On Saturday, June 29, 2019 at 4:27:18 AM UTC-5, Charlie Quebec wrote:
I just removed the factory screws and bracket, then got two of the inside threaded bolts from an old PC and screwed in. Worked great. A couple of comments; - Both Cumulus and Wings & Wheels have the Becker locking shells in stock. Unsure about the other vendors. - While I am not in love with the Becker latching system, preferring the LXNav "bail" type instead, they both have one advantage over the common screw-in type. Which is you can connect/latch the Becker/Filser/LXNav connectors blindly in our tight instrument panel confines. - See http://aviation.derosaweb.net/presentations/#wiring (slide 47) for details. - John OHM Ω |
Thanks for the comments & presentation link. I didn't see the shell on W&W and I still can't find it on Paul's site.
But no problem... I have 2 coming in the mail from NJ. Since you mentioned it (on the slide), know of a source for the "Filser/Dittel" sliding catch post-style shell? That's the type used on my archaic AR3201. Maybe I should just buy a 4201. Sarah On 6/29/19 10:03 AM, John DeRosa OHM Ω http://aviation.derosaweb.net wrote: On Saturday, June 29, 2019 at 4:27:18 AM UTC-5, Charlie Quebec wrote: I just removed the factory screws and bracket, then got two of the inside threaded bolts from an old PC and screwed in. Worked great. A couple of comments; - Both Cumulus and Wings & Wheels have the Becker locking shells in stock. Unsure about the other vendors. - While I am not in love with the Becker latching system, preferring the LXNav "bail" type instead, they both have one advantage over the common screw-in type. Which is you can connect/latch the Becker/Filser/LXNav connectors blindly in our tight instrument panel confines. - See http://aviation.derosaweb.net/presentations/#wiring (slide 47) for details. - John OHM Ω |
On Saturday, June 29, 2019 at 6:00:38 PM UTC-5, Sarah wrote:
Thanks for the comments & presentation link. I didn't see the shell on W&W and I still can't find it on Paul's site. But no problem... I have 2 coming in the mail from NJ. Since you mentioned it (on the slide), know of a source for the "Filser/Dittel" sliding catch post-style shell? That's the type used on my archaic AR3201. Maybe I should just buy a 4201.. Sarah On 6/29/19 10:03 AM, John DeRosa OHM Ω http://aviation.derosaweb.net wrote: On Saturday, June 29, 2019 at 4:27:18 AM UTC-5, Charlie Quebec wrote: I just removed the factory screws and bracket, then got two of the inside threaded bolts from an old PC and screwed in. Worked great. A couple of comments; - Both Cumulus and Wings & Wheels have the Becker locking shells in stock. Unsure about the other vendors. - While I am not in love with the Becker latching system, preferring the LXNav "bail" type instead, they both have one advantage over the common screw-in type. Which is you can connect/latch the Becker/Filser/LXNav connectors blindly in our tight instrument panel confines. - See http://aviation.derosaweb.net/presentations/#wiring (slide 47) for details. - John OHM Ω The LXNav "bail" type bits for the equipment end of things was "easy" to find. See the link below. But the connector eludes me (other than for Centronics types). Anyone? Bueller? Bueller? https://www.digikey.com/product-deta...AgkMEALw_wc B For the record Wings and Wheels lists the Becker latching "shell" as the alternate term "hood". https://wingsandwheels.com/db25-conn...d-housing.html |
PS - As to the Filser sliding type the link is shown below. Unlike the Becker sliding style which requires a special shell, this item is bolted to a standard DB25 connector (and shell). Enjoy!
https://www.newark.com/cinch-connect...SingleItem_ 1 - John OHM Ω |
Becker 4201 | soaringjac | Soaring | 4 | April 25th 19 01:56 PM |
Becker AR 4201 | John Foster | Soaring | 15 | October 6th 18 05:33 PM |
FS: 5 Becker 4201 + 1 Becker 3201 + 1 Dittel FSG5 Handheld | Ross[_3_] | Soaring | 10 | April 4th 18 04:36 PM |
FS: Becker 4201 | Romeozulu | Soaring | 0 | March 7th 14 11:21 AM |
FS: Becker AR 4201 | Don[_4_] | Soaring | 0 | September 19th 12 05:16 PM |
