At 08:53 25 June 2019, John McLaughlin wrote:
I've recently started flying a Ventus2. I can't rig the thing without a lo of struggle. The trouble is, there's a cover above the spars and you can't se anything once the first wing is in. I struggle to get the second wing to fit, never knowing whether it's a bi too high or a bit too low. The ground is uneven and sloping, which doesn' help. I hope some Ventus owners can give me some tips, please? Fit the left hand wing first (front stub spar) and support with wing stand. Make sure that the wing is fully flush with the fus (requires water ballast shut, flaps neutral and airbrakes unlocked). Insert the main pin into the spar by about 1 inch and put wing tape on the top of the fus/wing joint (to stop the wing getting pushed out when fitting the second wing). Adjust the wing support or twist the fus in the belly dolly to make sure the wing stub is located vertically central within the right hand side of the fus. This is the important bit for simple rigging. Now fit the right hand wing which should just push straight in with just a small vertical adjustment. I NEVER need to look in the fus to get the right hand wing height correct, the lead on the wing pins does that as long as you are in the ballpark. Rigging the Ventus is just like a Discus and around the easiest of the modern. Hope this helps. |
On Tuesday, 25 June 2019 13:15:05 UTC+3, Jonathan Walker wrote:
Rigging the Ventus is just like a Discus and around the easiest of the modern. Hope this helps. And yet no one is asking how to rig a AS or LS. |
Maybe the problem is just me!
Nope, it's Schempp.
Nothing wrong with SH, it just takes skill rather than brute force to rig one. I prefer a SH to a brand S any day.
On Friday, 28 June 2019 00:17:03 UTC+3, Tim Taylor wrote:
Nothing wrong with SH, it just takes skill rather than brute force to rig one. Yes it takes skill or bag of tricks which is not needed with 2 pin wing. |
On Friday, June 28, 2019 at 5:58:25 PM UTC+1, krasw wrote:
On Friday, 28 June 2019 00:17:03 UTC+3, Tim Taylor wrote: Nothing wrong with SH, it just takes skill rather than brute force to rig one. Yes it takes skill or bag of tricks which is not needed with 2 pin wing. I remain to be convinced about that as a generalisation. My ex-JS1c and current ASH 26e with 2 non-tapered pins need to be incredibly accurately aligned to get the pins in and can sometimes can be very frustrating. OTOH a previous LS7 with 2 x well tapered pins was very easy. I have had 5 single pin SH gliders (and a 6th soon) and all were fine to rig albeit a bit tight for the first few riggings if new. |
On Thu, 27 Jun 2019 13:56:05 -0700, krasw wrote:
Nope, it's Schempp. Not even that. Its single pin vs two pin spar designs. I've flown and rigged both, single pin (Discus, Libelle, SZD Junior) and two-pin (Pegase, ASW-20). For my money a two-pin system is easier to rig because, once both wings are fully home on the drag pins its just a matter of moving a tip up or down until the first wing pin slips in. Then the second pin usually just slides in without fuss. By contrast, with a single pin system you have six or seven pins to line up exactly (drag pins on both wings plus the two or three spigots on the spar ends) before both wings will fit far enough in for you to even think of putting the main pin in. This often involves considerable faffing about and strange mutterings. Then the main pin goes in without any trouble. FWIW Libelles and Kestrels can be easier to rig than SH gliders because all pins and sockets are out in the open. -- Martin | martin at Gregorie | gregorie dot org |
On Thursday, June 27, 2019 at 2:35:38 PM UTC-7, Martin Gregorie wrote:
Not even that. Its single pin vs two pin spar designs. I've flown and rigged both, single pin (Discus, Libelle, SZD Junior) and two-pin (Pegase, ASW-20). For my money a two-pin system is easier to rig because, once both wings are fully home on the drag pins its just a matter of moving a tip up or down until the first wing pin slips in. Then the second pin usually just slides in without fuss. By contrast, with a single pin system you have six or seven pins to line up exactly (drag pins on both wings plus the two or three spigots on the spar ends) before both wings will fit far enough in for you to even think of putting the main pin in. This often involves considerable faffing about and strange mutterings. Then the main pin goes in without any trouble. FWIW Libelles and Kestrels can be easier to rig than SH gliders because all pins and sockets are out in the open. -- Martin | martin at Gregorie | gregorie dot org Agreed, Martin. Possibly the same with a JS3, since due to space constraints it uses the one pin and more-to-align technique. At least with the JS3 a side-hinged canopy isn't in the way. Tim, please explain the brute force bit. Is it the brutal hydraulic trailer ramp jack used to align the second spar pin? I really miss that simple assembly technique on the Duo. Jim |
ventus rigging visual clues | [email protected] | Soaring | 13 | May 3rd 18 12:08 PM |
Ka-6 Rigging | vontresc | Soaring | 19 | August 14th 08 04:55 AM |
Ventus C rigging | James Hamilton | Soaring | 8 | July 7th 06 08:30 AM |
Ventus C rigging | James Hamilton | Soaring | 0 | July 6th 06 07:41 PM |
ski rigging | Drew Dalgleish | Home Built | 3 | December 3rd 03 04:16 AM |
