On Thu, 26 Aug 2004 21:10:39 +0930, "Scet" wrote
in rec.aviation.military: Is it this rise in EGT that is looked for to ensure the system is operative? Is there a thermal switch that is made to indicate the system is or isn't working or is the first inkling that the pilot has that all is not as it should be, aircraft controllability issues during the approach phase? Hi Scet I don't believe there was any variations in the EGT used to verify if the BLC system is working or not, but I will try to verify this with a friend who used to fly the 104 and see if he can remember. In the meantime, this is what the T.O. 1F-104G-1 has to say about a BLC malfunction : "If a boundary layer control system malfunction is experienced as manifested by a strong rolling tendency as the wing flaps travel to the LAND position, proceed as follows : 1. Flaps-TAKEOFF. 2. Throttle-Adjust to minimum safe setting to reduce the effect of asymmetric BLC while flaps are returning to TAKEOFF. 3. Fly final approach at not less than 195 KIAS with flaps in TAKEOFF position. 4. Touch down at 165 KIAS minimum." Regards Peter |
Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 06:42 PM |
You Want Control? You Can't Handle Control! -- Was 140 dead | ArtKramr | Military Aviation | 0 | March 2nd 04 08:48 PM |
Tactical Air Control Party Airmen Help Ground Forces | Otis Willie | Military Aviation | 0 | January 22nd 04 02:20 AM |
Control Tower Controversy brewing in the FAA | PlanetJ | Instrument Flight Rules | 168 | December 6th 03 01:51 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
