 AM
Oops, concluded - Oops 78.jpg (1/1) Mitchell Holman[_5_] Aviation Photos 1 August 7th 10 11:32 PM
