Fuse for radio
Old July 16th 19, 11:36 AM posted to rec.aviation.soaring
kinsell
Default Fuse for radio
On 7/15/19 9:04 PM, Charlie M. (UH & 002 owner/pilot) wrote:
Fuses and breakers are really to protect the wire from overloads.
A 12ga wire is good for a max load of about 20A. We won't get into free air load vs. in a bundle or conduit (it is rated at less).
Sooo.....a 12ga wire can carry about 20A load.
No, it can carry a whole lot more than that. Residential electrical
codes limit it to 20 amps to minimize I*R drops, where the length of the
wiring could reach into hundreds of feet. The wiring will actually
handle over 200 amps before it starts to melt.
Old July 16th 19, 04:59 PM posted to rec.aviation.soaring
John DeRosa OHM Ω http://aviation.derosaweb.net
Fuse resistance and voltage drop - Yep, each fuse size has a different resistance and thus a voltage drop. Who knew??
Small values of fuses (and breakers) have a bigger/worse voltage drop. For the widely used Bussman brand fuses here are some examples (at a 1A load)*;
1A 0.190Vdc drop
2A 0.078Vdc drop
3A 0.045Vdc drop
5A 0.024Vdc drop
So bigger is certainly better and 3A and higher is recommended.
Thanks, John
*Reference: http://www.cooperindustries.com/cont...AGC_Series.pdf
Old July 16th 19, 05:37 PM posted to rec.aviation.soaring
Not to be pedantic but ... FAA Advisory Circular AC43-13-1B defines the maximum current along 20ft of 12ga mil-spec (Tefzel) wire across 14Vdc as ~12amps (fig 11-2 continuous current flow) or ~22 amps (fig 11-3 intermittent current flow).
Reminder that this is DC, not AC, current we are talking about. Edison pushed DC systems but was beat out (trounced) by Tesla/Westinghouse and their long-haul AC systems due to exactly what we are talking about here. Just sayin'. ;-)
Thanks, John
References:
https://en.wikipedia.org/wiki/War_of_the_currents
https://www.faa.gov/documentLibrary/...-1B_w-chg1.pdf
Old July 16th 19, 09:16 PM posted to rec.aviation.soaring
Thanks.....
My comment was not, "what can it carry before becoming a lightbulb", but what is acceptable for continuous load at a voltage.
Basics......small wire carries low load.....fuse keeps wiring from igniting.
Big wire carries larger load and/or less voltage drop.
Fuse/breaker keeps from a wiring fire.
Huge wire is a minor weight penalty.
Huge wire may be a PITA to run/fit/connect.
Huge wire does NOT "overwork" a device.....the device only uses what it needs until failure...thus.....a fuse or breaker.
Would anyone here use a 12ga jumper cable when car has a dead battery?!?!
Well.....off in neverland, cold, rainy, etc......I would try rather than quibble.
Going to welding cable with suitable clamps would likely yield a better result.....
Have a great day....
Old July 17th 19, 03:11 AM posted to rec.aviation.soaring
UH - I am with you on this. My pedantic comments were needlessly complicated for soaringjac's simple initial request. RAS at its best in the weeds.
Light bulbs? Welding cables? What a thought. ;-)
- John
Old July 17th 19, 03:42 AM posted to rec.aviation.soaring
From now on, please all peeps label me as Charlie.....I wish nothing negative to "UH" if I do a FUBAR. I know him and fly his ships at times, I do not speak for him.
Whatever......while a 12ga wire "may" handle a lot more than 20A, for how long, what insulation (yes, I am sorta versed from PVC/MTW through Tefzel and above....;-)).
As stated before, big wire from battery to buss is great.....
Fuses are basically the resistance and should fail before wire becomes a "heating element/light bulb".,...
So, specking (SP) a low amp fuse can/will drop voltage to devices.
To others......do you want to use a 12ga jumper cable to get home?, or maybe 4O welding cable to handle the current?
High load WILL roast a small cable/wire. Short very high load may pass, not our issue.....we want to know the downside of very small fuses/breakers versus voltage supplied to devices....
My thought.....big wire, great connections, protection (fuse or breaker...), and have fun.
Cambridge 302 fuse [email protected] Soaring 6 December 18th 18 03:36 PM
ASW 27 Fuse ballast tank FS pat Soaring 0 July 22nd 12 05:56 PM
B40 fuse question Tuno Soaring 3 December 8th 08 07:43 PM
KR-2 fuse for sale Turbo Tiger Home Built 3 December 17th 05 06:27 PM
Fuse the Wire or Fuse the Device? ContestID67 Soaring 11 April 27th 05 03:13 AM
