On Saturday, July 13, 2019 at 11:24:31 AM UTC-5, soaringjac wrote:
Anyone know what fuse rating i would need for an old Edo-Aire RT-551 radio. Its marked inop now but i still want to replace the fuse in the panel for it Between you, me, and the fence post, I prefer breakers rather than fuses. Breakers are easier to reset while in flight than replacing fuses. Remember to use a minimum of 3A fuses/breakers or risk loosing precious volts. See page 86 of this presentation http://aviation.derosaweb.net/presentations/#wiring. John OHM |
On Sunday, 14 July 2019 21:40:14 UTC+3, John DeRosa OHM Ω http://aviation.derosaweb.net wrote:
On Saturday, July 13, 2019 at 11:24:31 AM UTC-5, soaringjac wrote: Anyone know what fuse rating i would need for an old Edo-Aire RT-551 radio. Its marked inop now but i still want to replace the fuse in the panel for it Between you, me, and the fence post, I prefer breakers rather than fuses. Breakers are easier to reset while in flight than replacing fuses. Remember to use a minimum of 3A fuses/breakers or risk loosing precious volts. See page 86 of this presentation http://aviation.derosaweb.net/presentations/#wiring. John OHM Why would you ever need to reset breaker during flight? Breakers protect your wiring, if your wires shorted, are you sure you wan't to reset the situation during flight? |
On 7/15/19 9:07 AM, krasw wrote:
On Sunday, 14 July 2019 21:40:14 UTC+3, John DeRosa OHM Ω http://aviation.derosaweb.net wrote: On Saturday, July 13, 2019 at 11:24:31 AM UTC-5, soaringjac wrote: Anyone know what fuse rating i would need for an old Edo-Aire RT-551 radio. Its marked inop now but i still want to replace the fuse in the panel for it Between you, me, and the fence post, I prefer breakers rather than fuses. Breakers are easier to reset while in flight than replacing fuses. Remember to use a minimum of 3A fuses/breakers or risk loosing precious volts. See page 86 of this presentation http://aviation.derosaweb.net/presentations/#wiring. John OHM Why would you ever need to reset breaker during flight? Breakers protect your wiring, if your wires shorted, are you sure you wan't to reset the situation during flight? In many years of flying, never have blown a fuse or popped a breaker. If your wiring is shorted or an instrument has a fault, take care of it on the ground. Personally I think a five amp blown fuse is the perfect companion for an inop radio. Why waste your money on a breaker? |
I always try to size the fuse to match the expected draw of the device I'm protecting. No idea what an RT-551 radio draws but a Becker 3201 draws a max of 1.4 amps when transmitting (according to their literature, anyway). So, if you protect it with a 2 amp rated fuse then Ohms law tells us that you'd only lose 0.11 volts across the fuse (E=IR or 0.109v = 1.4 A * 0.078 ohms). Negligible. I guess I don't really understand all of the concern over losing 1 tenth of 1 volt across the fuse.
Robert On Sunday, July 14, 2019 at 1:40:14 PM UTC-5, John DeRosa OHM Ω http://aviation.derosaweb.net wrote: On Saturday, July 13, 2019 at 11:24:31 AM UTC-5, soaringjac wrote: Anyone know what fuse rating i would need for an old Edo-Aire RT-551 radio. Its marked inop now but i still want to replace the fuse in the panel for it Between you, me, and the fence post, I prefer breakers rather than fuses. Breakers are easier to reset while in flight than replacing fuses. Remember to use a minimum of 3A fuses/breakers or risk loosing precious volts. See page 86 of this presentation http://aviation.derosaweb.net/presentations/#wiring. John OHM |
On Monday, July 15, 2019 at 2:48:29 PM UTC-5, wrote:
