Grob 109
Old July 13th 19, 08:21 AM posted to rec.aviation.soaring
Default Grob 109
I delivered a 109A from Arizona to the east coast. Out west, it didn't do well with the density altitude. I could climb OR keep the engine at a reasonable temperature. It couldn't do both at the same time. It was more manageable once I got to lower elevations of the midwest.
Once you eventually get up to altitude, it does scoot along pretty well. That's about the only thing that it did well.
I worked a few strong thermals in Arizona, but you have to imagine flying a 2-33... ballasted to double its gross weight. I wouldn't plan on doing much soaring unless you live somewhere with strong conditions.
Its frankly not a very good airplane and not a very good glider. I'm not sure what your intentions and expectations are, but I think that most people would be better off buying a Cessna 150 and/or a Libelle.
Old July 13th 19, 02:22 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
Default Grob 109
I've seen that from the other side - I once met a G109 under a nice big
cloud while flying my H201 Libelle and hugely outclimbed it without
really trying. At the time I put that down the the 109 belonging to an
Air Cadet squadron and quite possibly being flown by the cadet.
Martin | martin at
Gregorie | gregorie dot org
Grob Bob O'Rilley Soaring 3 April 29th 05 07:22 PM
Grob G-102 maintenance Stephen Szikora Soaring 4 November 25th 04 09:49 AM
Grob 103 SL R.W. Carpenter Soaring 2 March 21st 04 10:21 PM
WTB Grob 109 b Steve B Soaring 10 July 21st 03 06:54 PM
GROB 102 Vorsanger1 Soaring 4 July 11th 03 11:34 PM
