So I tried some buddy flying with Gliderlink recently. For a while it worked, and my buddy (who is not used to Gliderlink at all) thought it was great. Then we stopped "seeing" each other on the gizmo. I never figured out why, but I think one of us accidentally hit the goTenna "slide switch" and thus turned off the connection. This brings forth two suggestions:
(1) for users, play with it on the ground and get used to the app, so that you can solve app problems in the air without needing more attention than we can muster while flying. It also may help if you mount the goTenna somewhere where you can see it, then if it disconnects you will see its LED blinking. (2) for Ben: perhaps move that switch to somewhere less prone to an accidental tap, e.g., inside the goTenna status menu item. |
Moshe, some possible reasons that you stopped seeing each other on GliderLink:
1) If the phone loses it's GPS fix, it will stop broadcasting your location. This can happen if the phone is in a pocket without a clear view of the sky. I will add a notification to GliderLink when this happens. 2) If the goTenna firmware has not been updated to the latest, it may be suffering from the known problem that causes it to lose the bluetooth connection to your phone. 3) The goTenna battery may have died. This is less likely because the goTenna battery lasts quite a while. |
On Monday, June 17, 2019 at 12:50:15 PM UTC-4, wrote:
Moshe, some possible reasons that you stopped seeing each other on GliderLink: 1) If the phone loses it's GPS fix, it will stop broadcasting your location. This can happen if the phone is in a pocket without a clear view of the sky. I will add a notification to GliderLink when this happens. 2) If the goTenna firmware has not been updated to the latest, it may be suffering from the known problem that causes it to lose the bluetooth connection to your phone. 3) The goTenna battery may have died. This is less likely because the goTenna battery lasts quite a while. The firmware is from this past spring. And the battery was fine. Loss of GPS signal could have happened. But it was working up to that point, and never started working again after that point in the flight. What happens if one taps the goTenna slider accidentally? Presumably disconnecting from the goTenna and not reconnecting again unless one taps it again? |
Support the U.S. Soaring Team | Frank Whiteley | Soaring | 1 | July 13th 14 04:07 PM |
US Soaring Team eBulletin 21 | John Seaborn | Soaring | 0 | July 21st 05 05:14 PM |
US Soaring Team eBulletin | John Seaborn | Soaring | 0 | November 20th 04 08:11 PM |
GTA pilots on the US Soaring Team | chris | Soaring | 2 | September 1st 04 11:14 PM |
U.S.A. Soaring Team Web Update | John Seaborn | Soaring | 0 | August 17th 04 05:14 PM |