I always try to size the fuse to match the expected draw of the device I'm protecting. No idea what an RT-551 radio draws but a Becker 3201 draws a max of 1.4 amps when transmitting (according to their literature, anyway). So, if you protect it with a 2 amp rated fuse then Ohms law tells us that you'd only lose 0.11 volts across the fuse (E=IR or 0.109v = 1.4 A * 0..078 ohms). Negligible. I guess I don't really understand all of the concern over losing 1 tenth of 1 volt across the fuse. Robert On Sunday, July 14, 2019 at 1:40:14 PM UTC-5, John DeRosa OHM Ω http://aviation.derosaweb.net wrote: On Saturday, July 13, 2019 at 11:24:31 AM UTC-5, soaringjac wrote: Anyone know what fuse rating i would need for an old Edo-Aire RT-551 radio. Its marked inop now but i still want to replace the fuse in the panel for it Between you, me, and the fence post, I prefer breakers rather than fuses. Breakers are easier to reset while in flight than replacing fuses. Remember to use a minimum of 3A fuses/breakers or risk loosing precious volts. See page 86 of this presentation http://aviation.derosaweb.net/presentations/#wiring. John OHM Robert, Yes, you are correct that a lowly 1/10Vdc across one fuse is a pretty small loss. But is that everywhere you are loosing volts in your panel? Do you also have a fuse at your battery? What about your wiring? What gauge is it (too small)? How long is the run? (You might be surprised how long - don't forget the positive lead forward and then the negative lead back again) Corrosion? Even the master switch looses something! Connections/connectors too. So watch out for those lost nickels and lost dimes because it all adds up. My $0.02. - John |
On Sunday, July 14, 2019 at 2:40:14 PM UTC-4, John DeRosa OHM Ω http://aviation.derosaweb.net wrote:
On Saturday, July 13, 2019 at 11:24:31 AM UTC-5, soaringjac wrote: Anyone know what fuse rating i would need for an old Edo-Aire RT-551 radio. Its marked inop now but i still want to replace the fuse in the panel for it Between you, me, and the fence post, I prefer breakers rather than fuses. Breakers are easier to reset while in flight than replacing fuses. Remember to use a minimum of 3A fuses/breakers or risk loosing precious volts. See page 86 of this presentation http://aviation.derosaweb.net/presentations/#wiring. John OHM Are you saying there's (more) voltage drop as the fuse gets smaller? I know, I should never question a guy about electronics with a guy that has OHM in it! ![]() Also, we are trying to protect equipment, AT the expense of any voltage drop, if there is any... Regards, Gary |
Bigger wire has less resistance per length. A fuse is basically a wire designed to clear when overloaded.
Fuses and breakers are really to protect the wire from overloads. A 12ga wire is good for a max load of about 20A. We won't get into free air load vs. in a bundle or conduit (it is rated at less). Sooo.....a 12ga wire can carry about 20A load. So the fuse would be equal or less so you don't overload the wire and start a fire. A smaller fuse on a big wire can then help protect the equipment. Small fuse (amp/A rating) is the same as a lower load. The good thing is it clears when overloaded but no fire. Downside is voltage drop since it is not designed for a big load. So a big wire, then fuses that protect the equipment within reason. This gives max power (less voltage drop) to the fuse. Hope I didn't muddle things..... |
On 7/15/19 9:04 PM, Charlie M. (UH & 002 owner/pilot) wrote:
Fuses and breakers are really to protect the wire from overloads. A 12ga wire is good for a max load of about 20A. We won't get into free air load vs. in a bundle or conduit (it is rated at less). Sooo.....a 12ga wire can carry about 20A load. No, it can carry a whole lot more than that. Residential electrical codes limit it to 20 amps to minimize I*R drops, where the length of the wiring could reach into hundreds of feet. The wiring will actually handle over 200 amps before it starts to melt. |
Fuse resistance and voltage drop - Yep, each fuse size has a different resistance and thus a voltage drop. Who knew??
Small values of fuses (and breakers) have a bigger/worse voltage drop. For the widely used Bussman brand fuses here are some examples (at a 1A load)*; 1A 0.190Vdc drop 2A 0.078Vdc drop 3A 0.045Vdc drop 5A 0.024Vdc drop So bigger is certainly better and 3A and higher is recommended. Thanks, John *Reference: http://www.cooperindustries.com/cont...AGC_Series.pdf |
Cambridge 302 fuse | [email protected] | Soaring | 6 | December 18th 18 03:36 PM |
ASW 27 Fuse ballast tank FS | pat | Soaring | 0 | July 22nd 12 05:56 PM |
B40 fuse question | Tuno | Soaring | 3 | December 8th 08 07:43 PM |
KR-2 fuse for sale | Turbo Tiger | Home Built | 3 | December 17th 05 06:27 PM |
Fuse the Wire or Fuse the Device? | ContestID67 | Soaring | 11 | April 27th 05 03:13 AM |
