Condor 2 v 2.0.5 with VR Support
Old June 14th 19, 09:37 PM posted to rec.aviation.soaring
ripacheco1967
Default Condor 2 v 2.0.5 with VR Support
Is this good enough to run Condor?
Intel Core i5-8400 - 8GB Memory - NVIDIA GTX 1060 3GB - 1TB Hard
Oculus - Rift S PC-Powered VR
Old June 14th 19, 11:09 PM posted to rec.aviation.soaring
Dan Daly[_2_]
https://www.oculus.com/rift-s/ - there are min specs there, and a tool you can download to check if your system is good to go or not.
Old June 14th 19, 11:27 PM posted to rec.aviation.soaring
Paul Agnew
I believe he was asking if Condor would run on his system.
From the Condor Support page:
PC
To install and run Condor you will need
Windows 7, 8 or 10
Intel i3, i5, i7 CPU or equivalent.
5.5 GB of free space on hard drive or SSD
A dedicated graphics card with 1 GB memory. The graphics card should have benchmark (www.videocardbenchmark.net) result of 1000 minimum, 4000 is very good and 8000 perfect.
(Integrated graphics cards and cards with benchmark result below 1000 are usable, but with severely reduced graphics settings)
Internet connection required for activation
Virtual Reality
Condor 2 supports the Oculus Rift VR headset, and using Revive also the HTC Vive headset. Both of these have their own requirements, which can be checked for your system using tools on the Oculus and Vive websites.
Oculus: https://www.oculus.com/
Paul A.
Old June 15th 19, 02:47 PM posted to rec.aviation.soaring
ripacheco1967
Thanks for the information.
Im buying a PC just to run Condor 2
I understand that my Mac won’t work even with boot camp if using a VR headset.
Old June 16th 19, 09:11 AM posted to rec.aviation.soaring
Chris Wedgwood[_2_]
MAC should work -- if the GPU is powerful enough.
The PC spec you posted above should be fine, but I would recommend SSD instead of hard drive.
Curtiss T-32 Condor II pics 1 [02/11] - 1930s-passengers-boarding-american-airlines-condor-biplane-airplane-AAMYTR.jpg (1/1) Miloch Aviation Photos 0 November 17th 17 02:38 PM
Curtiss T-32 Condor II pics 1 [01/11] - 1007-condor.jpg (1/1) Miloch Aviation Photos 0 November 17th 17 02:38 PM
Curtiss B-2 Condor pics [01/17] - 463x600xHOWARD-Charles-H_-1st-Lieutenant-USAAC-and-Dr_-Robert-Millikan-CalTech-with-Curtiss-B-2-Condor.jpg (1/1) Miloch Aviation Photos 0 August 29th 16 03:46 PM
Condor Thanksgiving and Condor Christmas Contests [email protected] Soaring 0 October 22nd 12 03:33 PM
Bushite soldiers beat to death innocent Children to 'let offsteam' - Support Our Demands For Open Communications - Unraveling the Mystery- you can not find a single soldier on Earth to publicly support GeorgeW Bush without immediately being re Tiger Naval Aviation 0 April 10th 08 01:20 AM
