GliderLink - New team soaring app for airborne location sharing
Old June 17th 19, 05:50 PM posted to rec.aviation.soaring
Default GliderLink - New team soaring app for airborne location sharing
Moshe, some possible reasons that you stopped seeing each other on GliderLink:
1) If the phone loses it's GPS fix, it will stop broadcasting your location. This can happen if the phone is in a pocket without a clear view of the sky. I will add a notification to GliderLink when this happens.
2) If the goTenna firmware has not been updated to the latest, it may be suffering from the known problem that causes it to lose the bluetooth connection to your phone.
3) The goTenna battery may have died. This is less likely because the goTenna battery lasts quite a while.
Old June 17th 19, 06:26 PM posted to rec.aviation.soaring
The firmware is from this past spring. And the battery was fine. Loss of GPS signal could have happened. But it was working up to that point, and never started working again after that point in the flight. What happens if one taps the goTenna slider accidentally? Presumably disconnecting from the goTenna and not reconnecting again unless one taps it again?
Support the U.S. Soaring Team Frank Whiteley Soaring 1 July 13th 14 04:07 PM
US Soaring Team eBulletin 21 John Seaborn Soaring 0 July 21st 05 05:14 PM
US Soaring Team eBulletin John Seaborn Soaring 0 November 20th 04 08:11 PM
GTA pilots on the US Soaring Team chris Soaring 2 September 1st 04 11:14 PM
U.S.A. Soaring Team Web Update John Seaborn Soaring 0 August 17th 04 05:14 PM
