2 civilian airliners down south of Moscow
Old August 25th 04, 11:58 PM
John A. Weeks III
In article VP6Xc.135504$sh.122307@fed1read06, Darrell
My local paper this morning said the southernmost plane sent a hijack code
just before it went off radar.
A report that has not been discounted by Russian authorities.
-john-
John A. Weeks III 952-432-2708
Newave Communications
http://www.johnweeks.com
Old August 26th 04, 03:41 AM
Mailman
code just before it went off radar.
-john-
....which proves, yet again, how little journalists understand: setting the
transponder/IFF to emergency mode is done in a hijacking - or any other
emergency. All it does is to show the plane with a different display on the
radar screen.
Mailman
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 100,000 Newsgroups - 19 Different Servers! =-----
Old August 26th 04, 04:16 AM
BUFDRVR
emergency.
Uhhh...no. The ICAO transponder emergency distress code is 7700 while hijacking
is (I think??) 7200. There's also one for NORDO (No Radio) which I think is
7600.
BUFDRVR
"Stay on the bomb run boys, I'm gonna get those bomb doors open if it harelips
everyone on Bear Creek"
Old August 26th 04, 04:31 AM
Bob Coe
emergency.
7600.
7500 for hijack. Your other guesses are correct. 77 and 76 came from the old
64 code days. Back when there was only 10 airplanes within a hundred miles of
an airport :-) 00 was the intercept code, and 11 was the interceptor weapons free
code (nuclear). 12 was contact flying below 12kft.
Old August 26th 04, 04:40 AM
Bob Coe
"Howard Berkowitz" wrote
Hijack is 7500. For some reason I haven't fathomed, the FAA ATC
procedure is to contact the aircraft by radio and ask "Sir, please
confirm you are squawking 7500."
That's just one option. There are other radio code phrases. We used to
get new ones all the time when we filed.
Old August 26th 04, 06:30 AM
Pooh Bear
Oh great ! What presence of mind ! What berk thought that one up ?
Has it occurred that just maybe, here and there, a hijacker just might
not notice the transponder code was changed?
Mercuns just love to screw up the admin way.
Graham
Old August 26th 04, 04:31 PM
Chad Irby
Any hijacker who knows what "squawking 7500" means will certainly know
enough about the rest of the system to either respond correctly or turn
the system back to the right freq.
The ones who *don't* know what it means won't catch the significance of
the message (and in the early moments of the hijack, they won't be
hearing the radio anyway).
cirby at cfl.rr.com
Remember: Objects in rearview mirror may be hallucinations.
Slam on brakes accordingly.
Old August 28th 04, 11:09 PM
running with scissors
Pooh Bear wrote in message ...
someone has a good presence of mind. let look at this:
"'Aircraft X', confirm your squawk, 'Center X'". thats taken what 7
words, how long does it take to say ?
now consider the following:
1. when an emergency code is squawked, say for example a 7500 squawk,
the controller doesnt leap in his chair exclaiming "A Hijack! A
Hijack! what do i do?" for someone else say, "****! get the president
on the phone!" rather:
an emergency squawk initiates a set procedure, which will involve the
controller requiring radio silence from everyone else on that freq.
and will likely provide an alternate freq. for everyone else to change
to and other aircraft will be vectored from the vicinity. the
controllers will implement an action plan or rather set procedure
depending on what the situation requires.
2. transponders have a couple of different methods of entereing the
squawk code, some have numeric keypads, others have rotating dials.
some also have a feature to shortcut to a specific code.
accidental input of a specific code, has happened, does happen and
will happen. Personally speaking, durin the very first days of
instruction, a few moons ago now, i was advised to enter transponder
codes from the back first, to prevent any accidental emergency code
squwaks (with the rotational dial transponder its possible as you are
winding through the numbers to trigger an emergency code) and so set
off the alam bells at the handling control center.
3. controllers are pretty capable people, believe it or not, and their
familiarity with their daily profession enables them to make accurate
judgement calls on many situations.
A controller asking an aircraft transmitting an emergency squawk to
confirm, is going to get perhaps only a few alternative responses:
- the pilot responds with "'Center X', thats a negative on the 'x'
squawk, we're good here, please confirm correct squawk, thanks for
the heads up "aircraft x'"
- the controller gets no response, which is an indication as to a
problem.
- an unusual response occurs, which again is an indication as to a
problem.
now, just before people go off on a tangent that the pilot could have
a gun to his head and is lectured on how to respond, controllers are
pretty adept at working things out for themselves. a controller can
pretty much figure out if you have a problem with something from vocal
cues. furthermore pilot are pretty adept at dealing with problems,
there was one instance during a hijack that the pilots keyed the mic
during the hijackers vocal outbursts in the cockpit so not only could
the control center hear, but also it was on the tapes. thats not
mentioning the basic issue of has the aircraft deviated from the
flight plan, has it changed heading or altitude ?
listening to the tower tapes of an emergency situation, before all the
other pilots on the frequency changed off to the alternative assigned
frequency, there were a few blind transmissions from other pilots just
quickly and simply "good luck guys, god be with you" though i am not
particularly religious nor sentimental, it's something to give to a
flight crew in a ****ty situation.
as another side note, a friend of mine worked out rather rapidly
during flight that he lost the ability to transmit, could recieve
fine, but not transmit. which of course led him to input 7600
transponder code. the controller obviously came back to attempt to
make communication (bear in mind the controller only knows its lost
comms) and at the controllers call attempts, he hit ident. the
controller pretty much worked out rather rapidly, that the pilot could
hear and not talk, and so an easy day was had by all, as the
controller issued him with vectors, confirming by replying with the
ident.
so, after considering the above, is it more appropriate to say 7 words
and confirm the situation, or go all out into full blown emergency
situation. presence of mind yes. berk, no.
which is irrelevant either way. if it hasnt been changed he will
continue with his plan, if it has, he will continue with his plan. but
the ability remains to provide a non verbal indication of an emergency
situation.
hardly.
Graham
Old August 29th 04, 02:48 AM
Howard Berkowitz
Note that I did not make the statement about presence of mind. While I
don't have the procedure in front of me, those are not the words said by
ATC. Those words specifically are confirming a squawk of 7500.
Consistent with controller workload, occasional random squawk
verification requests might be a decent idea, to decrease suspicion. Of
the recent crop of hijackers, their English was imperfect, and a routine
query just might get by -- it might not.
I certainly did not suggest that was the procedure, which indeed would
be asinine.
And a simple confirmation request doesn't draw attention to 7500.
You seem to be making quite a few assumptions about tangents.
[snip explanations of tangents]
Were the words what you suggested, I would have less concern. Specific
confirmation of 7500, for exactly the reasons you mention below, do not
make sense from a human factors standpoint.
While terrorists may not be courteous enough to be repetitive, any 7500
is sufficient to alert NORAD. Fighters always can be recalled, but if
the hijacking is real and a suicide attack is a real possibility, time
is urgent. I can easily see a pilot's last living act to be changing the
squawk before a hostile takes his life, and control of the aircraft.
might
situation.
hardly.
Graham
Did we win in Viet Nam? Lisakbernacchia Military Aviation 89 July 12th 04 06:03 AM
SpaceShip 1 - South African Connection MWEB Home Built 4 July 1st 04 07:08 AM
CIA U2 over flight of Moscow John Bailey Military Aviation 3 April 9th 04 03:58 AM
U.S. Troops, Aircraft a Hit at Moscow Air Show Otis Willie Military Aviation 0 August 28th 03 10:04 PM
U.S. Air Force lands at Moscow air show Otis Willie Military Aviation 0 August 20th 03 04:19 AM
