Thanks.....
My comment was not, "what can it carry before becoming a lightbulb", but what is acceptable for continuous load at a voltage. Basics......small wire carries low load.....fuse keeps wiring from igniting. Big wire carries larger load and/or less voltage drop. Fuse/breaker keeps from a wiring fire. Huge wire is a minor weight penalty. Huge wire may be a PITA to run/fit/connect. Huge wire does NOT "overwork" a device.....the device only uses what it needs until failure...thus.....a fuse or breaker. Would anyone here use a 12ga jumper cable when car has a dead battery?!?! Well.....off in neverland, cold, rainy, etc......I would try rather than quibble. Going to welding cable with suitable clamps would likely yield a better result..... Have a great day.... |
UH - I am with you on this. My pedantic comments were needlessly complicated for soaringjac's simple initial request. RAS at its best in the weeds.
Light bulbs? Welding cables? What a thought. ;-) - John |
From now on, please all peeps label me as Charlie.....I wish nothing negative to "UH" if I do a FUBAR. I know him and fly his ships at times, I do not speak for him.
Whatever......while a 12ga wire "may" handle a lot more than 20A, for how long, what insulation (yes, I am sorta versed from PVC/MTW through Tefzel and above....;-)). As stated before, big wire from battery to buss is great..... Fuses are basically the resistance and should fail before wire becomes a "heating element/light bulb".,... So, specking (SP) a low amp fuse can/will drop voltage to devices. To others......do you want to use a 12ga jumper cable to get home?, or maybe 4O welding cable to handle the current? High load WILL roast a small cable/wire. Short very high load may pass, not our issue.....we want to know the downside of very small fuses/breakers versus voltage supplied to devices.... My thought.....big wire, great connections, protection (fuse or breaker...), and have fun. |
Cambridge 302 fuse | [email protected] | Soaring | 6 | December 18th 18 03:36 PM |
ASW 27 Fuse ballast tank FS | pat | Soaring | 0 | July 22nd 12 05:56 PM |
B40 fuse question | Tuno | Soaring | 3 | December 8th 08 07:43 PM |
KR-2 fuse for sale | Turbo Tiger | Home Built | 3 | December 17th 05 06:27 PM |
Fuse the Wire or Fuse the Device? | ContestID67 | Soaring | 11 | April 27th 05 03:13 AM |
